Showing content with the highest reputation on 04/27/17 in all areas
Spent some time on the weekend with the help of @kempy with good results. Some of the stuff I remember: Changed one-way valves on injector pump, cleaned points, bled injectors, replaced injector, adjusted fuel regulator to 110psi pressure, cleared return line, adjusted overfuel lever, replaced 6 (yes 6) totally dead spark plugs, re-timed and marked ignition, swapped distributors, lost all the hair on my arms and temporary hearing whilst fireball from backfire on intake gave @Geophy and @Threeonthetree a good laugh (possibly due to me holding a can of engine start that was also on fire) and then started car. Next steps - sounds like slight miss on one cylinder but no cooling system plumbed in, so, reinstall radiator, tweak, and do skids / road test / fix all the other stuff I find broke. Finally making progress = win.11 points
Well sorry guys. I never did update this thread, Needless to say it all went swimmingly And I managed to get it all wired back up. I never got to see it start up, as I had to go on my bike trip, and they had to do a service on the motor, Bike trip was epic, way more epic than fixing a train. But fucked train paid for the trip so yey for fucked trains Apparently it started first try with no wiring faults. So pretty happy about that. Especially since I was a month under best estimate and 4 months ahead of what they expected. It's back in for a service (I got a permanent job out of the cab replacement, and doing a bit of servicing and fault finding to the coaches) So work for them full time now. Any way. Here's some pics Yeah so that's it, It's also taken out some other retard who jumped in front of it, but they went under the murder train so no real damage.7 points
There were a couple of mx5s at zebra so I grabbed the cv bolts and the diff input bolts so hopefully they are similar enough to work on the fc so its less sketchy. I also have sorted a load of wheel nuts so there will be more than three holding the wheels on. Its a bit early but does anyone have a set of r32 gtst wheels for cheap? I've seen a couple on those wheels and like the look if them. This one on tardme looks pretty sweet imo7 points
7 points
4 points
sounds like you need to rock around there with your hands on your hips mayte.4 points
I wondered who these hipsters blocking up my hood with cameras were. Can lend the 91 Volvo 240 for the cause. Edit- working on photos, computer is doing a dumb - Blue Renault here currently, Morris is street furniture even now in NZ, Volvo very 90's (having grown up in that area in 92, all the cars in the background should be from the seventies. The newest car in the neighbourhood was an 89 Falcon. Just my 2c)4 points
4 points
4 points
So this is what happens when I’m on Trademe at midnight…. I accidentally the whole motorcycle. Yup, once again trademe is to blame for this. This had been on my watchlist since it was listed, with a low start reserve. When it came to the day it was closing, and the bidding was still really low, I couldn’t help but watch and see what happened. Sure enough, being midnight, no one was around to bid. One person had set an autobid, so once I exceeded that, it was mine. The photos showed a complete bike, and one that didn’t actually look bad. The seller had this to say I had a skid on this and got spooked, so it ended up sitting in the yard until the registration lapsed. It’s was running when I parked it up, but has been sitting so long now it’s probably only good for parts. So, so sad So yes, the rego is lapsed, and it hasn’t been on the road for 4 years. Apparently it last ran 2 years ago, but not since. It’s also been sitting outside this whole time, and it’s taken its toll. This is the photo that caught my eye It’s a pretty cool looking bike. So, what is it? It’s a 1993 Yamaha FZX250 Zeal. It’s a JDM only (except for a few late-model ones released new into the Aus market) high revving four-cylinder, four-stroke bike. It has about 40hp, 6 gears, and a slightly more upright, relaxed riding position. Despite what my better half says, it’s a fairly small bike but should suit me well. I finally had the bike transported from another suburb, to my house today. I couldn’t do it myself as my only car with a towbar was the S401 and that’s now gone. The transporter was very good, and kept me updated on when it was picked up And when it was delivered (since I was at work) I came home after work and after getting it into the garage, had a good poke around it. The first issue was immediately obvious; either the front, rear, or even both, brakes are seized and binding. This makes it a real dog to push