If I wanted to change the wheels on my certed car with the old data plate cert, is it a full recheck or $50 re plate fee or something in the middle or both? LVVTA website says this but I can't quite make sense of it.
"The fees charged to a customer for LVV certification are derived from the time it takes to carry out the LVV certification inspection(s), fill in the required forms and form-sets, and prepare the associated documentation, which will be in the region of 2.5 hours for the more straight-forward certifications like a seat and seatbelt installation, through to 4.5 hours for a Targa car, plus in every case $270.00 for the certification Electronic Data Plate fee (subject to change), or $50 plate fee for a wheels and tyre change only certification (on an already certified vehicle), and additional consumables including stationary, courier, telephone, and travel expenses."
Too many damn commas in that sentence. Data plate currently says OE wheels, was hoping it would say 17x7 40p or whatever so I could swap to something else of same spec.
Edit:
just found this, my exact question:
"My car has been certified for coil-over shocks but on the stock wheels. Now I want to change my wheels. Do I have to get the car recertified?
Yes, you’ll need to get the car recertified, but providing that all other modifications match what the vehicle was originally LVV certified for, you can get a partial recertification for wheels and tyres. Simply give your LVV Certifier a call and let them know what you want to do. The cost is up to the LVV Certifier to determine as it will depend on how much time is involved in the inspection and LVV certification process"
  • Replies 10.1k
So I was reading some fancy documents somewhere about having to have sliders if your seat had sliders from the factory unless on an authority card.
I have a Racetech that I was wanting to use as a driver's seat in my car, the belt seems to sit pretty happy if run through the belt holes in the sides of the seats and all is hunky dory except for the height of the seat on sliders. My thighs and the steering wheel end up in very close proximity for ingress and egress, past the bolster and it seems much safer if the seat just sits on the seat subframe without the slider.
Is the slider a complete non-negotiable and should I just stick to my Recaros?
Illegal
If you take a typical jap ute, and remove the body to use to put a pre 50s body on it, do you keep the plates and tags to that chassis, or is the reg process stay with the body?
seeing as most pre 50s bodies are usually deregd.
I think it becomes scratch built
Opinions wanted here, back story my neighbour who's a top chap but buys the worst cars...... has bought himself a lovely Mercedes just stuck it in for a wof needed a tyre upon taking wheel of found the wheel bolts in this state.
He's been quoted $3.5-5k to replace all the hubs yup they're all like this.
My guess someone bolted.5x114.4 wheels on a 5x112 car by just ugga dugga the shit out of them till tight
What can he do other than hubs? That'll pass a wof.
I would recommend he re-taps all the hubs, plenty of cutting fluid as you go and a new set of wheel bolts. More often than not with the wheel bolts you'll ruin the bolts before the hubs
99% of time at work fixing said issues from similar stories will fix, and torque to spec
He's bought new bolts already he'll spring for a good tap and try that first he was pretty gutted. Hopefully can avoid new hubs as that is 300% more fucking around than needed.
It's getting towed back from WOF shop to my place to look at.
Planning on cutting the bump stop mounts off and plating over as coilovers have their own stops and need clearance, thoughts?
That would be fine, but
Whenever changing bump stop position or length,  you need to make sure that there are no things like arms fouling the body, tyres hitting the body,  or joints binding because the suspension is operating in a different range of travel than the original design
Bump stop type, location, and setup is one thing that is very common to get wrong, a lot of people don't understand what the bump stop does and how important it is
  • Thanks 2
