Infinit
Infinit's Achievements
Advanced Member (3/5)
30
So I am wanting to put this front end into my minx it's l200 u can see were in have cut it off the chassis leating the bottom skin and side skin attached. If I was to remove these parts and reweld a nice bent section out of 5mm plate that I could use to bolt thru and into the minx rails with crush tubes in the rails? Would this pass a certain. ...
What are the rules on raising a vehicle? How high can u go....
Look at secound hando engine driven fridge compressors from boats on tm can get whole setups cheap as sometimes then u just make a insulated box how u want.
No only 2
The super chargers are cool.... wonder how hard it would be todo with carb.....
No the diff is in the rear and the front will be made to bolt onto the rails. Should be able to get some serious lowness from it to The flat head 37.5bhp I read it has a forged crank and rods....
I would rather not cut the roof!, I was thinking the same thing about the body line as the cut point!, u think I should keep the original motor but work it? Prity sure all the internals are forged....
So with the new front and rear ends being to wide... wide body???
To cert a car with a narrowed diff does the housing need to be welded by ticketed welder?
So have got the diff ready for a test fit it's 10mm wider each side!, don't think it's going to fit but will give it a try. Need to start trimming up the front cross member to get it ready for trial fit aswell also got some rims...
So decided that I will upgrade the suspension so got a L200 for free. Will shorten the lsd diff and run that aswell and put 2" drop spindles on and get it nice and low. I also happen to now have a box that will bolt to a evo engine.. hmm.... I'd prefer colum change to keep it sleeper... haha
Engine has been rebuilt and all brakes were rebuilt aswell but has sat since the quake...
So decided I need a project now I'm living in Christchurch didn't want another japa or something I've done before. 1952 Hillman Minx Mark V.
