Showing content with the highest reputation on 04/06/15 in all areas
5 points
sure its not stressed out? not since it was bent 10 ish mm . . . . it will be fine as long as you don't heat it up to much . . . . . Toyota steel is much better than china spec . . . . . are you lot serious? just read all of the comments and think about this for a minuet !! this is the bit that connects you to your steering . there are reasons why you don't straighten them, heat them, or repair them. its cause IF THEY BREAK YOU ARE IN THE FUCKING SHIT5 points
4 points
The guy would have the shit beat out of him? Nobody can give an accurate answer to that question of whether it would fail or not. In all honestly probably not. We chop and weld steering components all the time with drifting they get ndt'd and are accepted by msnz with the supporting paper work. Have they broken? Mine no but many have usually from impact. Its ok tho as we sign out lives away when we go out. if you get killed or kill somebody (and yes that also happens) you knew the risks so did your family tough shit. The poor guy traveling to the dairy to get milk for his wives tea didn't sign his life away tho. he infact did everything properly with regular maintenance keeping his car upto wof standard. But gets killed due to xyz breaking off some other dudes car because he thought it was ok to do so. Even tho it wasn't illegal to do so. He still fucked it up now theres a guy paying the ultimate price.... Get where im going3 points
I knew this would turn to shit. as soon as I said it shouldn't be done , I knew all the people would find some shit to argue with , make a big deal about it . turn it into a argument of what can and cant be done. blar blar blar but its the law its the law because you have to cater for dumb fucks who kill people from being ignorant and stupid . AND DOING IT WRONG! something you may have over looked , not everyone knows "how hot to make it" I didn't make the law, but its there and that is it. look at certifiers and the hoops you have to jump through to get a cert. they wont touch cast/heated/welded/fucked with. this guy asked for some help , you guys were giving him bad advice , so I said something. simple as that.3 points
more removal of the things. will get a glass guy to remove the windows i think. probably cheaper to do that than break them. no big rusty surprises hiding which was good i knew this bit was lurking not much more to come out of it. will probably make some sort of frame so i can flip it on its side or upside down to do the underneath stuff. also have to decide how to tackle the body- i might get it properly blasted and primed. im going to fix the rusty bits myself but i will give it to a panelsmasher to get it straight and paint it. also been looking at other mods im going to do engine wise- current plan includes a new exhaust, might use some of these or similar, they are for a dodge truck. turned around and the collector shortened and re angled, should be able to make the pre turbo part of the exhaust shorter, and flow & sound better3 points
Ford I-beams. Thousands bent by hotrodders, most people don't use heat on jap' car parts though.3 points
Finally got the c-notch pieces laser cut. So we pulled off the tray and started stripping it back.3 points
Heat it up and straighten it in a press, it isn't ideal but chances are you will get away with it. It really isn't that dodgy, people have been straightening things for years with no ill effects, basically it is just scare mongering from people who have very little knowledge in positions of power. Even if you don't get away with it the worst that is going to happen is that the caster will pull that wheel straight and you will have to pull to the side of the road steering with one wheel, no big deal really. To get past the wof brigade just wire wheel and paint and no one will know.3 points
heres some relevant info on welding struts together that have cast/forged bits http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_05-2012_Welded_Aftermarket_Suspension_Struts.pdf as far as i know, none of these struts have been approved, one manufacturer had one tested, it failed, they modified the welding process and tried again, still no good, so they basically said "fuck this, NZ is a tiny market, CBF" and didnt bother any more2 points
I managed to reverse the explosion and it goes Excuse the jumpy wife when something falls off the bench in front of her2 points
That's a different argument though Roger. From a mettalurgy point of view what is so wrong?2 points
Right you lot. End of the day it's written in the wof rules that you will fail a wof if a steering or suspension component "shows signs of welding or heating after original manufacture" Here's the relevant page http://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/steering-and-suspension/steering-and-suspension-systems2 points
could all the naysayers please outline their specific ability to make such statements. anyone reading above would think that practical metallurgy is magic or something.2 points
The old girls been putting along and the little 1600 Kent moves her very nicely, even made the trip from CHCH to Palmy over the Christmas break without a hitch, I recently had to do the head gasket as it popped and was making massey ferguson noises all over Wellington CBD. Ive also rebuilt the starter motor. Lately ive been acquiring parts for this girl consisting of an Aussie 6cyl diff (Falcon internals), Not one but 2 pre facelift GT/GXL Dashes/Centre consoles, New old stock guards, Grill. I also got a set of NOS Lucas Ranger spotlights in perfect condition, even had the switch to accompany them! Plans for the Tina have Manifested to me wanting to put a 302 Windsor in her with an off the self kit, but for the sort term it will be to fit the GT dash, fit a set of tombstone seats2 points
so, the other side. i ground back the massive amounts of bog to see what was hidden benith. no surprise, a few very bad repairs. Untitled by sheepers-ra28, on Flickr Untitled by sheepers-ra28, on Flickr this is how thick the bog is on the sill. i might have to make a whole new sill but we'll see when i strip the rest back. Untitled by sheepers-ra28, on Flickr this is a rusty bit at the top of the arch. Untitled by sheepers-ra28, on Flickr so its not as bad as the other side which will make life easier. ill start on this side tomorrow if everything goes to plan.2 points
