SiRge
Everything posted by SiRge
  1. Pretty sure you can use first gen hrv stuff like this guy with the bonus of 5 stud (B series turbo optional)
  2. Giz a hoon g 😇
  3. Yea going to do some hidden bits first and if it turns out alright, continue with the shown stuff, but otherwise just buy a kilo of 0.6 I did a little course in welding to get done techniques down and they covered some things panel steel things, so hopefully not going in completely blind
  4. Did the same on recent sale, can confirm pretty good so far. Have only done 2-3mm steel for the moment but does what it says on the packet. Using 0.8mm wire, so looking forward to starting on panels soon
  5. So you're the sadist who's cars at Steve's shop. I do wonder how he keeps that place afloat with Fraser and Josh there storing equally long builds there (I mean, not as long as Steve's Escort....) but hey, you're in good hands at least. But anywho, I see someone put a k24 in a lotus with an e153, so I assume your application is plausible too.
  6. There's some case law somewhere about that. Something something if the incident wasn't caused or contributed by a thing that would fail a WOF then you're covered still.
  7. I've never heard of Bilstein or Koni shocks not passed with perch sitting on a single circlip groove in all my decades in hondas. Always easy to argue both brands are able to be sourced from repco etc as OEM replacements. I've heard of people failing when there's multiple grooves as those are not OEM grooves and there's concerns over if that was suitable, and I've also heard of Wofs being a visual inspection and electrical tape strategically used 🤭 Hondas have different perch heights too, like the DA Integra one is flat perch because it's longer spring and EF civic is a 1.5 inch tall cup perch. So me swapping out the DA perch onto my factory EF shocks lowered my car by 1.5 inches. Was it legal? Dunno. Do I continue to be a degenerate? Yes
  8. Meeting next Thursday 27th at 6.30pm at angry chicken petone /Woolworths car park (see pic below). It's under the nzhondas banner, but you know, car community spirit is dying a bit and I'm trying to revive it without charging $10 at the door like others... All welcome, doesn't need to be Honda etc
      • 1
      • Like
  9. I wouldn't bother going through Police, pretty sure there's a check box on the Motor Vehicle Register at NZTA. Could easily request all the information about a vehicle with information on ownership redacted. It's a 10 second query if was still there
  10. Yea did a dohc zc in a shuttle as well with no electronic issues, however even dohc zc are getting pretty rare these days too. Probably a sohc VTEC from an EK is going to be the cheapest opportunity, but the you'll still need to adapt up to an obd2 ecu, or pay for an ever-so-increasingly expensive obd1 ecu ($200-300 odd, but chippable)
  11. Ohai, I posted on your FB post today. Didn't realise you were OSer. Happy to chat through wizardry if you do want to go down the path of stupidity on engine swaps. Local friend pioneering it all is happy to share details. Cool build though, love dedication to the mundane beauty
  12. As for the rear beam, could potentially use the Honda logo like I'm using? Looks to be veeeery similar design to your civic, but with more modern parts and 4x100
  13. Cool build, I'm going to try steal your k series intake on my Honda, I think it'd be pretty good match for the spaces I have to deal with in my build. Re: knuckles, have you considered trying to get a Honda Fit knuckle to work? I'm using GD knuckles with evo 7 shocks.... With some work.... But I might be a nicer fit on yours? Taper from the bottom ball joint and steering rack worked perfect on mine, so hopefully works for you too. Bonus if you can use GE knuckles as you can upgrade to 282mm discs easily too
  14. The main problem I have with the process is they're expecting me to submit a design to get approved, but Im not an engineer (happy to fab things, but plan wasnt to do final welding myself). When I asked engineer, they told me to talk to certifier. Talked to certifier and they want me to go to design approval. Ultimately I don't want to spend $150 to go for design approval for them to laugh me away and stop wasting their time. I have all the enthusiasm for learning, but seemingly no one who's interested to teach
  15. Anyone gone through design approval process with lvvta/TAC? Ol' m8 Julian thinks my cars too modded and wants to put me up against the design approval, but aside from lvvta website not sending the CCM, the Internet seems pretty quiet on it.
  16. Phuckin sik uleh
  17. Rack in, u joint angles aren't stuffed.... Be it a touch short. Everything rotates and doesn't bind. Tried jazz axles, too long by about 10-20mm both sides, need to trip to pap and conduct some research. Passed pictures and vid to Julian cert man, so we'll see if this is going to the metal recyclers or not soon
  18. Fitting on factory mounts to see where they kinda land. Gearbox mount mostly fits. The mounting to the box bracket needs to be spaced up 20mm at least. Lots left on threads This bracket is reversed 180, used to point outwards, but this solution looks promising for a front mount Engine side looks half OK, needs a little clearancing with Mr hammer, might look for other options though. EG civic half size seems to fit vertically. Outlets ideally need flipping. Top needs to be to the bottom of the picture and bottom needs to be in the middle. Wondering if I can flip an alloy radiator and swap the fill neck... Hole in strut tower temp drilled so I can line up the evuk 7 shock on passenger side. Next up is steering rack, passenger knuckle and maybe drive shafts? Still keen if someone wants to come have a nosey in Wellington, I'm quite over my head here but continuing on regardless Discust below, https://oldschool.co.nz/index.php?/topic/49007-sirges-1972-honda-n360/
  19. Is there anyone in Wellington who's familiar with the cert process for engine/subframe swap (a bit more than a bolt-in affair) who can come over and point out anything I might need to do before I pay for a certifier to come. Currently the engine etc is mocked up and the idea is to get certifier in to tell me how they want it put back together, but I dont want them to turn up and point out all these dumb things I haven't thought about yet. Figured you lot are smarter and more handsome than me which might help
  20. Pm'd
  21. 200hp?
  22. She's touch wider than what Honda built I think
  23. Engine hanging in there, tighter than a nuns faith
  24. New wheels (13x5 from CA Accord)
