tortron Posted April 11, 2017 Share Posted April 11, 2017 cool, the inhibitor switch was the first thing I fixed so I can put in a fancy billet shifter from the states and get away with it? Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 11, 2017 Share Posted April 11, 2017 Inhibitor switches are a good idea, 1 Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted April 12, 2017 Share Posted April 12, 2017 Do the wide wheels and flares (and/or other body mods) on this Rover need to be certed? 1 Quote Link to comment Share on other sites More sharing options...
The Bronze Posted April 13, 2017 Share Posted April 13, 2017 Import compliancing question: If I bring in something ex-USA which has been engine swapped, what is the process at this end for compliancing? hope it slips through un-noticed? or be upfront from the outset and see what mods need to be made to it to get it Low Volume complied. Regarding this: https://sandiego.craigslist.org/esd/cto/6083457653.html 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted April 13, 2017 Share Posted April 13, 2017 To be properly legal it would need LVVTA Cert. https://www.nzta.govt.nz/vehicles/importing-a-vehicle/step-2-evidence/scratchbuilt-or-modified-vehicles/ Quote Link to comment Share on other sites More sharing options...
tortron Posted April 13, 2017 Share Posted April 13, 2017 ever seen an American modified car that wasn't held together with zip ties and wire? 3 Quote Link to comment Share on other sites More sharing options...
cletus Posted April 13, 2017 Share Posted April 13, 2017 On Thursday, April 13, 2017 at 09:17, locost_bryan said: Do the wide wheels and flares (and/or other body mods) on this Rover need to be certed? No idea without seeing it. Here's the list of stuff you can do without cert. http://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf Quote Link to comment Share on other sites More sharing options...
cletus Posted April 13, 2017 Share Posted April 13, 2017 11 hours ago, The Bronze said: Import compliancing question: If I bring in something ex-USA which has been engine swapped, what is the process at this end for compliancing? hope it slips through un-noticed? or be upfront from the outset and see what mods need to be made to it to get it Low Volume complied. Regarding this: https://sandiego.craigslist.org/esd/cto/6083457653.html Needs cert to be legit, even if it somehow sneaked thru entry cert it would more than likely be picked up at wof time, or insurance if in an accident. Looks like it has had brake mods as well. If it was, for example, a camaro that was a 6 cyl and came in with a 350 you might get away with something like that because it's a lot more tricky to figure out what the standard engine was, and it could have had it from factory. But a 54 truck with a v8 (which chev didnt start making till 55) , and from a different manufacturer, and more than likely some American "engineering" will be obvious to anyone that it's not factory. 2 Quote Link to comment Share on other sites More sharing options...
cletus Posted April 13, 2017 Share Posted April 13, 2017 27 minutes ago, tortron said: ever seen an American modified car that wasn't held together with zip ties and wire? Blobby porous welds are also common. 2 Quote Link to comment Share on other sites More sharing options...
igor Posted April 14, 2017 Share Posted April 14, 2017 1 hour ago, cletus said: No idea without seeing it. Here's the list of stuff you can do without cert. http://lvvta.org.nz/documents/suplementary_information/LVVTA_LVV_Cert_Threshold.pdf Just read through that. I was surprised to see airbags mentioned in connection with the substitution of handlebars on a motorcycle. Quote Link to comment Share on other sites More sharing options...
Shakotom Posted April 16, 2017 Share Posted April 16, 2017 It you've got a car with a Valid Motorsport Authority card -full cage/harness/seat ect do you still need a cert for those modifications? even if car already has cert for suspension? 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted April 16, 2017 Share Posted April 16, 2017 No, if it's covered by the authority card, it doesn't need to be on the cert plate 3 Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 17, 2017 Share Posted April 17, 2017 Can a car with a lapsed rego but has the LTSA style vin tag be taken to any WOF place for a WOF then apply for a registration? Quote Link to comment Share on other sites More sharing options...
cletus Posted April 17, 2017 Share Posted April 17, 2017 No still has to go to TSDA ie testing station or compliance center that does re registration 1 Quote Link to comment Share on other sites More sharing options...
M.H. Posted April 18, 2017 Share Posted April 18, 2017 I have a land rover discovery, its mint mechanically but has some nasty rust in the body, can I just swap the body from another onto my chassis? Quote Link to comment Share on other sites More sharing options...
igor Posted April 18, 2017 Share Posted April 18, 2017 If one were to do that would the resultant vehicle bear the identity of the chassis donor or the body donor? Or does it not matter and whichever one has live plates is the winner? 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 18, 2017 Share Posted April 18, 2017 Stayed tuned to find out more. ... Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 19, 2017 Share Posted April 19, 2017 I went to vtnz with my Safari and they moved the VIN tag from the body to the chassis..I don't even think it cost any money. 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted April 19, 2017 Share Posted April 19, 2017 It can be done, If the Id tags are changed at all its meant to go to a tsda for them to attach them, or if you end up with a mismatch of numbers ie the chassis number is no longer the same as the one on the firewall, they can note it in Landata so it's all legit. 5 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted April 23, 2017 Share Posted April 23, 2017 This has probably been asked numerous times but I can't find any info anywhere. Is it legal to paint a white/black number plate black and silver to look like the pre 86 plates? Quote Link to comment Share on other sites More sharing options...
