Muncie 10,646 Posted January 10 Report Share Posted January 10 13 hours ago, SOHC said: Impco function controller PAT# IFC103 where would one find a replacement? https://www.fuelconversions.co.nz/ these guys are in mt eden and impco agents, be a good start. Have dealt with them before when i was into LPG cars were GC'S 1 Quote Link to post Share on other sites
kws 4,488 Posted January 13 Report Share Posted January 13 If my front swaybar measures 16.5mm.... would I go with 16mm or 17mm poly D bushes? Quote Link to post Share on other sites
Nominal 56,361 Posted January 13 Report Share Posted January 13 1 hour ago, kws said: If my front swaybar measures 16.5mm.... would I go with 16mm or 17mm poly D bushes? 16. 1 1 Quote Link to post Share on other sites
cletus 39,136 Posted January 13 Report Share Posted January 13 Battery I purchased last weekend A question for purveyors of car parts Does that sticker mean its past it's best by date? @GuyWithAviators Quote Link to post Share on other sites
Dolan 16,022 Posted January 13 Report Share Posted January 13 Just now, cletus said: Battery I purchased last weekend A question for purveyors of car parts Does that sticker mean its past it's best by date? @GuyWithAviators Means century supplied it septe.ber 2020 and repco is too lazy to get their batteries rotated by the century rep regularly. You warranty starts from September unless you keep your receipt and shit i guess 2 1 Quote Link to post Share on other sites
GuyWithAviators 8,944 Posted January 13 Report Share Posted January 13 What he said. If you didn’t use it yet take it back to repco or maybe century with the receipt and ask to swap for a newer one. but tbh irl it’ll be fine and as Dolan said warranty starts from purchase not manufacture date. 1 1 Quote Link to post Share on other sites
Yowzer 33,825 Posted January 13 Report Share Posted January 13 Oh is it year-month, not week-year? Quote Link to post Share on other sites
GuyWithAviators 8,944 Posted January 13 Report Share Posted January 13 Some makes are different or have their own hieroglyphics but century is year - month found a 19-04 the other day at the back of the shelves lel 3 1 Quote Link to post Share on other sites
Styles 1,670 Posted January 13 Report Share Posted January 13 14 hours ago, Dolan said: Means century supplied it septe.ber 2020 and repco is too lazy to get their batteries rotated by the century rep regularly. You warranty starts from September unless you keep your receipt and shit i guess Last time I was working in a parts department all the century guy used to do was swap the stickers... to be fair he did put the tester on them first. 3 Quote Link to post Share on other sites
Dolan 16,022 Posted January 14 Report Share Posted January 14 Yeah that's sufficient Quote Link to post Share on other sites
kws 4,488 Posted January 14 Report Share Posted January 14 7 hours ago, Styles said: Last time I was working in a parts department all the century guy used to do was swap the stickers... to be fair he did put the tester on them first. Lol, both places I worked Century actually swapped the batteries. They probably just swapped stickers at depot and we got it back the next week, but hey. Quote Link to post Share on other sites
kws 4,488 Posted January 14 Report Share Posted January 14 Did I do a bad thing? Did I buy cheap, buy twice? Im replacing the front wheel bearings in the TVR and thought I scored some cheap new bearings. Problem is I didnt check the brand (there isnt one on the website) and it turns out they are Chinese DSM brand bearings. I've already pressed the outer race in, so should I just send it and run them, or pull it out and replace with TIMKEN or the likes? They seems to roll smooth enough when spun by hand but that isnt an indicator of how long they will keep rolling when the weight of the car is on them. Quote Link to post Share on other sites
tortron 63,994 Posted January 14 Report Share Posted January 14 well they are already paid for and installed. Quote Link to post Share on other sites
Nominal 56,361 Posted January 14 Report Share Posted January 14 And, it's a TVR, how many miles will you be doing? 2 Quote Link to post Share on other sites
kws 4,488 Posted January 14 Report Share Posted January 14 Guess I'll just send it then. Got to be better than the old bearings which had been over tightened. 3 Quote Link to post Share on other sites
h4nd 6,715 Posted January 15 Report Share Posted January 15 Simple ways to fuck up phish scammers 1 Quote Link to post Share on other sites
Muncie 10,646 Posted January 16 Report Share Posted January 16 Haha what about Google form scams. 1 Quote Link to post Share on other sites
Muncie 10,646 Posted January 17 Report Share Posted January 17 Even more annoying is Google adds are popping up for gold buyers..... seriously fuck off. Quote Link to post Share on other sites
ajg193 9,232 Posted January 22 Report Share Posted January 22 Does anyone on here know much about valve clearances and ramps on flat tappet, solid lifter cams? For example, aftermarket camshaft profile calls for 0.3 mm inlet clearance and 0.35 mm exhaust clearance Factory profile specifies 0.2 inlet and 0.3 exhaust Will setting the aftermarket cam to 0.275 inlet and 0.325 exhaust in order to reduce noise cause too many problems long term? The duration for the cam is like 180 or 190 deg at 0.05", with advertised duration of around 260 deg. Would this make the ramps about 35-40 deg duration? Quote Link to post Share on other sites
nzed 1,693 Posted January 22 Report Share Posted January 22 If you have an aftermarket cam, why are you even comparing to the factory? Just set it to what is calls for and be happy. If you dont like a bit of valvetrain noise put the factory cam back in it and clean up after youself with your grannypanties. 4 Quote Link to post Share on other sites
