cletus Posted February 28, 2014 Share Posted February 28, 2014 i could do everything except the spindles, because the steering arm is part of them, needs a bump steer check so has to be done by a 1D certifier. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted March 3, 2014 Share Posted March 3, 2014 Bugger, would of preferred to give my monies to a OSGC but I guess them be the rules. Are there any 1D certifiers in BOP area or would I have to come to auckland/guess a bumpsteer check raises the cert price a bit? Quote Link to comment Share on other sites More sharing options...
chees- Posted March 13, 2014 Share Posted March 13, 2014 Hi, i've searched but everythings old and the pics are gone. Are you able to cert a setup like this below, where you bolt two plates to the original rails and then bolt seat to those plates? Quote Link to comment Share on other sites More sharing options...
Testament Posted March 13, 2014 Share Posted March 13, 2014 Dear Mr Cletus, Are you available to view a car and discuss options regarding of mini-tubing a car? I have a zillion questions and get some idea's I'd like to run past you on your thoughts on it. Biggest problem is I cant bring to your working place. I'm in south Auckland. Possible for you to come to me? Happy to pay for your time etc. Thanks. Shane. prob better to PM him man Quote Link to comment Share on other sites More sharing options...
Infinit Posted March 16, 2014 Share Posted March 16, 2014 have searched the topic but cant find the awnser! With removing interior can u still just change your car to a 2 seater from a 5 when u remove the interior and fill in the old seat/seat belt holes? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 16, 2014 Share Posted March 16, 2014 yep. http://vehicleinspection.nzta.govt.nz/virms/in-service-wof/general/vehicle-interior/seats-and-seat-anchorages click the 'tables an images' tab Note LVV certification is not required where the only modification is the removal of seats and/or seatbelts. However, a class change and a new load rating may be required in some cases. Quote Link to comment Share on other sites More sharing options...
cletus Posted March 16, 2014 Share Posted March 16, 2014 Hi, i've searched but everythings old and the pics are gone. Are you able to cert a setup like this below, where you bolt two plates to the original rails and then bolt seat to those plates? yep, sometimes needs a gusset on the flat bits if the seat mounts are a lot narrower than the rails. 1 Quote Link to comment Share on other sites More sharing options...
camo_78 Posted March 16, 2014 Share Posted March 16, 2014 hey Clint,ive got the opposite issue,seat mounts are wider than rails(in my case,wrx seats in a mk5 Cortina).any special rules around it or anything??I haven't tried getting a warrant on it yet(mid rebuild),have mounted them using 30x3mm flat bar and original wrx and Cortina bolts Quote Link to comment Share on other sites More sharing options...
Spooch Posted March 18, 2014 Share Posted March 18, 2014 Hey, quick question that's probably been answered a million times, but where is the most lenient place for a reregistration on the North Shore Auckland. Or any place on the North Shore. I'm in a rush. Cheers big ears Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted March 18, 2014 Share Posted March 18, 2014 vtnz? Quote Link to comment Share on other sites More sharing options...
Beaver Posted March 18, 2014 Share Posted March 18, 2014 Pretty sure it has to be vtnz for revin. So go there Quote Link to comment Share on other sites More sharing options...
Spooch Posted March 18, 2014 Share Posted March 18, 2014 I don't think it has to go to VTNZ because its been in somewhere else before. Can you just take it to any VTNZ? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted March 18, 2014 Share Posted March 18, 2014 If it's a revin then it can only go through VTNZ. It's effectively a very strict WOF, if there's any repairs to the car they'll probably request a repair cert and sometimes require paint / bog removed so they can inspect welds (or at least photos of) so if your car isn't sound there's not much point trying until it's properly sorted. Quote Link to comment Share on other sites More sharing options...
Ranter Posted March 18, 2014 Share Posted March 18, 2014 You can go to vinz or aa also. 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted March 26, 2014 Share Posted March 26, 2014 Is there a minimum height for high stop lights? Could I get away with putting one on the tailgate of a ute like the new hiluxs? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted March 26, 2014 Share Posted March 26, 2014 There is, dunno what though Quote Link to comment Share on other sites More sharing options...
Corbie Posted March 26, 2014 Share Posted March 26, 2014 No part of a lamp’s illuminated surface must be lower than 150mm below the bottom edge of the rear window, except where there is no rear window fitted or visible from behind the vehicle. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof/general/lighting/high-mounted-stop-lamps 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted March 27, 2014 Share Posted March 27, 2014 Yeah found that thanks but was confused/didn't read it properly. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted April 5, 2014 Share Posted April 5, 2014 Oh hey boes, Clint / Keegan, is it legal to run solid bushings on a rear control arm? The FD failed a WOF on these bushings, and there is not an off the shelf replacement. RHD Japan do these replacements, but rather than importing, I'd just get some made up locally. Quote Link to comment Share on other sites More sharing options...
cletus Posted April 5, 2014 Share Posted April 5, 2014 they would be ok for a cert as long as they are a quality kevlar or teflon lined bearing, im pretty sure the original outer bushes in that arm are similar to that anyway, rather than a rubber bush. bear in mind they wont last very long on a road car with no boots as road grit and crap will wear them out have you tried mazda to see how much a new arm is? Quote Link to comment Share on other sites More sharing options...
