si
  • Replies 9k
OK. Im installing some XYZ coilovers to my car that werent made for my car. Ive had some custom top hats made and have made some spacers and sleeves for the bottom attaching thingy.
There aren't any mounting brackets for the brake line so I started making some.
The XYZ coilovers have a fully removable lower perch
Id like to get the car certed for the suspension one day and before I go welding I thought id ask if this is ok
Wanting to do this
Good to go or hell no?
yes that looks good,  any welding on the front suspension is technically required to be TIG so do it with one of those if you have access to one
TBH if it was just a brake hose bracket, i wouldnt fail it if it was MIG.
also make sure you leave room for the jam nut
So just want to confirm before i go mounting battery, have read back through thread but just double checking.
I can run a battery not in a box and in the passengers compartment IF its a dry cell? Yes?
Going to mount the battery under where the roof folds down into but tis not sealed off from compartment.
Also there is no recommendation for fixings of battery to car? Assume some threaded rod with a decent plate either side of the floor will be sufficient?
I like the schedule A guideline for battery. Double clamp, mount to flat surface and minimum 4 M6 fasteners from memory. I run m8 fasteners on mine.
Don't forget a legit insulation for the +ve post.
Battery doesn't have to be dry cell, but must be SEALED. I run a SLA battery im my mazda and starlet.
Guide is maybe a bit tougher than any OEM fitment but might as well do it properly if its not mounted in the engine bay.
What is the minimum indicator size for a motorcycle ?
And if it's a American import American built motorcycle can it have red indicator lenses ?
Thanks
Here are the rules https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/motorcycles/lighting/direction-indicator-lamps
Red indicators on the rear are ok.
No minimum size but must be visible 100m in day and 200m at night.
Cheers Roger . Do these need to be e marked ?
Also I can't seem to find any info regarding certifying a motorcycle . In regards to what I've done to my Harley removing the swingarm and welding a Hardtail section in place then calliper mounts and seat pans and the like
Yes, for cert everything will need e marking.
As for what you have done, I will assume it will be similar to what I needed for mine; 1D certifier and crack test for everything that has changed and special requirements for brake lever if you have changed/modified it. Also It will need a chain guard, front mud guard, rear reflector and a I think a couple of other pointless things I can't remember right now hahaha
Interesting Rookie . 2 mates have recently certified their xs650s with weld on hardtails and no crack testing was required .
My brake pivot point is on the motor so haven't changed that . All I've done brake wise is the rear calliper mount .
In regards to e marked everything I'm fucked as I'm running vintage headlight and taillight .
Will run a temp chain guard and front guard for the very process . I'm a bit gutted mine is a 80 not a 78 . Would totally run no indicators if I could avoid it . Might run without them once got first wof
Do you need a heater/ demister for cert? I've just had a quick search on here, it says no but it was from like 2010 and 2012 I believe.. I'm contemplating just blocking them up, but if you need them for a cert obviously thats not going to be a good idea..
Chris, it probably comes down to certifier, and mine was a custom frame not just a weld on hard tail, so in this regard it could very well be different, but I dont see how you could weld on a caliper mount without them wanting it tested.
The lights/indicator thing is dumb, but you gotta play the game, the certifier definitely checked mine for e markings. I rode mine without indicators for ages after I changed the rear guard and tyre, but you will need them for wof/have to put the rest of the junk back on, but you have cost to be the boss.
i believe that is the rule in Australia but not here yet, i could be wrong about that though.
