Everything posted by crash
https://electronics.stackexchange.com/questions/574825/how-do-i-use-a-12v-led-indicator-light-for-an-alternator-i-have-seen-some-on-t No doubt with your googling you will have seen something like the info in the above link, and you know to ditch the LED and fit a filament lamp. Also as a temp trial remove fuel pump line and power from ign switch. Is fuel pump fed from here as a protection should engine stop with ign on? As in a crash?
I there's an old mine cart on a farm I go to occasionally, probably same size. Next time I'm there I'll take some pics. Near Methven, Canterbury.
Anyone know torque settings for a 8mm drive shaft bolt? Front wheel drive 1989 Celica, bolts shaft & CV shit together.
Thanks for your replies. As GuyWithAviators said, theres none in NZ, 2 - 3 weeks from Japan. Amayama approx half price and shipping is cheap. How do you tag someone with the blue oblong thing?
While the topic has kinda turned to Toyota parts, anyone know where I can get a set of 6 of these? 1989 Celica I'm sorting out to sell for my son. https://www.toyotapartsdeal.com/oem/toyota~bolt~serration~for~differential~side~gear~shaft~90114-08006.html
Recently got this Oleo-mac chainsaw which goes well. Except for spraying out chainbar lube. Stripped it down a bit and found this ugly burnt patch directly under the exhaust. There is a hole approx 5mm diameter under the chrispy shit. Question, does high temp JB Weld stick/bond to plastic OK? It seems that it's designed more for sticking to steel. any one got some recommendations? Cheers
Try what GregT mentioned above. Or maybe a ferrite ring thing around trigger cable.
Cables being in line for 2m would be unlikely to cause enough induced voltage. Unless trigger is quite a bit less than 5v?
Kimjon's next money pit - BMW Airhead cafe racer build
crash replied to Kimjon's topic in Two Wheels
https://www.bikebound.com/2020/02/25/silver-wasp/ Here's another one similar I saw some time ago. My father has a 1983-ish R100RT sitting in his shed (lapsed rego) that I jokingly threatened to strip down. -
Maruia Moped Melee, 10, 11, 12, March, 2023
crash replied to RUNAMUCK's topic in South Island Region
Hi Pee Dubs, could you tell me what year this Honda is please? I have one the same / same tank graphics and am struggling to identify the year of manufacture. Frame # MD10 5000672 Engine # MD10E - 5000639 An email to Blue Wing Honda didn't help much, just told me it's a XL200FWD. Any info would be appreciated, bit of a long shot, but I would like to get this road legal. Cheers -
crash replied to azzurro's topic in Project Discussion
shit yeah -
Can you provide a link to meter(s) please
Shit yeah, read all the postings on this a while back. Ticks all of the boxes for me, i.e. Fiat, wagon, blue, 6 cylinder. Love it. Love it! -
Try google-ing Carl Salter for lots of bike manuals.
Thanks for the advice, looks like a better bigger puller and more heat.
Yep pretty sure. Sledge hammer and puller cranked up.
Yes, the threaded holes are for the wheel bolts.
Recently my Dad bought a 1938 Chrysler coupe. Pretty original, been sitting in dry shed since early 1970's. Does anyone here know how to pull of the rear drums? He's been on a couple of forums and apparently they are well know to be an arse to get off. Puller has had a few good smacks, bit of heat applied etc. Also should I put a bit of a thread on here? if so where? Cheers
What happened to this? I have been looking into these lately and wondered how you got on with this.
- 40 replies
- euro style for miles
- e21 rules the world
- (and 1 more)
Can recommend Malcom Lovett, good bugger and helpful.
More pictures please!!
Hi all, did a search and couldn't find much info on OBD readers. Want one to read a variety of cars, is there a good generic one to buy? e.g. Bosch from supercheap $280. Had a cheapo from tardme which did a couple of jobs via bluetooth to phone, but not great. Any reccommenations appreciated
What's the seat off? Would like to get one for a ride-on mower
Can confirm this, zero it first. Surprisingly accurate compared to direct connection to a Fluke meter.