around. I got there though Cosmetically, it’s not bad. Some paint fade, some scuffs and scratches, and a badly torn rear seat are the bulk of it. Theres also some surface corrosion, and general grot (and lots of spider webs and spiders) A quick check of the basics was in order. Oil? Check. Black and thick, but it has some. Front brake fluid? Check, it has some, but it’s gross. Rear brake fluid? Check. Also has some, but a spider tried to come at me bro when I went to take the cap off. I presume it’s also gross. Coolant? I saw something sloshing around in the bottle, so I guess so. Fuel? Once I freed up the lock on the cap, and pried that open, yes, its half full of the most rancid smelling petrol ever. Will turn it into a 50:50 new:old mix for the mower. Free fuel, and better than disposing of it. The Mustang will love it. The tank opening had some rust (and grot), as did the cap. It’ll clean up OK though. I can’t see much inside the tank, but the fuel wasnt obviously full of flakes of rust, and what I could see in there appeared to be nice clean metal. Hopefully it’s not all rusty. Unfortunately the front forks will need rebuilding too. One seal is completely buggered, the other is leaking, and the forks are really soft. Once I worked out how to get the seat off (key on the side. Turn it one way and the helmet holder slides open and closed, turn it the other and the rear seat pops up. One 8mm bolt to release the front seat) I opened it up and checked the wiring and battery. Battery is flatter than a flat thing. Will try reviving it with my charger, but it’s likely toast now. The clutch lever has a lot of play, and doesn’t seem to be disengaging the clutch. The lever looks like its been rotated forward too. The plan? Drain and replace ALL fluids. Recondition/replace front and rear braking system (hoses appear OK, no swelling or cracking) Free up clutch and gearing Rebuild forks Remove, strip and rebuild carbs Drain and inspect fuel tank Replace fuel filter Replace spark plugs I want to try to fire it up sooner rather than later, so I can check that the engine isn’t complete junk, so I wont be doing it in any real order. Brakes, fluids and fuel will be the priority. It should be a nice rewarding project. Eventually I’ll get it back on the road, legally, and enjoy winding that engine up to the 15,000rpm redline. First things first though, I need to tidy up Scooty and get that sold.3 points
Want your car to be famous on the big screen? I've been asked if we can provide half a dozen cars for a movie being filmed next Wednesday 3rd May in Petone for a movie called Blind Panic https://www.facebook.com/blindpanicthemovie/ The cars will only be stationary props and there are no other cars being driven on the day so there is little risk of them being hit by other cars. What they need is late 80's - early 90's cars (movie is set in 1992) preferably stock as possible or with somewhat period correct modifications. Even something like your daily '91 Subaru Legacy will be fine. (or similar Honda, Toyota etc etc) Preferably NOT red though because it messes with the camera??? Your car will be needed from 7.30am till 12.00pm in Petone but you do not need to be with the car if you don't want to stick around. They can even pick up and drop off your car from you if you are busy at work on the day. They are offering $20-$50 worth of petrol vouchers if your car is not just coming from around the corner. (low budget movie etc...) There is a potential if they identify bad weather that they will be filming on Tuesday instead but that will be decided by Monday If you are interested can you post up a pic of your car in this thread and if you will need for the car to be picked up and where from. I'll send through the pictures to the director tomorrow and hopefully she'll get back to me pretty pronto with what she wants. Cheers3 points
You will be able to compensate with normal wheel alignment adjustment, but it shouldn't look like that. Id be asking for a replacement.3 points
Post Nats update: Tightened front left wheel bearing, rolled guards a bit more, installed oil, de-greased some bits, changed polarity of windscreen washer so that it squirts instead of sucks. Will remember to take pics next time. Things to do: Fix brake shudder. Still driving it lots. Weekend jaunt on some closed roads (it said ROAD CLOSED AHEAD, not road closed....) around the Clevedon coast with some OSGCs.3 points
I suck at photos. All going well this will be getting collected from its nice warm shed and be dropped off to me next week. I'll have to ask the landlord to put up another garage so I can work on my stuff at home3 points
