  • Replies 49
8 hours ago, GARDRB said:
I don't want to rain on your parade if you were considering using the E-series toyota box with the K24, but I talked to the K24 to E-series adapter guy that does all the MR2 kits when I was considering doing a k24 into an ae104 wagon and he said he's looked into it and the K24 block will not play nicely with the Toyota transfer case. He recommended going to CRV gear.
5 hours ago, mjrstar said:
Convert the k24 to run Volkswagen dsg, there are kits.
So looking at the DSG conversion Pic
The output does look pretty close to the Block not sure how much further the GT4 Transfer case sits out but your right it may not fit or may need to see if shaving the block is an option (not ideal tho)
The CRV AWD box doesn't have a center diff like the GT4 Box and after reading up it sounds like the front transfer case does run full time and the load to the rear is controlled by a clutch pack to the rear diff (rear diff can't handle full time AWD)
Considering I spent 2.5k on a front LSD for the GT4 box not including install and bearings etc, I am hesitant to change boxes (I could always swap back to a Bellhousing to suit the 3S again rather then the 4a) and try move it on still keen to see if I can make it work
Seems to be a 80:20 split to the rear which isn't great on the CRV box, few options for Transfer case upgrades to hold big power but also with a big price tag. Trying to track down info on what a factory transfer case will handle :s
Edit, Can't get confirmation on what power the 5/6speed will handle (talk of 400hp) waiting to find out what power the transfer case can hold, though Humble performance claim 600hp on a K series Box
Might have to go grab a box/motor from a wrecker here will see what the weather is like this weekend
22 hours ago, mjrstar said:
The golf R32 engine has intrigued me, I haven't done any real research, so it's probably a garbage idea for some reason, and is probably not ideal for high rpm, but from a capacity vs physical size, it could be alright...
it seems like a likely candidate for a +t conversion, just check out the head gasket surface area between the bores,  and the number of head studs.. (2 things not easily changed on an engine)
Snap! Have been dreaming of jamming one in the Fiat 1500..
GM 4.3 Liter V6 EcoTec3 LV3 Engine keen to slip one of these into my commodore when the 500000k ecotec dies under the turbo.
Not seen any for sale yet.
Displacement: 4301 cc (262 ci)
Engine Orientation: Longitudinal
Compression ratio: 11.0:1
Valve configuration: Overhead valves
Valves per cylinder: 2
Assembly site: Tonawanda, New York and Ramos, Mexico
Valve lifters: Hydraulic roller
Firing order: 1 – 6 – 5 – 4 – 3 – 2
Bore x Stroke: 99.6 x 92mm
Fuel system: Spark Ignition Direct Injection (SIDI)
Fuel type: Regular unleaded and E85
Maximum Engine Speed: 5800 RPM
Emissions controls
Evaporative Emissions
Bin 4 emissions
Returnless fuel system
Horsepower hp (kw)
Chevrolet Silverado and GMC Sierra: 285 hp (213 kw) @ 5300 RPM SAE Certified
Chevrolet Silverado and GMC Sierra: 297 hp (221 kW) @ 5300 RPM SAE Certified – E85
Torque lb.-ft. (Nm)
Chevrolet Silverado and GMC Sierra: 305 lb.-ft (413 Nm) @ 3900 RPM SAE Certified
Chevrolet Silverado and GMC Sierra: 330 lb-ft (447 Nm) @ 3900 RPM SAE Certified – E85
Materials
Block: Cast Aluminum
Cylinder head: Cast Aluminum
Intake manifold: Composite
Exhaust manifold: Cast Nodular Iron
Main bearing caps: Powder Metal
Crankshaft: Forged Steel
Camshaft: Billet Steel
Connecting rods: Powder Metal
Additional features
Active Fuel Management (AFM)
Variable Valve Timing (VVT)
E85 Flex Fuel
Electronic throttle control
Extended life accessory drive belt
Extended life coolant
Extended life spark plugs
Oil Life Monitor System
Dexos 5W30
Dual-pressure control and variable displacement oil pump
58x crank timing
What do these come in locally? the newer Commodores? I could have a look at local wreckers here in Ozzie land
Silverado etc
Apparently you can use LT parts on them like manifolds and lop 2 cylinders off. vvt sounds extra cool for a push rod donk. Saw a cranky one pop up on insty sounded fierce!
New (ZB) fwd Commodores have the GM LTG 2.0. turbs. Makes 191kw, and I believe they have lots of room for improvement. I wanted to put one in my Gemini, but they are pretty tall so it wouldn't fit without a fully custom cross-member and relocating the steering rack. The same engine comes in the Equinox which is AWD.
Usually a bunch of crashed cop cars on some of the wrecked car auctions.
On 08/04/2024 at 17:23, xsspeed said:
Whats a k24 do in n/a guise compared to the 2ar?
Race motor (cnc head, cams, pistons) on npd100 300hp odd (think that was at wheels too) designed for endurance racing, few $$$ involved but not crazy money.
  • 5 months later...
On 07/04/2024 at 21:21, Roman said:
1NZFXE
I think we've covered this one well enough - but definitely earns a mention.
It's a pity that available aftermarket cams max out at 264 deg / 9.5mm lift. As I think this motor would give a lot of older 1600cc motors a run for it's money if bigger cams were available.
Wins the prestigious Goez hard 4 wat it iz award.
I have been thinking about these engines, and was wondering if they Toyota Lego onto any RWD gearboxes?
11 hours ago, Willdat? said:
Just been googling
https://www.carjam.co.nz/car/?plate=Ngt954
I wonder how close 1NZ are to the 3SZ in these?
I saw this listing you may be interested in: 2011 Toyota Townace Liteace https://www.trademe.co.nz/4958079464
The SZ engines are more of a Daihatsu thing, the 2SZ is a K3-DE, which means you could probably technically turbo Townace with a K3-VET, but that doesn't help with the 1nz RWD bellhousing.
The way to do the 1NZ would be a milled and adapted J160
The Terios is rwd 5-speed manual and used K3-VE and 3SZ-VE and from 2017 (Malaysia) 2NR-VE.
Curiously the Yaris had 2SZ and 2NZ/1NZ, I wonder if they had the same bellhousing bolt pattern or a different bellhousing?
