Showing content with the highest reputation on 07/23/16 in all areas
7 points
6 points
Oh, and the other day Rob/slpery86 dropped in for a visit, we sharned and then went for a spirited tour of the local driving roads, it was rather enjoyable.6 points
Shit vid of me making a cunt of myself at Nats track day.5 points
Granddad spec 1962 Super snipe purchased a few months ago. The 'ol Slumber is reasonably advanced for '62 with power assisted front discs, a hemi'ish head that makes casual observers by think there is more than one cam going on. Drive is through 3 on the tree. Plenty of torque - she can be left in top gear most of the time and pulls from pretty much standstill to motorway speeds. She's no lightweight track car though. 15ft 8" long, 1544 kgs and an oil change will take 15 pints or 8.5 litres. The paint looks like it's possibly house enamel, so I expect 40 seasons out of it, which is good as it has the usual 'nice from afar, far from nice' thing going on. There's minimal rust as the old boy I purchased it off seems to have sorted most of that out. Interior is glorious red stuff. Possibly leather but unlikely and lashings of walnut veneer. Picnic tables in the back for tea parties / lines of Raro etc. Since I've picked her up I've done a few things which I'll blog about with photos in the near future. So far : - Changed to negative earth so the pixies run the right way for radios and stuff. - Given her indicators on a stalk rather than the toggle switch that was cable tied under the dash - Found the horn relay (this took a lot of time...) and made it all horny - Re-upholstered the front seat to stop all the foam falling out from underneath and my ass sitting on the frame - Fitted a stereo, speakers and a sub - Made head and air come inside the cabin other than from that of the engine - Made it run on 6 cylinders - rebuilt the fuel pump Few other items on the agenda. Probably won't be slammed as it's quite nice to full her with 6 people and go for a cruise without loosing the exhaust. So, watch this space.4 points
Couldn't find any front brake rotors the correct size, the smallest I could find was 226mm diameter ones whereas I needed 205mm ones. So we made a pattern and got some cast and then machined. Installed them today along with new pads and wheels bearings4 points
This is the first time since nearly forever the gorge has been open when I have a chance to use it.3 points
Patch work quilted up the original down pipe with a section of pipe with a joint already in it, welded the other joiner end (and some patches) into the parts car exhaust, and installed it. i installed the fuel tank from the parts car after a clean out and the sender from the original tank the other day so as its now down off the stands and away from the wall, I also connected up the fuel tank/pump piping in the engine bay incl with a filter but i have to get some gas and remember to prime it to see how slow and boring it sounds now */*/*/* Also cut my very first rust section out of the parts car for the very* last** rusty area on the project car. Rust traps! I wish i could say thats all done but ive got a few fiddly patches to make one good one out of two and a lot of careful measuring to do yet! Check out this area in behind the valance/bumper mount/radiator support. One bonus is its going to be easy to sort this properly with all the other bits out of the way. Guess which one is the parts car3 points
Also like most of these wagons the rear wipers have been removed...am a fan of the dual wipers. have got some new wiper arms from Toyota, but the actual part that holds the blade are no longer available new... I bought some generic type that are supposed to suit a camry wagon, but they don't fit, will have to get a pic to explain it better, bottom line is I need dual rear wipers,,,,,2 points
last time I was back in NZ I pulled it out of the garage and gave it the clay bar then hand polished treatment..I have sourced a wiring diagram so will be getting the windows etc working. Also on Japan Yahoo I found the red missing badge for the boot lock latch ...2 points
Went round the mountain but never actually got to see it. Typical Taranaki.2 points
