Showing content with the highest reputation on 10/02/17 in all areas
much work over the weekend mott came round on saturday and helped a bunch finishing welding up all the exhaust stuff that I had fitted up and tacked togethe,r while i worked on the thesis for my turd polishing doctorate. not only had the good old boys bo and luke of north taranaki been trying to emulate randy campbells greatest ever stunt and bashed the crap out of the fuel tank, it had some epic corrosion paint coating chemistry going on which took several hours of wire wheeling to remove and find out what specification colander i have. Im guessing the combination of the rustpaint protective coating and the holes being on the top of the tank meant no one ever noticed previously. anyway got all the paint and rust and shite off, cleaned and treated the rust. will have to cut and weld and patch in the top and the one pit hole in the bottom and some of the dents will get sorted with the fitting on the sump. also made up a frame and and brackets to mount the tank and got all that done. will get onto fitting the sump and repairing the tank next. PS thanks again jack ma, can vouch that these all in one drillytappy things with impact driver hex drive are astonishingly better that what i expected actually work awesome10 points
9 points
I was looking forward to driving it to work the other Saturday cause my work car is boring, but when I did it was flat as fuck, boring and generally disappointing. when I got home I put the timing light on it to find it had moved a little, so tightened. Needed a warrant so I put a standard carb on, so it had choke and wasn’t a jerk to start for them. hosed gas into the engine when you shut it off. pulled it apart and cleaned it, did the same thing. then discovered the power valve actuator was frozen up Freed that up and it was mint, but The morning of the warrant it started doing it again. passed with a clean sheet! Was a totaI knob to start afterwards so I hotwired it and wouldn’t rev out, popped and banged, so chugged it home. They didn’t mention it doing this to them so she must have behaved. more of the same. Have since thrown the twin carbs back on. it pulled a bit under brakes so I ripped the other caliper off (did the opposite side before last warrant) and: one Piston was a bit scabby so used a spare and got it back together, cheers to mint16 for the bleeding help! cheers also to the above for making my sweet rocker shaft spacers. likely overkill but it’s a cool old school mod which replaces the springs with a brass bushes to stop the rockers moving laterally under revs I also modified the mazda air box a while back so the bonnet closes over it. required me to cut most of the base, push down at front and then fill the pie-cut section with panel steel. and found out the hard way that if you leave the key on while you go check something else, it can get ultra hot,produce a lot of rank smelling smoke, drip Brown shit out of it and fail! Lucky I had a spare generic one, cooked one was a GT40. I have a new one, but I’m planning to go electronic dizzy soon so needed to be a non-resistor type. Heres a shot of the current state of play. I used to have the fuel line running over the rocker cover into a tee, but discovered that the factory hard line will reach with a little bending. Much tidier and safer.7 points
7 points
7 points
7 points
Sorry but yeah this is a sign that your engine is completely dead.5 points
Made a start on the bed over the past week, first thing was to remove all the old brackets and supports. They were a bitch to remove since they were spot welded ever 150mm or so and you couldn't see where the spot welds were, eventually got there after doing 1/4 of them each day after work. Decided to put the c-notch up through the deck because I think they look terrible with a raised deck with hardly any depth. After that I made up a frame out of 40x40 box section that fits on top of where the original wood would of sat. That means the deck will be about 40mm higher than standard, which is good because it will hide all the rust/corrosion behind where the old brackets were removed. Need to sandblast/paint where those brackets were and everywhere below the box section and fix the rust up the front of the tray. Was thinking of making the whole deck lift up so you can access stuff underneath it, but I couldn't figure an easy way to do the hinges. Then I realised I only really need to access the airbag stuff and the fuel tank so I'll just make the back third lift up. Made a mock-up in Solidworks to test how the hinging works. The pivot point needs to be above the wooden boards so that they clear the c-notch panel when it lifts up. Seems like it works well, can lift up to 60 degrees before it hits.5 points
4 points
A bit of further investigation shows no signs of stress on the underside or the valvetrain. This chunk obviously decided it'd had enough... But it's hard to know why. Also had this massive box arrive from Amazon: Which contained my new muffler. It's no wonder their shipping was so expensive! I chose this because it's 3". But also because my neighbour has the same on his K24A DC5 Integra and it sounds great. I've also got the matching 3" resonator that I'll probably make removable so it can be added if the car's too loud at Pukekohe etc.3 points