The 130 alloys are 14"x6" and with 205/60 tyres the rears rub on the inside of the outer guard, and are quite low geared compared to the factory 175/80 or 85 series tyres. I do like the look of them tho! So had a set of 14"x4.5" factory steelies blasted by @Mr Vapour and they turned out pretty good. as collected from Burger Fule meet, good ol Mr V rattle can primed to stop flashing i ran a strip disc over the tyre sealing area and then primered them And then top coated. I used the light grey that i did the floor and engine bay with with a bit more roof white in it (not quite enough grey left!) I didnt sand them at all, but it turned out ok and they have had way more attention than they deserve already. I have some 185R14C tyres that ive been saving for this since getting them from @kiwi808 when he moved down sarf that have a thin whitewall on them to install when the paint is dry, as well as trim rings and dog dishes. Presidentiale! Should mean i can drop the front a bit to even out the nose high stance and still steer, as presently the front is wound up as high as it goes.3 points
ok, been a few days, disconected all the wiring and what not then removed the desk from the cab and of all its wiring, today all the pipe work was removed, she is now an empty shell, ready for some one to win the tender to repair the fibreglass front, (best tender so far is £25k ) have prepped most of the new cab ready for the desk, most of the airlines are in, but need to lift the cab in the air to cut out 2 x 200mm holes on the underside for the air con stuff (as if they need air-con in scotland) had to mod the floor and shit, but she is coming along, still hoping to get the desk back in by friday, but we'll see, kind of waiting on other shit to happen first, no one seems to be in a hurry, i need some earth points welded to the new floor, but the fuckers don't even have some one who can weld ali on site, so it has to be sent out to an engineering firm !!! ffs, useless no floor=no desk= no work to do but i drew a picture of a penis behind the light switch for future generations to find so yeah, might grafitti a random kiwi somewhere as well3 points
Late last year I saw a certain rx7 advertised, wanted it, talked to friends and they said get it. I made a decision, slept on it, slept on it again. Had a week away to see reason and paid for it. It is joe/goats fc3s rx7. Here is his excellently written ad & some pictures I think I'm a sucker for punishment and I'm blaming the brain injury for making another project when everything else I own needs something doing on it a good idea. And I think I like cars that people hate? No space, no money (now) a trademe rtv rebuild rotary that hasn't run properly in years. What could possibly go wrong? After a few delays I made it down to Wellington, because brain injury I can't organise a piss up on a brewery. I arrived at Wellington airport and forgot my aunty & uncles address and while working out where to go and how to get there almost forgot about my bags. Caught a train and I'll be meeting Joe soon and we'll get some more parts and see what we can do. I have ordered new plugs and leads, made a diagnostic connector and got a new coolant temp sensor in the (misguided overly optimistic) hope it may help the flooding issues. No new pictures yet but I'll try remember to take some.2 points
I kept wondering what happened with this every so often. Glad you updated it finally!2 points
Most likely seized slide pins. See if you can undo them. It's the two 12 or 14mm bolts top and bottom of the caliper. Be carefull, if they are completely seized you might snap them. Then it's time to find a second hand caliper.2 points
Just keep the date as is. People come or they don't. If we start pushing it out it will just clash with something else and you can't please everyone all of the time etc etc. Also, snow season starts soon so that's me every weekend till the 15th of October haha.2 points
100% agreed but I didn't set the parameters. However if some have some early 80's car then chuck it in the mix - I'll send her all the pics and she can make the call. Fuck it I might even recommend my Falcon.2 points
Made a bunch of progress the last two days. I'm using cam buckles and ratchet straps that I've shortened to hold things in. I'm using a cheap grommet kit so I can bolt the straps in. The kit actually works quite well, it's a little punch and a driver/anvil to set the grommet. Here is one holding my table. Got the interior in. This is the last panel to go up behind the driver's seat, these are the wires for the solar and lights. Roof to the factory head liner. Bed platform in. AC and DC plugs on the back of the bed. View under the bed, the box on the left is where the 26 gallons of water sits. Above that is the electronics. Side door View of the water pump up against the wall next to the tank. Held down with some shortened ratchet and cam buckle straps. Wish I had taken more pictures of this area but we were making progress. Switch and plug panel from the front I've got almost all of my wiring done and the inverter and solar charger mounted but I'll wait till I've tidied all the wires up to take pictures of that.2 points
