tortron 63,975 Posted November 10, 2020 Report Share Posted November 10, 2020 for what trans. summit racing and (iirc) rock auto has them they are like $2usd Quote Link to post Share on other sites
Nominal 56,355 Posted November 10, 2020 Report Share Posted November 10, 2020 26 minutes ago, tortron said: for what trans. summit racing and (iirc) rock auto has them they are like $2usd C4 BNT didn't have Type-F fluid either. Disappoint I wanted to fire up my 'running' flathead to show off to the Morrie Club this weekend, but don't need trans fluid all over. Quote Link to post Share on other sites
Nominal 56,355 Posted November 10, 2020 Report Share Posted November 10, 2020 Bargain! 1 Quote Link to post Share on other sites
tortron 63,975 Posted November 10, 2020 Report Share Posted November 10, 2020 morrie club? set a peanutbutter jar over the end with a hole in the bottom. collect oil in a pan, pour it back in when finished 2 2 Quote Link to post Share on other sites
AllTorque 41,682 Posted November 10, 2020 Report Share Posted November 10, 2020 Rubber glove and electrical tape works too. I have seen those trans plugs in nz before, just can’t remember where. Quote Link to post Share on other sites
AllTorque 41,682 Posted November 10, 2020 Report Share Posted November 10, 2020 https://www.qualitytools.co.nz/transmission-fluid-retaining-tool-p-6557.html https://www.waihyd.co.nz/toledo-automatic-transmission-fluid-retaining-tool-1363669 https://www.supercheapauto.co.nz/p/toledo-toledo-transmission-fluid-retaining-tool/SPO1352687.html Quote Link to post Share on other sites
Nominal 56,355 Posted November 10, 2020 Report Share Posted November 10, 2020 11 minutes ago, AllTorque said: https://www.qualitytools.co.nz/transmission-fluid-retaining-tool-p-6557.html https://www.waihyd.co.nz/toledo-automatic-transmission-fluid-retaining-tool-1363669 https://www.supercheapauto.co.nz/p/toledo-toledo-transmission-fluid-retaining-tool/SPO1352687.html Thanks Rogee, name is the key, Do you reckon they would work when the engine is going and tranny is in Park? Quote Link to post Share on other sites
AllTorque 41,682 Posted November 10, 2020 Report Share Posted November 10, 2020 As long as the output shaft isn’t spinning it will be fine. Fluid level may not be that high anyway. What about trans cooler lines? Are you going to loop it? Does the starter bolt to the trans? Quote Link to post Share on other sites
Nominal 56,355 Posted November 10, 2020 Report Share Posted November 10, 2020 3 minutes ago, AllTorque said: As long as the output shaft isn’t spinning it will be fine. Fluid level may not be that high anyway. What about trans cooler lines? Are you going to loop it? Does the starter bolt to the trans? Yeah, I'll just clamp a bit of hose on the cooler ports Need to block the speedo drive hole (as I found out last night while lifting it) 5 1 Quote Link to post Share on other sites
yoeddynz 22,113 Posted November 14, 2020 Report Share Posted November 14, 2020 You've built your Morris v8 subframe and mounts already. I'm impressed! Some black paint and you're done. 4 1 Quote Link to post Share on other sites
SOHC 10,710 Posted November 14, 2020 Report Share Posted November 14, 2020 On 10/11/2020 at 19:24, Nominal said: Bargain! Apco has F type fluid and it’s a fraction of the price than anywhere 1 Quote Link to post Share on other sites
SOHC 10,710 Posted November 14, 2020 Report Share Posted November 14, 2020 Is that a Hydromatic or a C4? Quote Link to post Share on other sites
Nominal 56,355 Posted November 14, 2020 Report Share Posted November 14, 2020 31 minutes ago, SOHC said: Is that a Hydromatic or a C4? C4. Quote Link to post Share on other sites
ajg193 9,226 Posted November 16, 2020 Report Share Posted November 16, 2020 Anyone else notice up to 10% difference in fuel consumption between chipseal and asphalt road surface? Could be a good way to get a nice virtual Dyno boost @Roman 2 Quote Link to post Share on other sites
Roman 13,893 Posted November 16, 2020 Author Report Share Posted November 16, 2020 10% is quite a bit of difference It's easy to test though, do some coast down tests in neutral and look at decel rate on both surfaces Quote Link to post Share on other sites
ajg193 9,226 Posted November 16, 2020 Report Share Posted November 16, 2020 Here is some data for a Volvo (brick): I feel like for something significantly more aerodynamic the fuel consumption numbers would be affected far more by surface roughness Max difference at each speed for that graph: 50 km/h : 3.6% 60 km/h : 7.2% 70 km/h : 7.6% Quote Link to post Share on other sites
ajg193 9,226 Posted November 16, 2020 Report Share Posted November 16, 2020 https://eapa.org/wp-content/uploads/2018/07/fuel_efficiency_report.pdf Quote Link to post Share on other sites
Yowzer 33,822 Posted November 16, 2020 Report Share Posted November 16, 2020 Run bigger tyres. Problem solved. Quote Link to post Share on other sites
ajg193 9,226 Posted November 16, 2020 Report Share Posted November 16, 2020 Talking about tyres, I'm gonna get a new set on the Starlet today. Out with the fantastic Yoko A539s and in with hopefully good Falken 912s Quote Link to post Share on other sites
Carsnz123 4,002 Posted November 17, 2020 Report Share Posted November 17, 2020 How anal does one need to get as far as tyres go on a street car? like as long as they don't slip in the wet like Super Meows or are noisy and mushy like Hiflys, you're golden. 1 Quote Link to post Share on other sites