Getting a few small jobs done over winter. Wanted to build a new front diff mount as the Datsun factory setup is a pretty crap design that allows the diff nose to lift under load. I had hacked a factory mount up and doweled it (essentially making it sold mount) but that was not overly ideal so had another crack at it. Thanks to Mike for the idea on this style. Cut up the factory mount and built a jig to keep diff aligned. Welded in steel tube that fits a poly bush I had floating around. All mounted up. Holds the diff nice and solid with no lifting issues and also makes diff easier to remove as just slide out the main bolt. Next job was the exhaust. The car came with a nasty old press bent 2" system that I have always wanted to get rid of. It hung way low and looked shit. Decided to go with a 2.5 inch system which is way overkill for my engine but what the hell. Hoist makes this job 1 billion times easier than trying to do under the car. I wanted it tucked up as to the body as possible. The system that came with the car only had 2 hanging points and was one piece so wobbled like crazy and was a mission to get on and off. New system is to have multiple hanging points and be 3 piece to make removal easier. The headers I stole from Craig had a reducer taking the outlet pipe from 2.5 to 2 inch so I simply cut off the reducer and added a 2.5 inch flange to match the rest of the system. Started with a small straight through stainless rear muffler and added a angled tip that looked OK. The rear muffler has 3 mounting points so it is nice and solid. Then worked my way forward, trying to keep the piping as close to the body as possible Went with a basic straight through resonator mid system. Once happy with the layout I added flanges so that I can take out the middle section of exhaust to gain access to diff etc. Then cleaned up and painted, knowing it will burn off 30 seconds after starting the car. Came out OK and sounds better than the old one so I am calling it a win2 points
The brace I made to hold the motor in 1 place worked very well And the new cross member works well and uses all of the shelf Toyota mounts. Also a plus to see everything else fits back on. I bolted a set of leave spring back in and mounted the difg and it 2 fits....just need some long u blots now so I can make the blocks once its all back together. Slapped a 10" wide steelie on but it wouldnd clear the calipers but I think with the right size offset I will be able to get a 10" under the rear gaudes.2 points
much fucking around waiting for parts and changing my mind on things has resulted in it still not going yet. however the motor is in the car for permanent (this time round) and the only major bit I'm missing at this point is the intake manifold. so, whats been done? modify and strengthen the gearbox crossmember mount to bring it up to current cert regs head has been hardness tested, cleaned and reassembled with new stem seals. valves re-seated and stage 2 BC cams fitted. powerhouse racing pulley kit ATI harmonic balancer titan adjustable cam gears gates blue cam belt NZ EFI ultra high output coils with built in igniters other things. the block came with no engine number so i thought id better put one on it so i can identify it if i need to for whatever reason. 2016-07-13_05-58-18 by sheepers, on Flickr 2016-07-13_08-41-27 by sheepers, on Flickr 2016-07-13_08-43-57 by sheepers, on Flickr 2016-07-13_08-44-10 by sheepers, on Flickr2 points
Made an arduino based carb balancer using an aliexpress pressure differential sensor, took all of 5 minutes to balance the dells Bar graph just tracks left or right depending on the pressure differential between the two inlets which are hooked up to the carb throats.2 points
Project Uterus Picked up a solid old Courier/B series ute today from Ashburton. Was used as a farm hack, but overall it ran and had a fresh Wof and reg. Asked the guy what he wanted for it and $850 i was driving back to Chch. The steering box was super sloppy and i had to battle to keep her straight, good fun! I think its a 1.8 backed by a 4 speed. Anyways.... Someone welded a power bulge to the bonnet just to show what a powerhouse this thing is Interior was sweet usual kind of wear for a farm hack Looked behind the seat and found te woodys.... All in all good little score. No notable rust spots in the floor pan, a few small pinholes but all good. Once i strip the house paint off the cab it might bring up some uglies... Plans -Wellside -Fix up interior -Tighten up steering box -Strip down cab -Reupholster bench -Steels and caps -Good dose of low J-W-G1 point