Hmm good point, I don't have stock ones unfortunately (the Escort ones are just part of the strut), none of the photos of them for sale online are offset though. Think I'll go back to the guy. Cheers Matt2 points
Just quietly, I don't have any working Oldschool cars left hahahaha. So will have to arrange a ride or take one of the daily vehicles. So yeah in my opinion I'd rather have people turn up in something than not turn up at all because they don't have an old car.2 points
Because Anton failed my last submission i've tinkered with the code: Labels, scale and grid, well kinda Bench test only, cos its dark out. Speaking last night with a knowledgeable carb tuner, my initial analysis is off, word is idles sound fine, but mains are lean and the air correctors could be opened up to prevent flooding at high revs, I have a lead for some jets to try and failing that there may be a set of jet drills near by too. I also brought a LM2917 IC, this has a fancy trick of turning frequency to a linear voltage, ie give it a signal from the points and it will output 0-5V for the arduino, i've put together a small circuit on veroboard, but just need to bench test it along with an isolation circuit (optocouplers) so i don't risk getting the points running via my laptop!2 points
I dont have anything in particular to say right now, except for that I've started working at HP Academy in Queenstown. I have learned a mind blowing amount of stuff from Andre and co already. Motec M150 is just some next level shit. Sheezus. With the M150 you can write your own code for the firmware, today we were trying idea of IMAP / EMAP as a load axis. (intake manifold pressure divided by exhaust manifold pressure pre turbo) Which is a bit of a mind bender to me but apparently this compensates for VE changes etc relating to altitude and turbine efficiency way better than just MAP or MGP. Next step is to take the GT86 for a hoon up a mountain and see how well the AFR stays on target. I'm not sure if it's obvious from this post yet but holy crapping Christ. What a company to work for. The other day Tony Quinn's Pikes peak car was in for a tune before heading off again. It runs a VR38DETT mid mounted, runs two turbos > two intercoolers > two plenums (connected with a balance pipe) Looking at the intercoolers with the thermal camera we found a 20 degree temp difference left to right. Some more poking around from there and we found that one of the intercooler hose clamps was loose, so intercooler on that side had lower mass flow so lower temp. TL;DR: This thing is a fucking weapon, Andre got another 100hp out of it just with tuning. Same boost. ~950kg and now ~605hp atw with plenty of head room. Just stopped there because he wasnt sure if it will still be drivable, going to Highlands for testing on Saturday.2 points
So I did something dumb, I bought another Zephyr. I bought a VL churbo wagon that turned out to be a turd so I flicked it after a few weeks and was looking for a tidy 5L VL and then this turned up on the tard. I had a couple of goes at organising to have a look at and got mucked around so I gave up and forgot about it. Came back from a holiday with no reception and discovered that the seller had dropped the asking price significantly. Finally managed to have a look at it and ended up buying it. Its running a 302 Windsor with a C4 and an 8" diff. Modified in 1992 and on declaration form not cert. I've had it for nearly two months now and so far I've had the left hand rear sill section replaced, made and installed a speedo cable, recored the heater, replaced the brake booster, rebuilt the carby and reset the massively retarded timing as well as a bunch of other fiddly little things. Doesn't sound like that much when I write it down but everything's been one step forward and two steps back so far, if I'd had any idea how much I was going to have to do to it I never would have bought it but them's the breaks I guess. I haven't taken many photos so far as it's gotten to the stage where I just want to get the thing going but I think I'm on the home stretch now, have new springs to go in it this weekend and then touchwood I'll be able to take it for a decent drive and take a few photos.1 point
