SOHC 10,727 Posted September 27, 2020 Report Share Posted September 27, 2020 3 hours ago, kyteler said: Giz one of your flathead V8s How about a Morris minor flathead? You could braze 2 of them together 1 1 1 Quote Link to post Share on other sites
SOHC 10,727 Posted September 28, 2020 Report Share Posted September 28, 2020 Picking up a new ring gear on Thursday so I cut the old one off 2 Quote Link to post Share on other sites
tortron 64,053 Posted September 28, 2020 Report Share Posted September 28, 2020 That's brave of you to do before getting sent the wrong part 7 Quote Link to post Share on other sites
SOHC 10,727 Posted September 28, 2020 Report Share Posted September 28, 2020 1 hour ago, tortron said: That's brave of you to do before getting sent the wrong part It was more to stop me using the old one, this way I can never can turn back. i have been playing musical pressure plates for a few days but now I have slung one down into the bush so I don’t think about using it. 2 1 Quote Link to post Share on other sites
SOHC 10,727 Posted September 28, 2020 Report Share Posted September 28, 2020 I might start a bold thread on this 1 Quote Link to post Share on other sites
SOHC 10,727 Posted September 28, 2020 Report Share Posted September 28, 2020 Actually fuck it I cannot be fucked 1 Quote Link to post Share on other sites
tortron 64,053 Posted October 8, 2020 Report Share Posted October 8, 2020 1kz landcruiser should i bother seeing whats wrong with starter motor or just get another one quick google tells me it might want solenoid rebuilt, but ive not seen it yet other than being told starter not working *to clarify its never been off road, so im unsure if this is something that happens to these starters and just needs cleaning out, or if its more likley to just be worn out Quote Link to post Share on other sites
AllTorque 41,693 Posted October 8, 2020 Report Share Posted October 8, 2020 Usually they need the two brass contacts replaced in the solenoid. Easy to do. Replace the plunger as well if you are not a tight arse. 2 Quote Link to post Share on other sites
AllTorque 41,693 Posted October 8, 2020 Report Share Posted October 8, 2020 1 Quote Link to post Share on other sites
tortron 64,053 Posted October 8, 2020 Report Share Posted October 8, 2020 nice, il tell em i got a replacement one and pocket the change. are the kits available on the shelf locally, i gotta drive an hour to get to it and dont wanna make a bunch of trips Quote Link to post Share on other sites
AllTorque 41,693 Posted October 8, 2020 Report Share Posted October 8, 2020 2 hours ago, tortron said: are the kits available on the shelf locally Call your local ripco / auto sparky 1 Quote Link to post Share on other sites
UTERUS 18,564 Posted October 8, 2020 Report Share Posted October 8, 2020 Yee don't be tempted to braze some more marmite on there, I tried once. 1 Quote Link to post Share on other sites
tortron 64,053 Posted October 8, 2020 Report Share Posted October 8, 2020 waaaait, now i am tempted. 1 Quote Link to post Share on other sites
MaxPower 1,218 Posted October 11, 2020 Report Share Posted October 11, 2020 hey guys i brought this turd tonight for a couple hundy, it blew up on the way home (wasn't testing top speed at all when it stopped working) is there a bigger engine and manual that go into these for cheap backyard style? low km so worth not scrapping 1 1 Quote Link to post Share on other sites
igor 12,781 Posted October 11, 2020 Report Share Posted October 11, 2020 Does anyone have any good ideas for freeing up a stuck spark plug in an aluminium head please? Went to check the plugs on my Civic and three came out easily but the other one resisted the application of moderate force. Didn't wale on it really hard as not keen to risk breaking it or stripping threads. The three plugs I did get out were better than expected given the mileage and operating conditions of the engine (lots of short runs and almost never getting warmed up properly) but would like to replace them all anyway. Quote Link to post Share on other sites
M.H. 6,142 Posted October 11, 2020 Report Share Posted October 11, 2020 Soak with penetrative fluid and get the engine nice and hot 1 1 Quote Link to post Share on other sites
tortron 64,053 Posted October 11, 2020 Report Share Posted October 11, 2020 Do that But being you Igor, I'm certain you have some alum sitting on your preserving shelf. Alum in hot water will dissolve steel but not aluminium, so you could slowly corrode it out Quote Link to post Share on other sites
igor 12,781 Posted October 11, 2020 Report Share Posted October 11, 2020 I did give it a spray with CRC 5.56 in the first instance. Will give it a further soaking and warm it up a bit then see how I go. Quote Link to post Share on other sites
Yowzer 33,853 Posted October 11, 2020 Report Share Posted October 11, 2020 Send it with the impact gun. Trust me, I'm a professional. 3 1 4 Quote Link to post Share on other sites
Mof 13,338 Posted October 11, 2020 Report Share Posted October 11, 2020 Find a tube socket that fits over the ceramic but sits on the metal of the plug and give it a whack with a hammer. That'll squash the washer under the plug. Works for copper washers under banjo bolts 2 2 Quote Link to post Share on other sites
