si
I need to make new engine mounts for my ca18det KP starlet. The current ones are those cotton reel type mounts, so not captive. It is a race car, but I don't really want to go as far as solid mounting the engine.
I like those escort world cup crossmember ones that have the horizontal bush with a bolt through it. They look reasonably compact and easy to fabricate.
I came across an old post where Cletus said not to use any old bush because you cannot do it up tight and the hole goes oval, or something like that....
What kind of bush would be suitable? Is there an economical option that does not have $100's of escort/rwd/brandname tax added to something that cost $20 to make?
have a look at something like this
https://www.mountshop.co.nz/
a suspension bush with a crush tube in it works well for what you are talking about
  • Replies 9k
teflon or kevlar lined is what the book says, with a load rating suitable for the application
I have the information for the load ratings on the T3 rod ends somewhere.  I know the 4-link arms far exceeded minimum spec based on what Neil Miller told me.  I'll try find the information.
Have bought a bucket seat for my car, but due the cars low roof line and me being quite tall I can't use a normal seat rail to mount it because my head will end up on the roof.
What's the rules around solid mounting the seat? I will more than likely end up caging the car, getting authority card etc but until then am in able to do it for cert?
Just wanting final confirmation on this before i take a welder to the trans crossmember and prop shaft hanger bearing.  What materials should the spacers be made from and what rules do i need to follow/the guy im paying to do this needs to follow.  Will probably end up in your shed again Clint so what do you need?
The factory trans crossmember on an outback is just shaped differently to give the right amount of drop.
what R100 mentioned would be fine, spacers with the same footprint as what the OE crossmember had
Hey Clint, what's the go if you convert a say 1994 rhd car to lhd, the plan is for it to have a motorsport authority card, but can it be done and still get cert? Like wise with removing airbags and abs?
Cant convert a car to LHD. removing airbag and abs is ok though.
Drivers seat has to be adjustable if it was originally,  cant be fixed unless it has authority card or is a scratchbuilt vehicle
Hey Clint, stupid question I'm under the impression when getting removing air bags you need to remove everything (including wiring?) - can i still keep the spiral cable so that indicators will self cancel though?
airbag, SRS warning light, and any air bag logos must be removed, wiring can stay
Does the bush need to be bonded to the crush tube and/or outer metal tube/sleeve thing?
no, as long as it is fully insulated
my boss used nolathane spring shackle bushes to make his engine mounts. 700hp and they dont show any sign of wear or breaking
I am looking at some steel rims for a project and want to know if I can get the center moved for a deeper dish?
Not sure if this has been asked before, but have had no luck finding it, although I do understand that widening is all good by the certified people to do such work.
Cheers, Corey
Clint, dahling.
If I go from a 2 piece driveshaft to a 1 piece do I need a recert or would I get by with dropping by the certifier so they can get some new pictures and they can sight the receipt for making/balancing?
I expect I would have to ditch one driveshaft loop to keep the range of movement.
Progress.
Pajero lower control arm bushes.
The question I have is, should I gusset the mount on the cross member? It seems pretty solid already.
Like this, or something?
