  • Replies 1.6k
The stabilising resin?
Seems to have gone rigtt into the centre, but it's a hard wood so might not have been the best test.
The red resin is just on top of it, this was the piece I used.
run water through it for a day? or purge it with inert gas : I know there's an expert way  to do this & a Welder Barry will be along soon
have you seen the 'crafty Russian' that likes to use those Freon tanks for making dumb facebook "diy" stuffs?
He just vents them atmo (like every time)
I've blocked or snoozed most those pages so sorry cant find a link at the mo'
/bling
edit : a bit like this (and just as hazardouz)
7 hours ago, Bling said:
How do you clean the cylinder for safe cutting? Pig looks sweet.
I removed the valve and left it upside down out side for about six months before I used it .
i did drain the big bottles when I made a cannon, don’t get the dye or smelly stuff on ya or you will stink for weeks.
then lots of hot soapy water and store upside down, lpg heavy than air etc
Very crudely. I only did a basic calculation with 100kg hanging on the hoop. Ignoring a heap of things just to get a feel for it.
If you gave it a high stress value on the less than ideal welded joint, and a high shock value on the load being applied...it will still easily hold 25 people hanging on it (ignoring that the ground would fail first).
  • Haha 2
Proof test?
  • Haha 1
