Everything posted by AllTorque
Where to buy white wall tyres? (central norf island)
AllTorque replied to Vintage Grumble's topic in Tech Talk
Well, yeah. It’s in the VIRM, so just a heads up, that some AVIs might not like it. -
Shave and paint whitewall may fail a wof if any info has been removed such as size. -
@grunta & @LoLlife have used the STA whitewalls without issue. Many have used flappers with issues. -
We could keep guessing, or you could plug a scan tool in
Are the brake lights working? Maybe it doesn’t know your foot is on the brake?
Have you put it in the hole. I would have thought the floor would need chopping.
AC gas doubled a few years back when they added a big hole in the ozone layer tax
If there is a pressure switch, it will be on the hard line or the cooler/dryer. To recharge properly you will want to vacuum the system first then add the correct amount of refrigerant. There may be a sticker somewhere in the engine bay that says the gas type and quantity. Hopefully it’s r134a and not the old r12 as that’s hard to find. You really need a professional to do it properly. Probably going to cost you $300 - $400.
That’ll do it. Cut off goes the wrong way.
That sux alright. Not just a failed oil cooler or something?
So, I was on the right track.
Kinda sounds like compressor surge. Are the turbos fighting each other somehow? Is there still a blow off valve? (I don’t know what I’m talking about, just spit balling)
and the snowball begins
Yes
Please get 4 new coils. 2ZZ won’t rev all the way until they are warm, so hurry up with that thermostat. Clean your air flow meter.
Lift bolts? Ignition coil? Air flow meter dirty? Engine light on? Does it VTEC?
Can you check voltages at each end instead of continuity? A broken wire with 1 strand still touching may have continuity and a voltage drop.
Needs a third axle
Don’t need a cert to switch to flat deck/send it. Dimensions: https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-exterior/dimensions (see tables and images) You can have 4m past the rear axle.
Nah, I don’t think so.
That doesn’t look dangerous to me.
