Roman
I remember the first time I met you sharning about duratorque tensioners. back before sharns were even called sharns.
  • Haha 1
Share this post
Link to post
Picked up a press brake the other day. Have spent the morning freeing it up. It's mostly complete apart from the linkages between the kick lever and press, and return springs.
Any ideas?
From playing around with some lengths of steel I have, I feel the plate with the 3 holes should have a slotted vertical upright, and the middle tab is what joins to the press to provide clamping force (because bigger arc). The further most tab is probably where the springs attach and join the small tabs on the base part of the brake.
The two flat bars where the kick pivot is mounted has me confused though as I can't figure out the top holes purpose. Possibly it has none and was just an available piece ?
Share this post
Link to post
5 minutes ago, Get it done said:
Does anyone have plans for a home built car rotisserie please?
I have one of these
images?q=tbn:ANd9GcRYGJIAGarlNK3CnlnimYb
Its a little more basic than the sold ones.
Two hoops with a 2m ID
And they sit on a large piece of C channel and roll on some boat trailer rollers.
Weld some mounting tabs around the inside edge and you can make jigs to hold onto anything. Good for attaching to say suspension mounting points rather than rusted out bumper mounts.
Im working on a foot brake ATM. Maybe just an additional braked caster wheel to run against the outside of the hoop.
I'll probably be done in about 6 months if you want to borrow
Share this post
Link to post
Great benefit of this type is you can just hang it against a wall. The double engine stand type take up quite a bit of room.
You can also get some steel rims and weld some J shaped steel arms on them and just push the car in its side of you have the option To leave the suspension In
Share this post
Link to post
We were out in the Holden on Saturday, got about 5km away from home and heard a weird noise, sounded a bit like a speedo cable tick from inside the car.
Stopped and had a look under the hood, then decided to drive home stat.
Idles OK and just driveable but much more than light throttle results in misfiring.
Any guesses on what's wrong, place bets now :0
Going to start investigating now.
  • Sad 1
Share this post
Link to post
1 minute ago, kyteler said:
Valvetrain.
Yes, likely. Maybe a dud lifter then ???
1 minute ago, Yowzer said:
That is the sound of fucked
Time for a 5M swap?
Share this post
Link to post
Idles like a well oiled sewing machine....
Need a new rocker cover gasket now though.
Share this post
Link to post
Just had a flash back
It was sounding exactly like the seconds before when your car blows up from damage in GTA2 game (birds eye one)
  • Haha 2
Share this post
Link to post
2 hours ago, tortron said:
Engage safety squints
Oxy torch cuts through an 800mm thick slab in single pass
Imagine how much their bottle rental from BOC would cost!
  • Haha 1
Share this post
Link to post
The thickest I have cut is 300mm, hardest part is blowing through for the start, I had to drill a couple of holes to start from for the internal holes
Share this post
Link to post
