Infinit
Everything posted by Infinit
So I am wanting to put this front end into my minx it's l200 u can see were in have cut it off the chassis leating the bottom skin and side skin attached. If I was to remove these parts and reweld a nice bent section out of 5mm plate that I could use to bolt thru and into the minx rails with crush tubes in the rails? Would this pass a certain. ...
What are the rules on raising a vehicle? How high can u go....
Look at secound hando engine driven fridge compressors from boats on tm can get whole setups cheap as sometimes then u just make a insulated box how u want.
No only 2
The super chargers are cool.... wonder how hard it would be todo with carb.....
No the diff is in the rear and the front will be made to bolt onto the rails. Should be able to get some serious lowness from it to The flat head 37.5bhp I read it has a forged crank and rods....
I would rather not cut the roof!, I was thinking the same thing about the body line as the cut point!, u think I should keep the original motor but work it? Prity sure all the internals are forged....
So with the new front and rear ends being to wide... wide body???
To cert a car with a narrowed diff does the housing need to be welded by ticketed welder?
So have got the diff ready for a test fit it's 10mm wider each side!, don't think it's going to fit but will give it a try. Need to start trimming up the front cross member to get it ready for trial fit aswell also got some rims...
So decided that I will upgrade the suspension so got a L200 for free. Will shorten the lsd diff and run that aswell and put 2" drop spindles on and get it nice and low. I also happen to now have a box that will bolt to a evo engine.. hmm.... I'd prefer colum change to keep it sleeper... haha
Engine has been rebuilt and all brakes were rebuilt aswell but has sat since the quake...
So decided I need a project now I'm living in Christchurch didn't want another japa or something I've done before. 1952 Hillman Minx Mark V.
I never got try try fitting a rear seat and belts..... after all its Factory..... twin side draughts sound great!
I'd love another one! Ive had 2x 125,125 sports, 125T and the ute. I wanted to put the t engine and interior into the ute haha
Dam I had one of these back in 2010!!! Ended up selling it so regretted it only seen 3 others not including this one since then.
have searched the topic but cant find the awnser! With removing interior can u still just change your car to a 2 seater from a 5 when u remove the interior and fill in the old seat/seat belt holes?