Got the body on my new trolley - much easier to work on and move about the place IMG_40172 points
Won't be able to attend, but cool car chase! (posted before but ah well).. Interesting note to Zebradude - looks like the baddie steps over a Morris Oxford at 3:13.. probably this fine example for sale at the bottom of the country.. http://www.trademe.co.nz/Browse/Listing.aspx?id=859259042 I'll go away now2 points
Please say you are still going to put a fake browning .30MG and a dummy ammo belt coming up through the front guard like in the picture? Don't see that style on the road anymore.2 points
lol really , this is some sort of justification to repairing a cast steering components ??? is your axel directing the vehicle? is your axel about 130mm long and bent 10mm??? common , just think about it its really a simple thing to grasp here, look at all the things that could go wrong how many people could be killed. just if this one thing fails from a repair that you cant be sure is a good solid repair . its not illegal cause the there is a 0.5% chance that it would fail, its illegal cause you don't know if the repair has been done successfully, and its been proven time and time again that it can fail . this isn't something you can measure with a tape measure or tools from home. you haven't got any of the NDT testing or x ray inspection , you have a willy nilly "don't heat it up to much" type of answer . this shouldn't even be an argument , its ridiculous . , go have a Google , go do some research of metallurgical science, find out for your self why its illegal . we as a car community shouldn't be condoning bad practice, we are here to inform and help each other . Im not going to argue about this any more. I feel what I have said should be enough for anyone to grasp the seriousness of this topic. don't muck around with cast steering stuff its just not worth it. just throw it in the bin and get a new one.2 points
look at all the work you have done to your car, think about the implications of your steering braking whilst going somewhere, or if you are on the motorway ? look at the all the work you have done going down the toilet if it does go wrong,. what happens if you take out a car full of people from crossing the center line? im not going to argue about the strength of cast components, before or after being bent then heated and straightened, or how you can have success at straightening it . because there is no NDT testing or any way to prove that you are right . this stuff can fail that is why its not meant to be done . this is a proven fact . this is why its law. its to keep everyone safe cause no one can be sure the repair is sound . don't be ignorant and say its safe , its illegal to repair for a reason the point is if it goes wrong and you have tried to repair it , then its your fault. is all your work worth a easy replacement part? or someone's lives ? just think about it, its not a expensive part to replace2 points
Dude this thing is awesome, feel free to contact me and pop on down the yard and say hello, anything I can help you with let me know. I love this style of post apocalyptic mayhem, and I'll help out in any way I can.2 points
Yeah it was year 12 engineering, after i finished the first project which was a little steam engine my teacher let me start on this2 points
Since I last posted so much has changed My sex therapist has called me truly deranged good gracious, it seems I am no longer a teacher I now have go pro, come be my #1 feature You could come to my litterbox, fill it with scat Felixx you see is one filthy cat Anyway you know where I am I will do whatever you tell me to maam2 points
yes. with only minimal skill its completely safe and directly in the same catagory as changing 13 inch steels to 16 inch alloys without certification.1 point
If the wof inspector doesn't notice, does that make it safe?1 point
That's not my field of expertise, Dave. I can only comment from an AVI's POV.1 point
Even if it WAS weakened, it wouldn't break unless the car was crashed hard into something, and then it's crashed, so it's not going anywhere. Now I'm really going to get it1 point
Id bolt one set in and measure it up with internal micrometer. Then do the same with the other set. Then fingers crossed one set is obviously the correct set.1 point
I've got two in my shed at the moment, and that is definitely enough!!!!!!!1 point
ok I've been here with some mates on a club k cruse . they main man Daz is a fairly likable character hahahaha , try them, www.oldscoolautos.co.nz I don't know a hell of a lot about k as all my shit is t stuff .so I'm not sure about the interchangeability of specific k series gear , but I do know these guys have lots of k stuff and they are a good bunch of cunts : )1 point
How come its OK to bend ford I beam axles?1 point
Rookie gives you confidence in your backyard heat fix? Hilarious. Ah well, people tried to help.1 point
Since then i havent done an awful lot.. Engine is ready and waiting for me, heading to pick it up in 2 weeks, hopefully get an expansion chamber made up soon after.1 point
So with the monumental help of Mike-E, I managed to get the car safely up to auckland. Loaded the car on first... Then filled it with shit... Put tables and an engine hoist on the trailer too... Thanks Marshall Profiling! In the end, I towed the car trailer up with my partners Landcruiser - it didn't do too badly at all! And here the Disiesel is all safely in it's new home: I kid you not, unloading this thing was such a fucking mission - it took from about 9ish until midnight - I had to reverse up this mega steep driveway, then detach the trailer and jack it up enough for the car to start rolling back, then gradually shimmy the trailer out from under the car. Pretty much by myself too cos my girlfriend has a broken ankle and wrist! Ahhhh fun!1 point
What do you drive to get pulled over so often? I must be doing something wrong as I haven't been pulled over in years...1 point
Had a car in at work today with a GPS tracker. You could tell by the box sitting in front of the center console with "GPS Tracker" printed on it. Please hide your GPS trackers.1 point
You are sweet. I dropped a large version of this into their letterbox au.1 point
One more of the Honda Dax 70. Fits in the tray snuggly with my tool box haha. Might put a thread up in the 2 wheel project section eventually1 point
