On 13/06/2024 at 11:42, Spencer said:
After someone mentioned HVLP guns in here I also went down the rabbit hole of seeing what the hell they were. Turns out they are just china clones of some of the brand name guns that are known to use a little less air and have a finer spray pattern.
The main one you see is the R500, its basically a W400 clone, which with a 1.3 tip uses like 5-7cfm. I think the R500 is about the same air consumption as the W400 if you run it at 30psi with full paint flow (not the 2cfm and other bullshit you see) if you turn the paint dial down you can run very low pressure (like 25-27 psi) and get a real nice finish with minimal over spray so its a great garage gun for $$ it cost me. If you are used to big fans and decent guns (in a shop with lots of air) then its junk, but its a decent clone and dirt cheap. They have the next version up (R830 or R600) which is a kiwami clone and basically is the same thing with a bit of a different spray pattern and it looks cooler, again works well with paint dialed down and low pressure (I got them both).
These guys Rongpeng make the two clones you see everywhere sold under different brands, you can buy the original guns there. There are other sellers than have them even cheaper than the factory (my R500 was $57 shipped)
https://rongpeng.vi.aliexpress.com/store/3009028/pages/all-items.html?productGroupId=511210255&spm=a2g0o.store_pc_home.smartGrouping_2009187456512.511210255&storeId=3009028&sortType=bestmatch_sort&shop_sortType=bestmatch_sort
So yeah in short the clone china guns have got way better over the years, those are just the falsely marketed "HVLP" ones which are probably the best for the 3hp compressor crowd looking for a cheap gun that works. From what I have seen if you have more air they make decent clones of everything now SATA, Devilbiss the whole shebang, just have to wade through all the shit to figure out what is good. There is a barry on youtube who reviews almost every spray gun in the universe, he is the most barry chap ever.
https://www.youtube.com/@peteshobbies5383
Yo Spence, can you recommend me one of these Rongpengs that I can use with my 2.75hp compressor (https://www.stanleyproducts.com.au/air-compressors/2-75hp-50l-twin-stack-silent-air-compressor-sxcm27550323)? I'll be using it for spraying things black, like the underbody, suspension arms, interior, etc, and also some stuff around the house like diy shelves.
  • Replies 2k
Hey dude. I have one of these, works good but I am only doing base and clear fix ups with them at the moment no resto stuff. You might want something else or a set of tips for primer. This R500 is the common one on the HVLP youtube vids, its not a real "HVLP" or whatever that means, but its a Iwata clone that does use a bit less air than other cheap shit. Should be fine on 2.75hp, turn the paint down and run less pressure, works best that way for me (less overspray, less air use, tradeoff its slower). Think I got this rather than the genuine rongpeng as it had free shipping, there are like 20 versions of it.
https://www.aliexpress.com/item/1005005767569627.html?spm=a2g0o.order_list.order_list_main.65.3b441802SWe4lY
I got one of these adapters
https://www.aliexpress.com/item/1005005411806645.html?spm=a2g0o.order_list.order_list_main.69.3b441802SWe4lY
and these cups
https://www.aliexpress.com/item/1005005663483568.html?spm=a2g0o.order_list.order_list_main.70.3b441802SWe4lY
and these cups
Sick, thanks. I'll not be using it too much, so slow and steady suits me. What're the details for primer tips, they are different from paint tips?
Use a different gun for primer, usually something with a 1.6-2.0 tip. I can’t recommend any of the cheap local options as I haven’t used them but do use an ANI from spraygunsdirect.co.uk. Think it was less than $60.
You could use the same gun and tip but why would you, you want thick wet coats and primer is rough on spray guns
Use a decent 2k primer.. and give each coat enough time to flash off, don’t rush it.
If I'm going to buy a primer gun from there, maybe I should also buy a paint gun and max out the shipping costs. Any suggestions?
What’s your budget like? I am not the most experienced painter so can’t say too much but I use a Devilbiss GTI pro lite which is a pretty expensive entry level gun. It’s really good, forgiving and easy to use. The fan can open up really well too.
The Gunman does a few reviews On guns you can buy on YouTube, he’s pretty good. Also recommend Pete’s Hobbies channel for recommendations on the aliex guns.
tldr; devilbiss if you have the money, ANI/aliex if you are on a tight budget.