Cheers bro! I pretty much do as per this guy, but nowhere near as good. http://www.build-threads.com/build-threads/thai-kombi-restoration/ tap tap tappetty tap. Hammers, cold chisel and other formers (sockets, bit of wood, anvil, vice) to suit. The finish you get is a function of the time spent, and many small taps is better than a couple of big ones. But Im a rough cunt and in a hurry Basic process is/was: mark out sheet. pay attention to the edge and inner bends of the indents. These ones have a flat base so need two bends = 2 lines (inner and outer) Preferebly on both sides, but esp on the side you will be hitting (denting) - i didnt make any allowance for 'pulling in' on the floor panel (ieally it should stretch the metal at the indent) but smaller bits might be best to leave a bit extra on the edges to trim afterwards set up the vice to open to the width of the outer line, and with a chisel head hammer or ball peen slowly hit along the inner line keep going up and down slowly forming the bends, the hits on the inner line pulling the metal over the vice jaws into the indent once you have a nice indent, flip it over on an anvil and planish the piece up to the outside edge. lip it again and planish the base of the indent to the inner edge repeat steps 3-6 as required. I formed the radiused ends and flattened off the base nice and even with a socket. The trick i reckon is taking it easy on the hammer, tappy taps are the way to go, keep tapping and flipping it then it will just happen.1 point
Wasn't easy to find another 90 degree fitting for the catch can as being 'Merican they're NPT, so I bought a BSP elbow from Hayes... Machined the barbed end off the NPT straight connector, fitted inside the trimmed elbow, and soldered them together... And it plumbed in quite nicely. Seem to have misplaced the rocker cover grommet but it's somewhere in my pile of bits... And started on the plug wires, tried different layouts with the old leads to check neatest solution... Fitted the connectors to use as a guide to cut leads to length... And done, I'll tidy these up once the timing is done properly. Only problem making leads was I left it halfway through to play footy, and the boots got stuck on the leads as the dielectric grease had dried. Bugger of a job sliding them back onto the connectors... And had a win at Supercheap today, shot in to grab some Penrite oil as it's full zinc for the break-in. Was 25% off and I had store credits, so pretty much scored $60 of oil for $20. Sweet...1 point
Got a floor, all the windows and a door now. Door swung first time too, must have done something right ?1 point
Sounds easy enough. I wouldn't be suprised if the seals are fucked, as I don't think enough oil came out to make up that volume......1 point
sooo close to the end now been doing a whole bunch of tidyup stuff thats not noteworthy after a talk with webber specialties he gave me some jetting advice on, when the carb was on blizzos car the jetting was 55 F8 idle F11 emulsion tubes 125 mains 170 air correctors his recommendations had the full setup but 50 F9 idle jets F16 emulsion tubes 150 mains 180 air correctors this was about 190$ worth of changes from nz and well that was just a bit too much for me this week so i got them in from the uk 105$ and was here in under a week I had had a hard starting issue with the new plugs from cold and a stumble when blipping the throttle and i couldn't tune it out, after talking to a friend that is much better at tuning carbs than me he asked my why i was still running my vac advance and that that could cause my issues with the stumble and just set it at 10deg at idle , so I changed my old plugs back today and found I hadn't tightened no4 so that is probably the hard starting issue haha . So today I removed the vac advance and tgb lent me his timing light and it was pretty much bang on 10 deg needed to wind in a bit more fuel as it was popping a bit so that was fine idling at 1100rpm quite fine (it isnt that smooth with the cam under that ) and the throttle response is much better than before . I have a lambda link afr gauge and a copy of a bosch lsm 11 semi wide band sensor to go in that ive had kicking round for years . so here is the result of todays efforts1 point
Its a zc cylinder head so from the same family as original, meets criteria does it not? I think hes pulling ya leg or someone is pulling his, they never came DOHC from factory. Rarest would be the shape before this 84-87 Shuttle GT with fuel injected single cam EW5 engine. There used to be one around town here but havnt seen it for a while1 point
Nah DOHC swap shouldnt need cert, same engine series, same cc, same aspiration, same mounts, not much more power. Chassis plate should say it has a zc, engine is a zc. Win1 point
From memory AEG offer 6 year warranties on tools and 3 years on batteries. That's impressive. DeWalt is only 3 years on tools and 1 year on batteries. Makita is 30 days on tools and 30 seconds on batteries.1 point
Makita seem to have the biggest range of tools that can all use the same batteries. I don't have the need to spend tradesman dollars so I have gone with Ryobi one+ and find it excellent. Made by same company that makes Milwaukee. I have 2x 1.3ah batteries and 2x 5ah batteries, about 6 tools that use them. Probably all in for under $800.1 point
I should add that its super handy, like change your life spec, to not have to manually undo/do up every bolt1 point
