4 hours ago, ThePog said:
Brush on would be ok for a lot of what I am doing...
I do know someone coming to chch in the next couple of days, what part of town are you?
Happy to flick some cash your way.
Dang, I just drove back from chch today..
  • Replies 2.1k
Where do you guys get gun wash from, and is it cheaper/better than thinners for cleaning out your guns?
also I don’t have a gun wash machine soo would an old steel pot suffice? I currently just clean parts off in a mixing cup but reckon the paint pots need a good soak.
About paint pots, do any of you use the disposable type? I’m thinking about getting these https://www.spraygunsdirect.co.uk/product/sagola-dpc400-paint-cup-kit-400ml-different-grades-available-ptdpc-400-125-ptdpc-400-190/ as they’re name brand and cheapest on that website. Aliex do them too but it’s always a risk with them.
I get 20L at a time from PBS, last a long time as you don't need all that much. About 80bucks
I have an old stainless steel sink. That drains into the previous 20L container
In semi-related paint-barry chat i have an expensive Legend house paint brush that got gummed up with water based paint+insufficient cleaning+years of storage
I bought some resene brush cleaner which is toluene i think. Maybe the same as gun wash?
i soaked the brush in that for a while and it’s brought it back to life
Hey all, does anyone have any tips for prepping and spraying textured interior plastic? I've been looking on YouTube and most of the videos seem to talk about smoothing it out first and are aimed at exterior parts like bumpers and door handles.
This is what I'm working with:
Do you want to keep texture or smooth out?
  • 5 weeks later...
I'm about to get the landy vapour blasted as it has too much bog and house paint on it. It has been an eternity since I have painted a car in bare metal and I'm not sure I have ever done alloy panels. Is Epotec primer still a thing?
I used epotec 408 on some panel repairs to the Defender cos its all I had a the time and its still sticking.
Think @nzstato had some fancy aluminium primer for his?
I’ve scored a conventional spray gun that’s been sitting for years. It’s been left unwashed for quite a while. Anyway I managed to get the pot off the bottom, it tore the seal unsurprisingly. I managed to get the needle out and strip it down to the best of my abilities. I’m assuming it is enamel as person I got it off would only work with enamel. Anyone know what I can soak this turd in to get rid of the build up? Also is the saying “you can put enamel over lacquer but not lacquer over enamel” correct? I want to use a high build primer underneath that I think will be lacquer
I don’t trust paint shops after the Vulcan paint debacle….
I soaked one I forgot about for years with durapox and enamel stuck in it in plain old gunwash, in a hot bath a couple times. Then Let it soak, scrubbed daily, and r4placed th3 gunwash in it every few days Some pipe cleaners delt to the rest. Wasn't that bad tbh
Are there any local suppliers that do inline filters/regulators that aren’t crap but not too expensive?
I have a black ridge SCA one and it’s not doing its job
May just have to order an inline single stage and one that goes just before your gun/tool at the other end of the air line from Spray Guns Direct. $100 shipped from the UK
Could come down to setup. For a water trap to work the air needs to cool a bit so having at it compressor is a waste of time. If the compressor is working it's arse off too, that will be creating more heat which won't help. If you can have the trap a decent distance from the compressor it will give the air a chance to cool a little and could help it work better. Depends how you have it setup really. I'm sure local compressor suppliers will have traps available. When I got mine from Marquip they had all the bits available. Probably just reselling aliexpress bits, but still available.
Hmm mine is about 3m away from the compressor and about 1.8m high. It’s probably compressor working it’s arse off as i don’t get water when spraying at lower pressures.
I just run my air hose over a rafter from the compressor and the water separator near the gun end. Not sure if the rafter thing does anything but makes it easy to get the hose out of the way when I'm done to hang on the wall.
Do you guys recommend removing the small filter that sits beneath the paint cup?
I saw This paint society video on YouTube and tldr he recommends a) straining the paint and b) using the fancy disposable liner systems that have a filter built in, which negates the use of the small filter.
I'm using paper cone filters but have traditional reusable cups.