Ive been painting random stuff when im bored i did a blue with pearl keep in mind this is all spray can
i started with primer then blue anither coat of blue then i dipped my finger in the pearl and blew it off my finger onto the car then did coat of clear then pearl clear again then pearl and then did one last coat of clear to seal it in
Went full r3tard and bought the wrong rust remover product (ie, a converter, not remover) - save your money and don't bother with this shit
Rust Converter 1 litre | Mitre10
Added a horrible, difficult to remove "primer" which when I removed, was just covering up rust. Didn't convert a thing, pretty sure Spencer has mentioned this a billion times too. Should probably read labels more carefully. Anyway, got a 20l bath of evaporust running for removable parts which is pretty magical stuff it seems, crisp white metal is the result on some insanely rust pieces. Not fast, but getting the job done. Got some 2k primer and a heap of bits and pieces to make the process of repairs a bit easier/not totally bodgy.
With 2k primer and filler, is the process like this... strip steel back to "white", 2k primer, filler, 2k primer again, top coat?
FYI for those keen on evaporust but wanting to save pennies, there is this. According to the youtuber it's better, and about 1000% cheaper. I'm gonna give it a whirl as I share my workshop with a girl that makes soap, and hence can get the soda.
15 hours ago, Spencer said:
Yeah I thought it was on that guns description page but you have to go to another R500 listings.
Cheers matey!
Ok, please don't hate on me too much... but here we go.
Are there any options available for a reasonably durable single-stage colour finish that I can roll or brush on? I would like to get the Marina in one solid colour, so it doesn't stand out as such a heap of shit that it currently looks like (50 shades of different primers, and old and new yellows). I do eventually want to do a proper panel and paint, but that's a long way down the track, in the meantime I just want a 50 footer in one colour.
I have been touching up some bits with paint-matched 1k rattlecans, but it's expensive and doesn't go far. I had considered using my cheap compressor to spray the car panel by panel, but even that is expensive, and I only have my home garage to do it in, which is under the house/bedrooms, so fumes and overspray are a big issue for me (hence wanting to avoid spraying). I can lessen fumes a bit with a brush/roll solution if I do it panel by panel and it's not really airborne.
I'll probably need a primer that I can apply in a similar fashion, before the top coat goes on, just to seal everything under it. I'll be going over the existing surface with a DA to level it a bit better (or even remove the old primer).
Rolls royce would send a man around with a tin of paint, a brush,  some cutting compound and 5 packs of cigarettes and he would touch up your car by hand and polish it in till the repair was indistinguishable
You can brush or roll on any paint, a quality roller is probably the best option. There are endless videos on YouTube about getting it perfect.
I'd probably try a few thinner percentages to find the best self leveling
I sprayed high build primer on my morrie with an airless sprayer under a tree, and it went on preddy thick, but that was ideal actually.
I usually do the underside or interior floor with a brush or roller With durepox (2k) it comes out smooth, probably opt for the slow hardener. It sucks to sand when fully hardened but would seal everything nice
Borrowing a shed/yard for a weekend might be worth it. I have done a bunch of spraying outside and it's usually fine, normally do it in the morning on a calm day to avoid bugs
My white S110L had been painted by a previous owner in white with a brush and roller.
Couldn't really tell other than a few small spots of roller texture showing at the very leading edges of the front doors down low and the trailing edge of the rear door down low.
All the old cars, I guess pre ww1 predominently?? Were brush painted - its called coach painting. You can get a really good finish using enamel, usually you warm the paint to make it flow out. Check youtube for tips,eg..
probably the only word of warning is make sure your work underneath is good if you're going to come back and spray properly later, and also if you go the enamel route it will ideally need to be sanded off if you go to a different paint sytem later on like 2k.  It can remain however if your brushing you'll have to flatten it off to prime to seal up the enamel, which may not be super fun either. All doable and if you're coming back to it it's a future you problem.
I have seen "coach paint" in my travels online, but so far haven't really found any source for it in NZ? The closest I have found is tractor paint, https://www.bareco.co.nz/files-general-g71
Coach painting refers to the process. The topcoat will be enamel paint. For primer you are probably best to stick to 1k primer, brushing on is probably best avoided for primers unless you like sanding.
after fuck knows how many years of spraying things with a 60$ wellmade spray gun i finally took @Spencers advice and bought a semi decent gun from Ali.
this one to be precise,
https://www.aliexpress.com/item/1005006123473943.html?spm=a2g0o.order_list.order_list_main.12.74df1802lK0JrN
im not a spray painters arsehole but im pretty keen to use a better gun and maybe try and get better at painting things.
