Everything posted by 10Speed
I dunno but those cylinders look a bit small...
^exactly wheel choice is for pussies
- 123 replies
The absolute cheapest option is about $1900AUD, obviously, you'll need a Subaru gearbox (my donor box cost me about $450), about 5hrs labour on top and also fabricate some mounts yourself. But at the end of that, you end up with a stronger box and 5 gears to choose from.
- 123 replies
- 7
Needed to test fitment in project car, could be in any condition at all only needed for a day or so. Have beers etc. Dave
ready for that subagears buy whenever you are
- 123 replies
I suspect I left mine in the sun prior (but to be honest it was so long ago I might be imagining it). Also, when you do get them on the window, make sure the corners aren't stretched too tight/thin or the outside of the rubber won't sit on the body. And finally be glad you're not dealing with the extra work the chrome brings
a squirt of silicon lube helped when I did my window glass. You doing Cal-look rubbers? or with chrome?
cheers, will look up the sizes of those. Time for me to buy one as well.... Are you running a coolant header tank in the back? (I really should just come and have a look at it one day)
- 497 replies
what radiator are you using?
- 497 replies
though you know they're IRS only?
- 497 replies
yeah sounds like a plan :_)
- 497 replies
(also on my to do list)
- 497 replies
or straight from the source in Sydney? https://www.facebook.com/Subarugears/
- 497 replies
Moa Beer advertisement - Car wanted - Auckland
10Speed replied to Threeonthetree's topic in Upper North Island Region
I have a beetle that can be there around that time... -
keen, if there's not already a waiting list?
I just set up retro pie on a pi, let me know if you want a well populated sd card image...
- 27 replies
Amazing!!! btw CSP have a bracket to mount the brake res. inside the boot https://www.coolairvw.co.uk/Image/0/0/JPG/CSP601021.jpeg
https://vwparts.aircooled.net/mobile/Product.aspx?ProductCode=401498 these were the cheapest 0 offset I could find, but you can't use them with drop spindles
what are your plans for the front end? add lots of narrow & discs?
bugger was hoping it was the digital one and I would be able to take a copy of the CD
very envious of your case and is that a magnaspark on the Taipan?
tonight I changed my spark plugs WITH THE ENGINE IN THE CAR!!! (I also drew up some flanges and covers that are getting water jetted)
yeah, its a slip joint, and yeah it does leak... but will weld it up when I put the bung in Opps yes, I did... looks like they're out of stock at the moment... but that's about the right price left hand side is the waste gate outlet... theres not risk, of it being too close to the end of the exhaust after the resonator?
stoked to hear it's still puttering around
See the pic of my exhaust setup below, where do I put an O2 sensor? and while we're talking about it does anyone have a source of reasonably placed ones?
