1 hour ago, jakesae101 said:
Those tohatsu pumps were great but jesus they were the loudest thing ever during training we had to wait to fire them up until mid morning as not to wake the neighbors. This is a racecar tho it needs a wajax pump….
The model with the Sachs rotary?
  • Replies 1.6k
Would dearly loved to have seen the helmet double take as this flew by (ext LR cam pleeeese? :grin: ). Would totally suit a set of Mad-Dog Pizza livery (I'd pitch in for that).
Good to see the bump stops doing their job. Car looks great on the 13's Dave!
Pity about the water pump. Time for external jobbie? or run twin water pumps so if one fails it switches over? lol.
Cheers, I'm stoked with 13s, it all worked out awesome.
Yeah waterpump is a pain alright. Id switch it back to a mechanical pump if it were easy to do on this motor.
Water pump: I could make you a little clip on widget to look for V spikes at that part of the loom? (just a Zener running into a small R which is likely to blow with a generous voltage excursion)
Little L brackets between underside of wing and the hatch. And some riv nuts near the leading edge.
@h4nd one theory my dad has, is that since theres no alternator on the factory engine, the 12v supply is highly regulated and stable. So I might just be running it outside of what its designed for in that regard. But the data sheet for that capacitor shows its susceptible to both heat and vibration, so it could also just be a 9000rpm thing.
Interesting. How much current? Could loan / find you a DC/DC converter to keep its supply clean.
I'm no electrical engineer, take this with a grain of salt, I'd have thought the vehicles battery would do a very good job of smoothing voltage across the entire vehicle? or @Roman do you think even the increase to 14.5v during charge is likely too much of a fluctuation? If you need more smoothing just throw in a small bank of capacitors to take out higher frequency oscillations
Nah battery isn't quite enough. You can hear your ignition through your AM radio.
Bit of potting around at risk components is a legit idea, probably already done by Toyota though.
We cut our crystal failure rate after ultrasonic welding by thirty just by potting them first
Also, I'm not an electrical engineer so don't take everything I say for gospel
I still think a ESC from a RC car / drone is worth investigating haha
No idea if they'd actually be compatible with the motor, but I don't see why not, pretty sure they're just a regular brushless design.
Rc escs get their control signal as a pwm from the receiver so a link ecu should be able to drive one no problem … water pump controller $250+
Rc 200amp esc - $60-80 …
That's the exact pump that my engine uses, but since It's not connected to a factory ECU then the diagnostics isnt the same.
I guess the good news is that I know what the issue is, and some ways to hopefully resolve it.