Pulled the head off and will send the bottom end to the rebuilders this week. And I noticed this very strange bit of damage while inspecting the head: I have no idea how this would have happened, but there's a substantial piece missing from the face of the bucket. There's no signs of damage on any other buckets either. The cam appears to be fine aside from a small wear pattern visible in the above picture. I'll get a DTI onto it to make sure the cam is straight and will replace the bucket. Has anyone else ever seen this?3 points
applied maths and string theory zing they see me chooching3 points
everyday turn more steel into dust unsure exactly where I want the exhaust to end so cut it a little long and will see how it looks when its on its wheels. put the turbo kit back in temporarily to check fitment and of course needed to slit most of the joins to take the pipe strain out so everything will play nicely. will put the guard back on and make the hole in that while its all there3 points
thems some holes in my tinfoil hat Ah well, at least its clean inside2 points
Is that your shed up the back of your old house? Get a chain trencher and drop some neutral screen cable in the ground. Best in the long run. Can do hookups for good pricing.2 points
Turned left after doing a bit more reading. Made front mounts and a trans mount. Assuming I have all my measurements right, its in the middle, and I have about 1.3 degrees slope on the 1st section of driveshaft which is where it needs to be according to the interweb. Im swapping the rear end to a 12 bolt, so I can set up the pinion angle. Been pretty productive really ! All just tacked together at the moment. Everything is just sitting there in the photos, need to drill a few holes and bolt it all up. not 100% happy with the trans effort and may rejig it a bit yet.2 points
Went for another wee spin last night, found a dark wall and adjusted the headlights, so now they point at the road, not the sky. Also adjusted the steering box, feels much better, just needs alignement me thinks, still a bit vague and twitchy. Rear end feels good, amazing how much of the road surface transfers though the car, from the rear end it would seem, might be the ride height I guess2 points
Hey, if it devalues the street enough i might be able to get into the housing market2 points
and I'm basing it on this build from the www.Avenger.co.nz Forums have also just been informed about uprating the rear Cylinders to match otherwise risk them being over worked anyone have any better info or specs to match? Application will likely be Track based activities for the Racecar & less Gravel / rally2 points
Today my flatmate (mott) and I drove in to the Kaingaroa forest around the Rangitaiki area of SH5, then along foresty/public access roads to Murupara. Few side adventures to drive up/down things and along a river for awhile. Good day, got a new personal best fuel economy on the drive back, 15L/100K. Lowest I've ever seen it. We saw this abandoned building in Murupara, it had a real bad vibe about it.2 points
Over 1.1mil views, doubt there are any 3s hilux vids with that many views...2 points
Some people know, even though I've been all about keeping this on the downlow, but it's now time to make it official. I swing both ways, in fact I am properly batting for the other team now, well at least until I rekindle my old relationship... ...behind the wheel of my Commy. That's right, I've bought a Ford. Gah the shame of it all. So, after pulling apart the Commy last year for rust and consequently fucking around for the entire Wag-off season, I realised in November that it just wouldn't be right to turn up to Wagnats in a non-wag of the olden days variety. So I begun the search for an XD Wagon which frankly has always been a dream to own. I found a good looking beast (although it was an XE) in Gore, so I got our friendly southern gentleman Mr Old Man Southern himself @kyteler to take a lazy look for me. He came back with a reasonably positive report and heck I went for it. A few phonecalls, emails and PM's later and it was on a transporter to me in Wellington, turning up right before I went away for New Years. But still I was trying to keep it quiet until Wagnats for a surprise wagcessory. I was pretty successful at keeping it quiet, except for a drunken moment with a couple of jokers where I spilled the beans out of sheer excitement but I kept a lid on it, at least until @Aladdin drove past my lockup for the 30 seconds I had the door open to roll inside my new wheels and the bugger saw it. Luckily he didn't quite grasp the gravity and the rumours didn't go very far. So I bought it and while it was on it's way up to me I snaffled me up a set of Tridents from Hawera and picked them up when I went that way for Bizzo and Lozza's "engagement" party. Got them back to Wellington and the next weekend I excitedly tried them on - but to my dismay they ended up being Holden stud pattern. Even thought they