locking it in eddy. we will just have OS meats at top of remarks car park in winter.1 point
It's just like my Dad always said "be good to your Mum son and remember British cars don't work"1 point
since when do rotarys ever have wofs? just bring it. theres bound to be rougher looking cars you can hide amongst. or get a ride with us can I come if I don't have an oldschool car? unsure if ill jump in with matt or bring my own car.1 point
if a barry modifies a car in the woods, is it still a lash up?1 point
Last repair to do on the passenger side was the rear section, behind the wheels. The bog here was over 15mm thick in places. Fucken rough. As it goes with chasing rust, this ^^ soon turned into this. The outer and inner skins were rooted where the dirt and shit had been sitting for years. New inner skin was sused. Then the outer was made, including around the back behind the bumper. And before it was hit with the rattle can. Short story, the passenger floor annoyed me so I replace the entire lower half of the van. Tomorrow I'll put it back together and drive it for a week before I replace the drivers rear wheel arch section. When is enough, enough?1 point
Those accessory belts would have gone for another 50,000 km. You should have seen the alternator belt on my old FX-GT, it was fucked from the day I got the car but I couldn't get the P/S belt off without excessive butchery due to previous butchery so I just left it on and did 60,000 km before selling the car. As for the clutch, if the engine is out of the hole on those cars it is silly to not replace the clutch unless it is virtually brand new as it is a huge job to get to it. A TGP clutch kit would probably be about $150? Hopefully it will be back up and running soon, I like your car.1 point
Six months of wof all used up. Had a good four months use out of it. Had next to zero issues in that time. I had to swap out fuel filter when it starting running like a bag of dicks after getting fuel in Hahei and had some tyres fitted in Auckland after the tread disappeared. That's it! According to the speedo I've put 6000kms on it in that time (I'd say it's closer to 5000 though). I took it to Leadfoot and then to Rotary Reunion in February. At some stage soon I'll put some new shocks in the front and lose some height. I've got some clips sitting in Sydney to put the sill trims on and yeah I'm fairly happy with it currently. Pics Courtesy of Snoozin Courtesy of MichaelJFox And a pic of the daily cos it's too new and boring for a thread. JZX110W with a 1JZ-faeces, 18x9/10 work emotions and BC BR series adjustable coilovers.1 point
Just a small update. Been putting the car back together. Gave all the windows a good clean, got them looking crystal clear. They did have tints on them but they were quite rough, so decided to pull them off and clean up the glass. Also been doing more upholstery, almost completed the seats, but ran out of material and thread. I tried covering the dash in vinyl but gave up. Iv glued up the cracks and put a textured finish on it, and then painted it, its come up good.1 point
failed hard, cant get bolts out of cross bar. yeh the towers look ugly from the top, but wont see them once done v21 point
Picture time. I forgot to take pictures but got some. First thing was to sort out the lack of battery clamps. Easily fixed Joe convinced me to use gasket paper instead of the ht lead box or rtv. Turned out ok We popped out to supercheap and I splashed out on some caps for the unused vacuum ports instead of using bolts and hoses. The lower rad cap was leaking and it turned out to be a split of ring, I'm too tight to pay $8 for a new one so on fitting with the theme of the motor rebuild I made this We have reinstated the idle? Motor or air bypass valve and swapped the rangi fuel setup with factory stuff. It was great having the adjustme reg so we could see the pump wasn't working properly and then the fact that the pump had 5v to it. I've written up a quick list for tomorrow, everything is easy enough except figure out why the ignition stays on even after we unplug the ignition switch. I'm genuinely surprised at how easy and nice to work on this is. Plugs have been pulled many times and we have had the manifold off heaps of times. Same with the fuel rail and injectors.1 point
Monty Checking out how grippy lol Not sure if please with his new living room ornaments.. Thanks to MM for the springs, we swapped my Original alloys for - sent them off monday morning, and received the springs along with the carbs from Japan on Thursday.. Put the springs on Saturday after work... Discuss; http://oldschool.co....ith-added-moss/1 point
