si
  • Replies 9k
Got an ek hatch as a daily from ZEBRA and want to replace the rear bushes.
Cheaper to just get aluminium arms from scarles (they say on their site they are LEGAL unlike other brands)
How true is this? Can you change to adjustable top links without a cert?
How does the wof man know a legal brand of arm from a non legal brand?
if you dont need aftermarket adjustable arms, dont bother. You would need a cert, and on the cheaper brand arms, the bushes suck and fall to bits.
Hi Clint, just saw this system and wondered if it would require the full automatic system that airbags use?
Seeing that its mainly used in at either full extension or none would it be allowed with just a switch to go full up?
looks like a good idea.
here are the rules for air suspension, you dont need a full automatic self levelling system to pass cert
http://lvvta.org.nz/documents/suplementary_information/HCTM_SAMPLE_Chapter-6_Suspension%20Systems_airbag-hydraulics.pdf
That would prove a little difficult for getting over speed bumps/driveways, you'd have to come to a complete stop before and after for it to go full up/down
Yes. Mine was certed wired to the neutral safety switch, so it works in either neutral or park (for auto).
i thought they were sealed, but had a look at the spec sheet
Overcharging
can cause the safety valves to open and battery gases to escape, causing premature
end of life.
These gases are flammable!
so it would need to vent to outside or put it in a sealed box
Manufacturers plate had the chassis number. Never saw a car without one in all my years doing WOFs in the early 90s
From memory VIN plates only came out in the early to mid 90s. When Jap Imports started getting really popular.
Edit - I just re-read your question, re-reg was not a big deal as you just used the original chassis plate number and remember that continuous vehicle registration was not a thing.
I think vehicles only fell off the system after 3 years or something and you didn't have to backpay reg if you forgot for a couple of years.
Clint oh oracle of knowledge im looking at putting some side flaps on my rally car can i drill and put riv nuts in the underside of my sills like 4 or is this a no no my other option is to make them longer and bolt through the floor
like what you see on the side of this car
10742d1312288824-lancer-evo-6-gravel-ral
Whats the dealieo with that rule where you can drive your unwarranted vehicle if you are driving it to a place to get work required for the warrant?
My Starlet has rego on hold(last rego was 2014) and wof expired. It needs a new cert because I have changed from a sohc to a dohc.
My cert guy is in carterton(Julian Cheer), I am in Upper hutt.
Technically, getting the cert is "work required for the wof"....
If I drive it to carterton, and I am stopped by "the man", would I get away with it? I would probably be stopped because my car has panels that are not all the same colour, rather than for speeding or whatever.
"It’s illegal to drive a vehicle…
  • If it doesn't meet WoF requirements.
  • If it doesn't display a valid WoF label.
You can drive your vehicle on the road under these circumstances only when taking it somewhere for repair or to get a new WoF – providing it’s safe to do so."
You would probably be OK if you aren't picked up for speeding/being a dick on the road.
No guarantees when dealing with the Police though.
