Roman
7 hours ago, Bling said:
Flaring guards not an option? Cheaper than buying new wheels like I did, to get a tyre / wheel combo I wanted. For cert anyway, which I assume this is for.
Will be rolling the guard lips but keeping the exterior factory. Haven't finished the suspension set up but the rims should be very close to the guard and I don't want any tire protruding past the rim. Have searched a few tire manufacturers and seems I can only go down to a 195/45r15 on a 15 x 7 wheel.
Need to find some pics now of that wheel and tire combo to see how it looks.
Share this post
Link to post
Here's a picture which miiiiight help.
These are 14s, Falken 195/45R14 all round
Rear wheels are 7.5, Front wheels are 6.5.
Gives you an idea of what to expect.  Somewhere in between the two.
They're almost square on the front and stretched slightly on the rear so yeah.   Split the difference?
Share this post
Link to post
Just now, weetbixkid said:
Silly Question but can you fit a BOV to an Automatic Gearboxed Turbocharged Engine?
Yep, should have one factory fitted. What car is it?
Share this post
Link to post
Yes. Generally standard petrol turbos in both auto and manual will have a bov.
Edit - beaten by the man with an au profile pic
Share this post
Link to post
A friend brought a Audi A3 1.8T 1999 Model with a AUG (??) engine.
Share this post
Link to post
Thanks for the answer!
Share this post
Link to post
It will have a diverter valve that recirculates as if you fit a bov that vents to atmosphere it will cause running problems as you are dumping air that the ecu has measured
Share this post
Link to post
Ok, i think i understood that, but just so I tell him correctly. He cant have an external dumping valve cause the car already has messured the air and will run poorly if he does?
Share this post
Link to post
Correct.
The factory valves don't last forever. If you here a fluttering noise when lifting off on boost it will need replacing. Genuine ones are not expensive
Share this post
Link to post
1 minute ago, 00quattro00 said:
Correct.
Ok cool thanks, I am sure he wanted the classic Psst style noise when he lifts off the throttle.
thanks for the help
Share this post
Link to post
It'll just run rich for a second after it has blown off. Otherwise it'll be fine.
On a manual it'd make a little pop on gear change, sometimes a small flame out the tail pipe. Looks and sounds good.
Share this post
Link to post
Could plumb back a bov post air flow meter? That what I have on my air flow metered turbo.  That way no idle issues if there is a slight leak across the seat under vacuum.
Share this post
Link to post
Ok thanks guys, I have had a chat to him, he cant drive manual due to an issue with his left foot so is stuck on Automatic gearboxes only.
He really wants the turbo sound so have passed on your feedback to him.
He is also going to fit an S2000 airfilter which is a drop in replacement for the AUG engine and is meant to give a nice 1-2hp gain.
Where would the best place to buy one? I have put a circle around the type he needs, needs to be an OEM paper one.
Share this post
Link to post
Lol.  Unless your mate is going to the effort of putting a cold air box around that filter, he's going to lose power.
It may sound a bit throatier, but no performance gains to be had in that application.
Share this post
Link to post
Just tell him to stop wasting his time.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
