Sunbeam Posted October 31, 2023 Posted October 31, 2023 LVMP guns… ok for home warrior? 6CFM at 36psi sounds pretty compressor friendly. Quote
NickJ Posted November 1, 2023 Posted November 1, 2023 I have a cheap one, its crap. good for primer thats gunna get a sand or motivation to purchase a nicer gun Quote
Sunbeam Posted November 4, 2023 Posted November 4, 2023 On 01/11/2023 at 19:06, NickJ said: I have a cheap one, its crap. good for primer thats gunna get a sand or motivation to purchase a nicer gun What brand and price point are we talking? Total bodyshop is clearing some at very steep discounts. Italco brand Quote
NickJ Posted November 5, 2023 Posted November 5, 2023 Non branded and likely came from toolshed or similar, I find it doesn't get the velocity at the tip to atomise nicely and when I ramped the pressure up to compensate it really didn't like it. 1 Quote
Willdat? Posted November 17, 2023 Posted November 17, 2023 Polishing pads and general touch up supplies, where does the hive mind get them from? The more YouTube I watch, the more I think I can't make these deep scratches worse... Tune in next year for when I have to spray the boring daily in bed liner... Quote
Bling Posted November 17, 2023 Posted November 17, 2023 Typically an automotive paint shop for me. I find my local one is cheaper than SCA / Repco for pretty much everything. Mine is Spraystore, but if you have an automotive paint shop in town, which I imagine you do, i'd go hit them up when you're mobile again and see what they got. 1 Quote
87creepin Posted November 17, 2023 Posted November 17, 2023 Who do you guys use for 3M abrasives? I’ve got a feeling autolink supply them. I’m over using the cheap stuff edit: seen smits group do them, but I’m after 125mm discs not 150mm. Quote
rusty360 Posted November 18, 2023 Posted November 18, 2023 Yeah 150mm is the most common size in panel shop world, 125mm is more diy etc. 150mm discs normally cheaper for that reason to. Quote
Early jap nuter Posted November 18, 2023 Posted November 18, 2023 Wyatt tools do all the Rupes stuff and somtimes have good deals on sanding discs Quote
Bling Posted November 18, 2023 Posted November 18, 2023 I get all my 125 sanding discs from Spaystore (Smits). They might just not list them online. I never had a problem sourcing them and I needed a fair few for the project. Often they just had to get them from behind the counter rather than the limited options on the store shelves. Quote
cletus Posted December 23, 2023 Posted December 23, 2023 Faded/dull clear coat It has not bubbled or lifted yet but it's not far off Is there any magic jizz that restores this back to concours perfection? Or does a half decent job of slowing the inevitable march of time and deterioration? Or should I spend my time on more productive things Quote
sheepers Posted December 23, 2023 Posted December 23, 2023 You could try giving it a cut. If you're only doing the roof it probably won't take toooooo long. Pacer products super cut followed by ultra cut then a decent swirl remover and you'll be golden 2 Quote
mjrstar Posted December 24, 2023 Posted December 24, 2023 Is suspect it could be too far gone to polish, I'd probably nail it with some 1200 on an orbital and blow some fresh clear over the top. Not exactly magic jizz though. 3 Quote
ThePog Posted December 26, 2023 Posted December 26, 2023 I realised I have run out of Brunox convertor/primer, I had a ring around and it seems the only spray on equivalent is crc, does anyone rate this or should I hold out for the brunox? Quote
Bling Posted December 27, 2023 Posted December 27, 2023 Need to be spray on? I have brush on in CHCH I don't plan to use anytime soon. Kicker is would need to have someone grab it as posting it will be a ballache. 1 Quote
ThePog Posted December 27, 2023 Posted December 27, 2023 Brush on would be ok for a lot of what I am doing... I do know someone coming to chch in the next couple of days, what part of town are you? Happy to flick some cash your way. Quote
Bling Posted December 27, 2023 Posted December 27, 2023 Flick me a PM, will dig it out. I'm based in Prebbleton so south area. Not worried about coin, better it gets used than goes to waste here. Quote
87creepin Posted December 27, 2023 Posted December 27, 2023 On 26/12/2023 at 16:40, ThePog said: I realised I have run out of Brunox convertor/primer, I had a ring around and it seems the only spray on equivalent is crc, does anyone rate this or should I hold out for the brunox? I would wait, brunox is much better than crc. It sounds like you need it asap and can’t wait for a courier? Quote
ThePog Posted December 27, 2023 Posted December 27, 2023 1 minute ago, 87creepin said: I would wait, brunox is much better than crc. It sounds like you need it asap and can’t wait for a courier? Yea I have been pretty happy with the results so far. The paint shop will probably be open on Wednesday, and I have plenty to go on with in the meantime.. Quote
