locost_bryan
Everything posted by locost_bryan
  1. I'm keen, have to cadge a ride off someone. Then you can all badger me until I get the Marina on the road. 😀 (@Kiwibirdman, is your offer to help still on the table?)
  2. Kenworth? I made a White Road Boss back in my teens. Unfortunately I left all the models I had made at my mum's place when I moved cities, and it looks like they all got binned when she moved house (unless they got stashed in the ceiling). Another of life's regrets...
  3. Romantic Getaway The Catlins | Southland, New Zealand
  4. The Taeiri Gorge railway. Albatross colony and Larnochs Castle on the peninsula. If you've got time, head up to Oamaru for Steam Punk HQ and the penguin encounter. Head down to Invercargill for Bill Richardson's truck museum and the bikes at E Hayes hardware store. @RUNAMUCK has just been through the area, check his posts on the spam thread.
  5. Sounds like the old Classic Mini engine movement issue, solved by fitting stiffer mounts and twin steady bars. Helps to stop the diff moving relative to the wheel hubs and the suspension bush compliance effectively pushing the wheels briefly out of alignment.
  6. On my Samsung, i just use the builtin resize in Gallery. Open Gallery, select the photo, tap the pencil icon, tap the ... icon, tap Resize, select the size you want, tap Save, job done. 🙂
  7. Yeah, you're off the hook. 🙂
  8. No need for air con with a monsoon sheild, and a wagon's not a wagon without a towball to kick your shins on.
  9. Mental health fundraiser. https://www.gumbootfriday.org.nz/
  10. My dad had a '57 Plymouth Savoy with the six, sadly he dismantled it in the early 70s after he bought a new Falcon. He didn't seem as keen on street rodding it as pre-teen me was.
  11. The coalmine train was at the Cambridge show last year.
  12. Get your signwriter to do the NZ in the same green as th middle stripe, that was one of the approved variants of the logo.
  13. I was trying to work out what they used, guessing it's either Kei truck or Jimny based?
  14. Wonder if any of the small awd Japanese cars would have a strong enough rear diff? Perhaps the Swift or Yaris?
  15. Standard 8 before that iirc. More than 100bhp I'd be looking at the TR/2500 diff. Would be surprised if there wasn't an off the shelf kit for the upgrade over the years.
  16. Iirc the GT6 has the Herald "small car" diff, shared with the normal Dolomite and Marina. The Marina axle was used in the Caterham 7, the half shafts fail before the diff. The Group 2 rally Marina 1300 had 130bhp and a lsd in the standard diff and never broke one (and had class wins on the RAC and 1000 Lakes WRC rallies). The Dolomite Sprint had the TR "big car" diff, plenty strong iirc. @VitesseEFI will be your font of knowledge. 😊
  17. Mag and Tyre Direct | Mag Wheels | Tyres | Auckland | NZ Wide 245/50/16 Falken Tyre Model Number FA245/50/16 PRICED FROM $169.00 or $129 from their Palmerston North branch 245/50/16 Falken ZE912 FREE FITTING!! | Trade Me Motors
  18. I think the Six also got 165x13 tyres instead of 155x13.
  19. Someone with a Marina Six parts book could check the speedo part number, but it will be different because of the higher 3.70 diff ratio.
  20. Certainly, sort out the distributor, then check the carb isn't worn, which can lead to air leaks around the spindle and so on. Have a read of @kws's Marina thread, he had issues with his HS6 iirc.
  21. Try this Needle Comparison Chart | SU Carburetters This one talks about needle options for Minis with various carb setups, including single HS6 SU Carbs - Quick reference needle selection (for Minis) The EA71 is very short stroke, so BMC/BL long stroke stuff using single HS6 may not be much help, however the Austin Maxi 1500 and 1750, B-series 1600 and 1800, and O-series 1700 might give some ideas of needle options.
  22. That's wicked, seriously jealous of your skill (and patience).
  23. You're right, Shell SAE 40 oil. The poster of a guy on an electric guitar would date it at least late 60s, more likely 70s, looks more like Jimmy Page than Jimi Hendrix.
  24. Not to mention those plastic fuel cans.
  25. Sounds like you're setting yourself up for a beating from the audiophiles...