Gave up on the eagers, even though I said I wouldn't! So got me some sweet 205 whitewalls. Got wheels sandblasted and painted silver.1 point
How about another run to the private museum in Takaka? That place is fucking epic!!1 point
Bit of a shit day rallying. Ran a bit wide into a tight blind left hander from top of 3rd gear. Turns out there was already another car in the same spot. Bounced into gutter which tipped us on the drivers side and slid into the back of their car. Rear tail light came through windscreen. Next step is to figure out how far we need to go to fix it. Will be getting a new cage but not sure how much of pillars etc is usable. First crash. Definitely a learning experience. Fun times. Will upload some videos later in the week of some of the good bits.1 point
Have finished off my custom rocker cover. changed my design slightly once i was made aware i was not going to be able to cnc router my original design easily. still more than stoked with the outcome. this more or less concludes the amount of tidying up in the engine bay im going to do. bar some little thinks like paint strip and polish the oil cap, and try do something about the choke cable cutting across the engine now it has the nice cover. ill probably re tape the loom once its gone through cert and i dont need quick access to anything. wouldn't mine getting rid of the blue on the head at some point, but ill leave that for another day. the adapter for my new bosch coolant sensor arrived today, so i can fit that and actually have the ECU read a usable coolant value. not really much else to do i think before i roll it down for cert. link to discussion - //oldschool.co.nz/index.php?/topic/30375-flibois-1971-toyota-corona/page-71 point
What's up old schoolers. I almost biffed the 618/616 gearbox X member - glad I didn't as it actually can easily be made to fit s4/5 rx7 gear boxes. The RX2 gear box X member is a short son bitch and the RX2 mounts come very close if a s4/5 box is fitted. I blasted it up yesterday ready to mod and paint. It's good to use as it has mounts already there attached to the chassis rails (616 not RX2) Next - header fab time. My mate knocked me up these headers - soooo stoked. I will be ordering the Adrenalin R resonators x4 and a dumpy soon. Watch this space. My mate has a jig for making a hilux diff suit RX2 - flanges have been laser cut and are now on the diff. Next step is to cut diff and mock up with wheels axles and brakes under my car to make sure it fits. It's going to be close. Next - making my RX2 struts fit the random Honda Odyssey fully adjustable units. My mate lathed them apart and interference fit them together = press fit. Tidy job and I owe him some bourbon!!! Top fella This is the original rx2 strut next to the new adjusties Hilux 6 stud axles are now turned down to fit the FC rx7 brake discs. Not the old holes haven't been filled....I was told that heating the hubs is not a great idea. There is loads of meat for re drilling 4x110 and this will get done when I get the axles cur and resplined. I want to have an extension added to the centre of the hub so that the rim can locate...how? Do I need one? And finally....I bought two of these off eBay as they are old from the 80s unused and cheap1 point
I needed some nails so I put together this nail reclaiming machine to salvage some from all the pallets lying around Porirua1 point
Check the contact pattern to confirm its close enoughness1 point
Another angle of the sill closing shenaigans, also showing the outer sill less the end cap. No wonder they rust out here. 3 knife edge plug welded seams (triple thickness) all facing the rear of the tyre with a couple of pockets to collect grime. Just like it lest the factory... With the door off i can remove the rest of the sill and clean up everthing a bit sill outer test fitted to size up the end cap (i forgot to allow for the lip that plugs to the inner sill! ) a bit extra added to the patch including the end cap, mostly buzzed on and first grind back not bad! The fender on this side is a replacement , im guessing a fender bender based on the gobs of leading i melted from the repairs in the bottom front valance1 point
