Posts posted by piazzanoob
sweet project vehicle.
would look sweet with some low and some form of hand painted company signwriting of its era.
also the lady at nzta who deals with the black plate stuff might be able to dig up some info on the van too
otherwise fill out a ownership form. there is a specific one for deregistered cars and get a jp to sign it. and maybe get the all clear from police that there is no interest in it
Sweet project car to start off with.
Its also nice to see a couple who don't know much about cars to give it a go and learn along the way. this is also the best way to learn but can also be frustrating and disappointing when you don't know how to fix an issue or break something from a rookie move.
Also with the fuel tank situation I've seen very mixed results with the por15 kit. where a friend did his and the sealer did not stick and went through the fuel system. tank was a throw away and rockauto to the rescue for a new one.
i also guess that the budget on this vehicle is limited just by going on the posts. as have seen people often get there fuel tanks reco'd but can be spendy. but often radiator shops can do this service. which i suspect the tank gets electroplated
also now that you found media blasting. often getting a small blasting booth is handy for car resto stuff and would be a good investment.
also yeah get proper efi rated fuel pressure hose. because being efi the system runs at a higher pressure. where a car with a carb might only run at 5-15 psi. and any hose clamp is better than none.
keep up the good work
And if you get stuck on something there's plenty of people on the forum who can help or take a look through the tech talk part of the forum.
@Mr Vapour knows a few things about this
the easiest way ive found to do selector seals on 727 or 904 trans is to pull pan and valve body out and put new seal in then the seal is fitted square.
but this is how its done with trans in car.
nice progress looking forward to the end result
galaxie may be there tomorrow if the correct parts can be obtained. then put back together and hopefully go otherwise will take daily
fuck im useless at updating this thread.
motor goes and had a few hiccups on the way.
Hei dizzy being shit and causing a misfire
And me misplacing one pushrod not into the lifter causing one cylinder having no compression
and still some overheating problems
polished up my rocker shafts and machined the rockers to suit
and in the hole.
during the engine rebuild i spent some time and made a fan shroud
its definitely nothing flash but worked with what i had and my current skills
I then loaded it on a trailer to get the cam break in procedure done at work on the dyno.
after that i fixed up my old points distributor and got that working as the HEI caused a miss and fitted a new set of ignition leads
new cap rotor points and condenser
and changed the mechanical fan to one with a better angel which works much better
which is actually a chevy one
I also got these valve covers as a freebee from work as they required welding as had been broken and customer never came and got them. and sat out the back for years
so had them welded and started to polish them up
Ive put these on the backburner as spent hours on them and painted one and the paint peeled off and the more polishing i do im still not happy with them as they are not the greatest casting. i suspect these are from the 70s
also shows where it got repaired
And while i was on a trip in the usa prior to covid i got some needed parts
which i still need to fit.
also just before i rebuilt the engine i cut off the rear mufflers and straight piped it as was really quiet no v8 rumble at all. then was loud and sounded like a tractor so rewelded them back on.
to be continued...
- 24
Marketing chemicals in Auckland sell methanol but not sure if they sell in a small amount as normally in a 205 litre drum and goes off if left for too long.
Also try STA Parts as they sell race fuels
for the cam situation i would recommend henry at Auckland cams
have used him and is very helpful and isn't badly priced. i would also talk to him about compression ratio and what you want to do.
I take it that haul of parts were from trademe?
also are you willing to sell some of your spare engine bits?
14 hours ago, ul9601 said:
Bummer - when I was there last lockdown the queue was snaking out the main road so I gave that a miss. Wendy's used to be pretty nice joint but not any more...
By the way, do you think we'd attract more interest in the meet if I offer a free can of Double Brown (I have a 18 can box sitting in the garage not being drunk any time soon) or would it put people off...
yeah its not as good as it use to be. the orange juice isn't bad when its good.
haha perhaps on the wrong part of the country for that one!
ive also got some in the fridge that need drinking and have been there for some time
9 hours ago, ul9601 said:
How did it go last night?
i was the only one haha
and burger fuel was only doing online order so put that in too hard basket and bought Wendy's instead
On 17/02/2021 at 09:55, Mark_Fleming said:
^ can you see if the bumper has been wrapped with one piece or are there joins.....I have been told the chrome substrate doesn't like rolling around corners/bends....
had abit of a look and appears to be no joins and is one piece. but yeah in some of the bends it is coming off
I'll be there if anyone wants to join also
On 15/02/2021 at 09:35, Mark_Fleming said:
piazzanoob, any chance you can take some close up pics of the gold chrome wrapping on that chrysler's rear bumper for me? I spoke to the guy who wrapped it but he wouldn't send me close ups......at the very least I need to know if the wrap is one piece or a series of individual sections.....yes, chrome/gold metallic wraps are hard to do....
Does this show you enough?
6 minutes ago, cletus said:@piazzanoob what's up with that red and gold thing I've seen parked outside your work but haven't taken a pic of?
Sweet lawdy jesus its ugly
This one haha
I've named it grillz
Some Maori fella kingi down the line owns it. He loves it. But it's quite a pile. Vinyl wrapped everything
We seriously need to hide it somewhere as everyone is asking why we have it there
happy to take a look if you haven't already found someone.
send me a pm cheers
On 14/12/2020 at 17:58, piazzanoob said:
Burgers this Next Wednesday 17th February
who is interested?
@sentra @locost_bryan @sheepers @rich1179 @Shakotom @ul9601 @Styles @cletus @Tumeke @Snoozin @V8Pete @tortron @Kiwibirdman @punkoutnz @SOHC @michaelme @Avenga @MIRAGE-MAN @Thousand Dollar Supercar @Ghostchips @Ghost @Hurmeez @Snorkpipe @xsspeed @The Bronze @The Dude @ae85 fiend @63Ragtop @MichaelJFox @rusty360 @Matteybean @66gt @Mr Vapour @Corbie @SOHC @sluggy @Sambo @Not-a-number @Taistorm @zep @f100_dreamin @Ashkellybarr @sleeektoy @rivalrx @dabuzz @mk2marty @shizzl @beachlander @mlracing.co.nz @Sourkraut89 @slacker.cam @chris r @Threeonthetree
And maybe some others i forgot?
I know you said this on your latest post but is it okay to wet sand expoxy primer?
i would've thought that it isn't sealed and ends up wrecking the primer
also what grade sand paper do you start and finish with?
progress is looking good
Burgers this Wednesday guys
who is interested?
piazzanoob's 1964 Ford Galaxie 500 seeeedaaan
in Projects and Build Ups
After doing a few miles the motor needed the heads being retorqued
After the heads were retorqued i fitted the MSD ignition system i bought. i also bought a black msd cap and leads.
And replaced the high beam headlights as both inside ones had clouded over. these current ones were cheap ones from repco but they didn't last.
then got the car ready for OS drag day in 2020
