si
Just failed WOF. Car got one fine before we got it in Whangarei 6 months or so ago.
Aside from tyres and no high beam warning light (fair 'nuf)
Apparently I need LVV for the inertia seat belts I installed (replaced shoddy as 2 point with clasp). New ones mount using the old holes (Car has 3 holes for seat belts for each seat).
Also failed for misaligned and unfocused headlights. They are original spec, unchanged.
Also apparently need a brake pedal rubber. Original car did not have one at all.
Is this correct/What can I do?
  • Replies 9k
Quick question about additional welding to a car body. Restoring mk1 escort at the moment, and to be fair the factory welds are pretty shite. Any reason why i'd be pulled up come WOF time if i've added spot welds here and there to panels to give them more strength? Likewise I see gusset panels available for the car, anything preventing me from adding some DIY ones or is this a no no? Some areas just don't seem all that strong so it would be handy to be able to just add in small sections as I progress. Purely for examples sake: Example Car isn't going to be doing anything than normal driving, so may not be required, but more so asking out of interest if I come across a section I want to strengthen.
Yay and nah on that sort of thing? Cheers
if the mount points are original you can fit a belt which is better than original to them. the only time we cert belts is if there is a new anchorage fitted. ie if you put belts in where there wasnt belts before.
7.5 in here
http://lvvta.org.nz/documents/suplement ... eshold.pdf
Thanks. Car came with 3 point (although not with tensioners) according to the heritage cert I got, and the 3 anchorages are standard on every car. I might take it to a classic garage for a wof next time.
strengthening like that would technically require a cert, as it is a modification to the structure
adding some spot welds- youd probably get away with that if it all looked factory
hey Clint
So I am looking at importing an f100 over from the states soonish
Do you know what the deal is with chassis Clipping, like taking the factory chassis and welding on the front section to convert to double wish bone etc?
i heard it may have recently became illegal but that was just a passing comment.
Cheers
(if you dont get my probabaly poor description then let me know)
yes can be certed- as long as its done properly. as andy said in your other thread there are a lot of scary built things in the states. if you want a nice job id look at doing it yourself, as redoing a previously fucked one is harder than doing it from scratch. or at least making 100% sure its a good one from millions of pics or someone looking at it over there
what year f100 you lookin at?
In all honesty if you had a cable coming out of the gearbox and once the speedo was fitted in the car and the certifier was road testing it then how would anyone know if it was a GPS speedo or not.. (obviously removing any labelling that indicated the speedo was GPS)
I'm not saying circumvent the law but it must be hard to figure it out.
work around would be to wire in a bicycle speedo with a pick up on the drum or something for wofs, and remove for all other occassions...
further research seems LMVT people are worried about speed being reported accurately in tunnels etc... which is a shame considering how much time kiwi cars speed in tunnels and how often mechanical speedo's report in accurate speeds
Full load stationary tests arn't relevant, its a VW beetle that left the factory with a wee 40hp engine... Also VW's have the speedo passing through the front spindle and fixed to the wheel bearing dustcap... and I am quite keen to eliminate this, and to have an accurate speed reported regardles of what wheel/tire combo I have on the car...
I think those gps speedos are a good idea.
a speedo can be one of the hardest things to sort out with some conversions. have had a few blokes with latemodel gearboxes with only an electric output in old cars with cable driven speedos that have spent $1k to get it working accurately- needs a box that converts elec input into spinning the cable at the right speed
even getting a cable operated speedo calibrated properly can be pricey
for those using an electronic speedo, jaycar sells a DIY kit that allows you to calibrate your own speedo. I used one of these in my last project, adapted a nissan electric drive onto a340 toyota box
