chasinthemirage Posted February 8, 2017 Share Posted February 8, 2017 What's the go regarding vehicles with declaration? I'm looking at purchasing a vehicle that has been modified, do I just need a copy of the declaration paper and wof's and insurance etc will be all good or is there more to it? The car is currently wof'd and reg'd as I understand declaration dies with the plates. I haven't been able to find much info on Google regarding it. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 8, 2017 Share Posted February 8, 2017 19 hours ago, jakesae101 said: be pretty sketchy to have them on a road car you would loose alot of protection from memory even race cars to run composite doors had to have a cage with side protection. Not any different to the many glass body rods that are kicking round. 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted February 8, 2017 Share Posted February 8, 2017 And have series Holden's probably aren't the strongest in side impacts anyway 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted February 9, 2017 Share Posted February 9, 2017 Did you see the glass HQ on TM? There is a silver one driving round Henderson to 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 9, 2017 Share Posted February 9, 2017 There's a full glass body on FB ..I was trying to get the doors off him but he wasn't keen. Still, for $1600 it's a bargain (if you can be bothered trying to get the cab legal..Would need lots of steel I imagine)..Actually even if ya biff the cabin- for the doors and one piece front it's still cheap I hear there were 20 made in NZ, the one on Faceballs is FG cabin, FG doors and one piece FG front (I can't work out if that is cool or just a pain in the ass) 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted February 16, 2017 Share Posted February 16, 2017 On 2/6/2017 at 18:21, flyingbrick said: What is the story with fiberglass doors on a vehicle like the HQ? Do you have to frame out the guts? (Simple bar work between hinges and door latch? What's the minimum requirements?) yes, the book doesnt specify minimum sizes, but a simple frame between the hinges and the door catch made out of something like 25mmSHS, 3mm wall would be fine 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted February 16, 2017 Share Posted February 16, 2017 On 2/9/2017 at 10:02, chasinthemirage said: What's the go regarding vehicles with declaration? I'm looking at purchasing a vehicle that has been modified, do I just need a copy of the declaration paper and wof's and insurance etc will be all good or is there more to it? The car is currently wof'd and reg'd as I understand declaration dies with the plates. I haven't been able to find much info on Google regarding it. yes as long as the car matches the declaration, you just take it with you and go get a wof one thing to look for is that there has been no further mods since the declaration, as they were only a statement that the vehicle was modified prior to 1992, and doesnt need LVV cert. any mods after the declaration was done= go through a new cert, there are allowances for cars modified prior to 92 though 2 Quote Link to comment Share on other sites More sharing options...
M.H. Posted February 16, 2017 Share Posted February 16, 2017 What rules I need to read up on changing my mercedes to rack and pinion steering? Quote Link to comment Share on other sites More sharing options...
cletus Posted February 16, 2017 Share Posted February 16, 2017 i would suggest going to lvvta.org.nz the car construction manual is now available by chapter, so you can buy the steering part on its own http://www.lvvta.org.nz/shop/ also have a read of the infosheets section, theres a couple of them relating to bump steer 2 Quote Link to comment Share on other sites More sharing options...
Popular Post cletus Posted February 16, 2017 Popular Post Share Posted February 16, 2017 While I'm recommending things, everyone building a car or chassis for one, or modifying a factory chassis should read chapter 18 of the hcm/CCM properly before picking up a grinder. It's amazing the number of people that grind welds back in an effort to make it look better, which is a giant cockup because then it has to be re welded, and then looks worse than it did in the first place. Especially if they have ground material off the chassis to 'blend' it in 12 Quote Link to comment Share on other sites More sharing options...
tortron Posted February 16, 2017 Share Posted February 16, 2017 You mentioned certs pre 92 get some leeway Mine was 91, what can I get away with? Quote Link to comment Share on other sites More sharing options...
Nominal Posted February 16, 2017 Share Posted February 16, 2017 We had a spiel from Andy Smith on cert's at our latest rod club meeting. He avoided mentioning too many fails, but did note that a lot of people ask to cert 'just the seat rails' or similar, which can't be done. The certifier has too look at the whole vehicle and all mods. Also touched on the pre-92 thing as one member has a rod that has declaration, but rego has lapsed, so falls into this category. 2 Quote Link to comment Share on other sites More sharing options...
Raizer Posted February 17, 2017 Share Posted February 17, 2017 Is it a WOF fail to replace the hinge pins in door hinges with high tensile bolts? Might have just been a Barry yarn, but I've been told it's a no go. Quote Link to comment Share on other sites More sharing options...
doullama Posted February 18, 2017 Share Posted February 18, 2017 I had bolts as hinge pins for all hinges on a cf bedford, was all good but being so old can get away with vaster bodginess generally Quote Link to comment Share on other sites More sharing options...
MaxPower Posted February 21, 2017 Share Posted February 21, 2017 hey there anyone know anything about roll cages? been offered a 70's corolla race car for what seems to be a good price but worried that the roll cage may not be up to todays standards, has logbook but no number plates. he last used it at taupo 10 years ago. will this be allowed back on a track etc? cheers Quote Link to comment Share on other sites More sharing options...
JoKer Posted February 21, 2017 Share Posted February 21, 2017 oooh I'm thinking not really, best hope is to find ANY sort of identification to 'reprint' or regain the original logbook from MSNZ (chassis stamped numbers anywhere? I had something similar with my Avenger when I obtained it it was an existing cage 'reshelled' but not up to the new spec's (80's spec main hoop etc) I might / will likely be wrong or corrected but those are my thoughts & experience with that sort of matter Quote Link to comment Share on other sites More sharing options...
MaxPower Posted February 21, 2017 Share Posted February 21, 2017 has factory body tag and a cage number and logbook. Quote Link to comment Share on other sites More sharing options...
JoKer Posted February 21, 2017 Share Posted February 21, 2017 ahh then no problem, soz skim read you post a bit & thought you said had 'no log book' nah you should have no issues with that 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted February 21, 2017 Share Posted February 21, 2017 So jealous Quote Link to comment Share on other sites More sharing options...
Toddy415 Posted February 22, 2017 Share Posted February 22, 2017 This has probably asked a million times but here goes, my step dad has a 1994 silverado ext cab thats not complied yet. From reading nzta rules etc. It shouldnt need converted to rhd because its over 20 years old. My question is does the import date matter on having to convert it to rhd? This has been in nz for years now previous owner never put it on the road because he was going to convert it but if it doesnt need converted then that would save a lot of pissing round. Quote Link to comment Share on other sites More sharing options...