were sold as "Falcon wheels" With Wagnats looming fast, I got out the oversized and seriously depleted chequebook and bought a brand new set of 8" Tridents off the Tard. A few days later I had them and some tyres mounted up and the car was finally rolling (oh yeah the guy sold it sans wheels and had sent it up on 4 different wheels, some held on with barely a thread holding the wheel on. They ranged from a 8"wide 12 slot to a stock Hiace 14" rim and a 16" EF Falcon XR6 mag wheel. Anywho, the car was now rolling and a week before Wagnats I snuck the car under the cover of darkness to my wheel alignment man, I hid it at his workshop for a couple of days and then stashed it at my house, away from prying eyes (my lockup is the entire other side of town) Wagnats rolled around and it had it's debut. Won "Mintest Wag" and Strokers Choice. Both of which I was pretty fucking stoked to win. I've done fuck all to it other than give it a bit of a birthday in the servicing department, got all the wheels pointing mostly the same direction and threw on a set of 14x8" Tridents. It is a solid 7.5-8 out of ten in the body (had a bare metal respray a year or so back) and looks like they did a good job, including all the shuts etc. Running gear and suspension etc is a really good 8-8.5 out of ten, very very little in the way of bangs and knocks when driving along. The motor goes grouse now and the transmission does what it needs to do (oh yeah - this wee puppy is bench seat & column shift.. shit yes!) Where it all falls down is the interior. I give it a 3-3.5 out of ten. It's all there (mostly) but half the trim has been broken or screwed back together with wood screws and what have you. The front bench is pretty fucking poked too and is supported by a towel or two wedged into the exposed springs - nothing a car seat cover won't hide for now. That's OK though, I can slowly accumulate all the stuff I need to renew the interior at not too great of a cost and then once I have it I can chuck it all in for hopefully a nice tight insides. It was hilarious getting rid of the rubbish all through the inside when I got it, an empty bottle of classy Chardon was jammed under the seat and random Waikato and Speights bottle caps strewn throughout. Good ol Gore pisswagon living up to it's heritage. I don't even remember doing it but managed to drunkenly procure a set of 9" Tridents one night recently. So those will be tidied up and go on the back, then I want to find a pair of 245-50-14 Eagers for the front and drop the front spring an inch or so too and add an 1-2 inch lowering block in the rear and I reckon she'll look the part for a bit. Anyhow enough numbers and letters. Here is a couple of snaps I took tonight after the monthly meet. It's still filthy from Wagnats and the back has some freight I picked up tonight. But it gives a nice start to the project. I reckon it can only get better. Your pal Seedy.1 point
https://www.aliexpress.com/item/1-4-Hex-HSS-High-Speed-Steel-Thread-Spiral-Screw-M3-M4-M5-M6-M8-M10/32687876380.html1 point
WTF a KE16 as well? Giz! No actually if he wants to sell or you come across a 16 over there please let me know!1 point
Put a bung in that bunghole. On a whim decided to offer up the spoiler. Got it in about the right place and marked holes for drilling, but will hold off until I've painted it before I go there. Along the top it's going inside a box section, so will be sealed and riveted on.1 point
sweet deal now its good to take to pureora rub all the panels and break off the other mirror1 point
Keen to try dishwasher, just need wife to bigger off for awhile what about a honda gx160 or robin ex21 stationary motor filter?1 point
Had a bit fun playing Datsuns thisavo. Nice avo sun and a box of beer made productivity a little low. Did a little picking around bits which looked like bog on the blue diesel. probably wasn't such a good idea. Spent a bit time trying to get the brown petrol to run. Gave the points, rotor, and cap a clean which gave me spark. Checked it had oil pressure and rigged up an electric fuel pump. It didn't want to go on its own but I could keep it running with engine start so needs the carb cleaned. I also gave them all a squirt with 30 second spray and wok away to try kill the lichen. It will be interesting to see the effects. I'll give them a waterblast in a few weeks.1 point
Finally have a bit of an update on this build... My tyres showed up from America so they went on and did some test fitting. Reverse Cragar's all day long. The standard offset set looked weak. It's pretty much ready for vinning, I brought in some suspension parts (tie rods, bushes etc...) but they supplied the top arm bushes instead of the lower arm bushes I needed. So vinning has been put on hold for another few weeks.1 point