R154 was about 3K so not much difference in price to their listings on TM. would i still recommend swan? well, yes. I'm pretty fucked off with parts of the process but i can see where they are coming from and why things had to happen how they did. they are going to get reparation from the mongrel piece of shit that stole it so they had to document everything in a way that could stand up scrutiny in court. the third party mechanical assessor is the person who needs a fucking bullet. he "was a mechanic for years mayte so i know what I'm looking at" but i reckon theres a really good reason he's not a mechanic anymore. would you put a motor back together with a second hand cam belt? would you use a second hand clutch throw out bearing that had obviously had some serious abuse? especially if its going to cost you twice if you have to remove the whole engine to replace it if its fucked? lts of shit like that that really boiled my piss. was that swans fault? i suppose not but they did have the option to take precautionary measures with the mechanical damage which they chose not to. if anything goes wrong with the abused parts that i have been forced to reuse you can bet ill be nominating the most expensive workshop in this country to do the work required to replace it all and that will be solely at their expense.1 point
Pulled the remains of the exhuast off the parts car, wasnt expecting much, but is acutally in pretty good nick (after filling a few hioles) and has a stainless back box, so that will do for WoF. Now that the towing is done, time to remove what little structual rigidity existed in the front right quarter... this is what i looked like before: After my treasure more than a couple of spot welds to drill then i will start adding new steel back in. Like a complicated jigsaw puzzle where you get toi make the pieces. Im going to rebuild the sill to strengthen it up again before removing the floor panel and heater cross member itself. The jack is under one of the cross members to ensure the door still closes nicely!1 point
got this old bus running again after buttoning up the cooling system, and fitting the tow bar Then backed it out in to the sun for the first time in aaages. leetle bit of rake! will hopefully come down with interior etc installed then proceeded to pull the parts car out of its spot (which is over a bit of a hump and slighlty down hill) with it. YO DAWG! I HEARD YOU LIKE 2300 WAGONS SO...etc I had to get Mrs Azzurro to drive the tow car while I 'steered' the parts wagon (by kicking he wheels, as it has no steering box or steering wheel!) and controlled its forwards momentum with wooden blocks. Seems a shame to put an exhaust on it, but in other news, she said she likes driving it So now its in reach of my air hose and extension cord its dismantling time Unfortunately when emptying the boot out (so i can remove the fuel tank - the one that came in the nautilus has a massive dent in it,) the pane of spare hatch glass smashed lucky i have two more i guess.1 point
So are you saying this isn't a Ford Capri with a pursuit 170 + blow through carb on it??? These pony cars all look alike to me!!1 point
You should have fitted a British engine. In fact you should have bought a British car full stop. Then they wouldn't have started it and upon trying to run away slipped up on the oil slick and knock themselves out against the proper British steel panels. I hope you have learned your lesson.1 point
Note to self - make underground carpark with steep as fuck driveway. Like 45 degree shit with a hidden winch at the top to get your cars in and out. Those crooks would never work it out lol On serious note - had accident with 120Y when with Swann and were awesome, even let me pic the panel beater and all. Hope you get paid for man hours - your the only one that knows your way around the thing and hopefully it doesnt take too long.1 point
Also, bonus stolen pictures for no real reason. Thanks to those who's pictures I've nicked Regards, VG.1 point
Started giving the SSRs a tidy up.They had a bit of curbing on the lips and the clear coat had pitting in places. Should have sent them off to a polisher but thought i would have a crack at doing it myself. Split the centers and barrels Stripped off the old clear coat with rubber stripping disc. Then jacked up the back of the datsun and used as a poor mans polishing wheel. Bolt on wheel, throw in 3rd at idle and work your way through sandpaper grades. Stripped back the flaking paint of the centers and resprayed gunmetal. Also repainted all the cap screws black. All done and bolted back together Came out Ok for a rangi home job. Tyres going on this week fingers crossed.1 point
Attempted to make the engine look a bit tidier. Sent a few bits out to be re-plated, still waiting a some stuff to come back. Painted block and a few other bits Removed sump, stripped and painted then threw back on With motor looking a bit better time for it to get back in the car Replaced some small stuff like leaky oil pressure sender and exhaust studs as old ones were shot. Still waiting on a few parts to reassemble the carbs. Mounted fan on radiator. Still need to get piping to plumb it in. Trial fit the rangi strut brace I hacked together and it looks to clear everything ok Start on wiring this week.1 point
