supposedly more predictable clamping force, probably pretty important on the bleeding edge of automotive performance, probably less so in an 80s mitsi donk
  • Replies 7.2k
5 hours ago, igor said:
Is there any engineering benefit to the use of TTY bolts?
Not really - but the bean counters love them as you sell more parts.
That was my first thought too. Thieving roguing bastards.
"Compared to conventional type bolts, torque to yield bolts
offer the engine manufacturer a number of advantages including; greater flexibility of
design, reductions in component costs, more accurate assembly and reliability of seal.
Engines designed utilising torque to yield (TTY) head bolts require fewer head bolts to
achieve the desired clamping loads than those using conventional bolts. With fewer
bolts the engine manufacturer has more flexibility in cylinder head and block design as
well as reducing the cost of the engine."
  • Thanks 2
Batteries,
Just dropped a new battery in teh middys daily. Thought id whack the charger on, because fuck knows how long its been on the shelf at repco. Been on a half hour, and still not got the full charged light on?
I got a dud battery last year
Also they said my car was the problem and not charging it. My man, i told you I have a battery tester and the result
  • Sad 1
Relevant if it's a newer car (I struck this issue for the first time on a 2010 model): Sometimes you may need to tell the car via OBD2 device that it's a new battery, so it doesn't try and pump a squillion ergs into the new battery...
Check the label on the battery first before handing over shekels/francs/cowrie shells
There should be a sticker on it with 4 digits, iirc first two = week of the calendar it was made; second two = year.
but I’m guessing most of us already knew this
/ling
7 hours ago, Goat said:
Any of you Mitsi foamers know anything about 4g41 donks? Early 70s OHV engine in early colts.
Specifically, if the bellhousing pattern is the same as a 4g32.
@fuel @DoBro Jesus
I hadn't heard of one before. I would gamble on the bellhousing being the same, Mitsi seems to just have the wide and narrow patterns on the early stuff
Always made me giggle, our old 2005/6 E61 wagon was an IBS (Intelligent Bowel Syndrome) car and needed battery coding, plus sensors etc.
My Camry Hybrid and Prius both do not require that. Go figure.
I had to disconnect the ibs sensor in my 650i or it would drain the battery for fun...
"Intelligent"
  • Haha 1
Why do people blur their license plates in photos when selling cars? Is it still necessary to do this, or was it only really a thing in the days of being able to find out the owners info through the post office?
Can't find out owner nowadays unless you are popo etc.