I got the van back together yesterday, and drove it around today dropping off some parts for work. A few minor issues to sort, but it runs really well! Anything more than half throttle from a standstill will turn 2 of the 4 rear tyres into tyre smoke! The power steering is fantastic, although a bit "pointy" now, I will fit another castor wedge in there to try and help with this. The new big bore stainless exhaust sounds so sweet, not too noisy when you are cruising, but has a nice deep bark when you put the slipper in! Still need to fit the evaporator into the heater box and connect up the air conditioning, but other than that it is basically finished. Super happy with it! A few pics of the finished product: The pulleys run really close to the radiator fans! I also fitted a smaller pulley to the blower to up the boost to 10 psi Roll on OS drags Mk5! Big thanks to Muncie for the loan of the blower pulley tool Mk3 power steering box, with hybrid Mk2/Mk5 steering column: I needed to make an extra auxiliary wiring loom for the engine, and fitted relays to the headlights, and horn while I was at it. That is 7 micro relays, 4 mini relays and 16 fuses! I tried to make it look as "factory" as possible, so moved the battery tray to the RH side, and fitted the original airbox (which I had to modify a little bit) to the LH side.1 point
Sooooo, I may or may not have got a little carried away while browsing Yahoo auctions for r30 parts... It all started when I found this: And it quickly escalated And as a bonus (which I didnt realise at the time, the side skirts have rear corner caps too! FIZZING! they should be here in a month or so! Unfortunately now I cant afford any wheels... Would people hate me if I ran widened steels for a while?1 point
So long time no update. Have been chipping away at the minor things over the last year to get this thing closer to being road legal. Not too many things to go to get legal but have been working on getting it track ready for this Octobers Jerkfest track day. Finally got the Bride Brix mounted up and sitting at an acceptable height. Also picked up a TOM'S ECU - makes a fair amount of difference to mid range torque compared to factory ECU. Also removes speed cut and up rev limit to 8400rpm. Found some new/old stock Pioneer parcel shelf speakers. Got around to undersealing the whole bottom of the car and also made up some driveshaft loops. Also painted the gearbox crossmember and shortened the studs on the runner mount. Also managed to do a few more bits like fitted rear the swaybar, bought some Direzza ZII Semis, fitted AE86 accelerator pedal. Did Cambelt,Water pump etc also. As it sits currently: So the list to get it legal currently stands at: - NSDT cert for the front struts - Fit new speedo pickup - Fix rust spots in doors - Replace seat belts - Fix hole in rear muffler - Align Headlights - Do skids (oh wait, too late) Im aiming to drive it to Leadfoot this year so I better get cracking!1 point
All the shit out of the way, ready for the RB conversion Wasn't the easiest, but wasn't the worst. Tidy up time. Getting it back in will be interesting.1 point
They sure are a pleasure to drive off road, spent a day wombling around unmaintained forestry tracks the other day in air conditioned comfort.1 point
Those things are remarkably capable off-road. I had one exactly the same. They crawl, and wade well. They didn't put the alternator right up the top of the engine for no reason yiou see. They put it up there so the cabin computer still had electricity, and as they put that under the driver's seat it was the first thing to go bang when you got wet ankles. Oh the horrid dash rattles, blend flaps, aircond, air suspension, electric brake booster and cylinder liners though. Kisses1 point
Nah fail, it was better but no full secondary's. Pissed about with it all afternoon but never got there. I noticed the dizzy wasn't advancing so I put mine in, tweaked the feet of the secondary's so it's just about touching the primary's actuator. pulled the diaphragms off and they checked out, put back on with some sealant on the gaskets. I though maybe the airbox might affect the vacuum situation so I also sliced the bottom of the air box, pushed it down to where it cleared the bonnet and filled the gap with panel steel. Didn't get to test drive it but didn't seem to change with free revving on the spot. A keen mate decided I needed mirrors so went and scored a few from some wrecked Cedrics, I made a pair from the best of them, cleaned up well. Stoked with the look, sedans look best with rectangles as opposed to round sporty ones. were now cooking up some 13" wheels so I can utilise the golf shocks and lowering springs I got a few months ago. likely have to reset the leaves too but it needs to come down. I like the current wheels but they..aren't 13s1 point
Jason managed to turn my "buck" (read: bucket and piece of wood) into a part that will hold the filter and funnel air towards the air box. the filter fits like a glove! Test fitted with some big hose: Gave it a wash and a paint. I didn't want to sand it too much because I hate fibreglass dust and don't have any masks at home, so it can stay rough . The setup has turned out good enough for now. I'll re-visit everything next time the engine comes out.1 point
So that means don't out gl5 into anything with a warner synchro? LIke all A series, ca18, rb, Sr have brass synchro rings. funny how you think newer shit is gonna be better. might switch back to DOT 2 as well lol.1 point
