Get it done Posted April 25, 2019 Posted April 25, 2019 Does anyone have plans for a home built car rotisserie please? Quote
tortron Posted April 25, 2019 Posted April 25, 2019 5 minutes ago, Get it done said: Does anyone have plans for a home built car rotisserie please? I have one of these Its a little more basic than the sold ones. Two hoops with a 2m ID And they sit on a large piece of C channel and roll on some boat trailer rollers. Weld some mounting tabs around the inside edge and you can make jigs to hold onto anything. Good for attaching to say suspension mounting points rather than rusted out bumper mounts. Im working on a foot brake ATM. Maybe just an additional braked caster wheel to run against the outside of the hoop. I'll probably be done in about 6 months if you want to borrow 3 1 Quote
tortron Posted April 25, 2019 Posted April 25, 2019 Great benefit of this type is you can just hang it against a wall. The double engine stand type take up quite a bit of room. You can also get some steel rims and weld some J shaped steel arms on them and just push the car in its side of you have the option To leave the suspension In Quote
Nominal Posted May 6, 2019 Posted May 6, 2019 We were out in the Holden on Saturday, got about 5km away from home and heard a weird noise, sounded a bit like a speedo cable tick from inside the car. Stopped and had a look under the hood, then decided to drive home stat. Idles OK and just driveable but much more than light throttle results in misfiring. Any guesses on what's wrong, place bets now :0 Going to start investigating now. 1 Quote
Nominal Posted May 6, 2019 Posted May 6, 2019 1 minute ago, kyteler said: Valvetrain. Yes, likely. Maybe a dud lifter then ??? 1 minute ago, Yowzer said: That is the sound of fucked Time for a 5M swap? Quote
kyteler Posted May 6, 2019 Posted May 6, 2019 Also, rocker arms have probably just spontaneously loosened. 1 Quote
Nominal Posted May 6, 2019 Posted May 6, 2019 Compressions OK 1,2,3,4,6 at ~180psi #5 is down about 140psi........ Quote
Popular Post Nominal Posted May 6, 2019 Popular Post Posted May 6, 2019 37 minutes ago, kyteler said: Also, rocker arms have probably just spontaneously loosened. Loose as Al's Mum. 11 2 Quote
Nominal Posted May 6, 2019 Posted May 6, 2019 Idles like a well oiled sewing machine.... Need a new rocker cover gasket now though. 4 1 Quote
scooters Posted May 6, 2019 Posted May 6, 2019 Just had a flash back It was sounding exactly like the seconds before when your car blows up from damage in GTA2 game (birds eye one) 2 Quote
kyteler Posted May 6, 2019 Posted May 6, 2019 8 hours ago, Nominal said: Loose as Al's Mum. Bingo. What do I win? 2 Quote
Popular Post tortron Posted May 10, 2019 Popular Post Posted May 10, 2019 Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass 9 1 Quote
Nominal Posted May 10, 2019 Posted May 10, 2019 2 hours ago, tortron said: Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass Imagine how much their bottle rental from BOC would cost! 3 1 Quote
M.H. Posted May 11, 2019 Posted May 11, 2019 The thickest I have cut is 300mm, hardest part is blowing through for the start, I had to drill a couple of holes to start from for the internal holes Quote
yetchh Posted May 11, 2019 Posted May 11, 2019 10 hours ago, tortron said: Engage safety squints Oxy torch cuts through an 800mm thick slab in single pass Surely it be easier to use a big guillotine.. Quote
