Showing content with the highest reputation on 09/11/22 in all areas
30 points
24 points
10 points
10 points
I'm still plugging away at the new radiator and a/c condenser install. I ended up sourcing a 23" x 14" condenser. It's a bit shorter than the new radiator, but the next available size was 25" x 14" which would have been way too big for my current opening. I've mounted the condenser as far left as possible for two reasons. First up it was easier to run the a/c lines this way as I didn't want them rubbing on the new radiator core. Secondly, I figured with the radiator inlet and outlet both being on the right-hand side and the radiator therefore having a natural tendency to push a higher percentage of the coolant up this side of the radiator it made sense to have the unrestricted airflow on this side. I don't really know if this will help, but hey ... it is what it is. With the condenser test fitted I made some templates for the two additional mounting brackets required and I also carved a little filler panel to cover the old a/c hose holes. Figured I'd refresh the front panel whilst I have the grill and valance off, so that is looking a lot neater now. A few "in progress" photos:9 points
9 points
I’ll just leave this here… After toying with the injection idea I just couldn’t do it. picked up a pair of mikunis, slapped them on, hooked up the fuel line that was already there. found a wiring diagram for using the stock dizzy with a bim024 type module. found that the wiring I paid an auto sparky to do last year is cactus, so hotwired the module for now, pump isn’t running, great. got spark. Wouldn’t fire off tdc, so figured the module may have advanced it by up to 30degrees. Guesstimated that on the pulley. And pop goes the weasel. only ran it for this long. now can sort the wiring so shit works, finish a few other bits. order up a ae86 radiator. but holy shizzlnut, it’s way quieter lol7 points
I'm not sure I've ever been less prepared for anything. I've never ridden my bike. I own exclusively leather riding gear. I haven't even grown a mustache yet. ... and the Mrs has already put up our Christmas tree.7 points
7 points
All off now, bit faster on the second side as I knew what I was doing. There's a fair bit of sticky sealer on the body side, not sure that all that is necessary, will do some research before it goes back together. First side has been been stripped using a heat gun and given an initial DA sanding. I need to go over them again and check the details, then go down a couple of grit levels to 240 or so.7 points
In prep for my bucket seats, I ordered the bloody bracket that I was loathed to pay for. it sits over the trans tunnel and allows the inner leg of the buckets to locate. Also it appears I need 2 x nylon 45mm bushes with 8mm centre bore as a spacer. $74nz for 2 off trademe or $8 if you c all a plastic engineering place in NZ haha. I also buffed the hell out of the 14x8 prostars and almost have got the clear coat off using stripper many many times….. that was some good sh!t they used back then. Sigh. I ordered repro centre caps from GT Wheels aussie and some ROH 45mm decals from Toyshop Engineering in NZ. I think you agree that they now are looking great and all for the cost of some 800 and 1000 grit wet n dry and elbow grease My spare mint 245 50 14 nankangs will go on the prostars as I want to save the Eagers as much as I can Carb was leaking fuel down the idle bleed valve and a mate popped in the other night, tore it down and it’s now fixed and runs loads better. The bloody dizzy cap was loose….which wouldn’t help the richness and bad idle Now to fit the buckets when the arrive, time it up and then I ca look to reset leaves 4” and super low front springs with new struts if anyone ha super lows to suit PM me.6 points
Guess I should try getting this thing road worthy if I’m to take it to drag day.. Finally managed to install the rebuilt PS pump.. had a bent pin I believe. When I went to install I noticed how far out of alignment it was so that may have had something to do with it failing, so I’ve shimmed it out and it’s pretty much bang on in line now.. was about 4-5mm out originally and I noticed the pulley on the pump wobbling prior to the rebuild, hopefully this will help it all last a long time to come. Last thing to do was to put in the new filter, unfortunately I ordered the new one off the code of the old one without realising the old one wasn’t correct.. needs to be 2.5” diameter to fit in the cup in the base of the reservoir, but this one is 3” so sits on top.. probably not a big deal as the spring holds it down, but I’d prefer the correct filter so I’ve got it ordered and should turn up next week. Getting there..5 points
5 points
Just did my test ride. Bike ticks along nicely at 75kmh now. Much happier!!4 points
4 points
@RUNAMUCK its interesting looking at the drive power curves, where it crosses over tells you where is best to shift. So in first gear, you lose so much wheel torque going to 2nd that it's worth revving the absolute snot out of it in 1st even though power is completely gone. If it had a slightly taller first gear then it wouldnt "ideally" want to go to 10k Then 2nd gear onwards, less need to rev it so high.4 points
Yes hopefully back to dyno before drags. Rev limiter needs to stay at 9000 for drags, otherwise rpm drops too much on shifts. At trackday try stick to 8500ish. I will set the limiter lower when doing burnouts. As it was overshooting to 9200rpm a lot which cant be helpful.4 points
4 points
4 points
Got the guards mounted, they are old bits of shit I found, stays are recycled junkcut and welded I, made sure everything has heaps of super stud lock on it and is straight and its good to go, that rear number plate/ light thing is off a Bantam, I choped it down, I might invest in a can of paint to touch up hear and there, I want to fuck up the chrome on the tank some how, I think you can do it with some acid and a rag and a car battery.3 points
I was about to say you have no sense of danger or adventure....but your current escapades suggest otherwise... Do you get extra points if you sell it at the end of the trip to some clueless 16 year old?3 points
What the heck, the cars look great, I thought this was a shitbox tour Night pic for thr underglow?3 points
I just stopped by to ask, if you'll be on the dyno before drag day? And also to say, Damn those god damned torpedoes! Dont you dare run a lower redline for a drag day. If you dont rev your engine to the moon, even for just that one day, I'll block you. Plus if you scatter the block, someone is sure to be filming. So we can all enjoy your offerings to the gods of speed. (Over and over)3 points
Also I broke my ITB manifold trying to get it off, because I had to pooz it onto the head with heaps of silicone. Not for sake of sealing it from vacuum leaks. But because anywhere that wasnt covered in carbon fibre, needed to be sealed from fuel reaching it or it starts melting. hah. So, I thought I'd give it another hoon printing one from carbon nylon stuff, as this is much more fuel/temp resistant. Rather than fiddling with heaps of settings, just used PLA settings with hotter temps, and set extrusion rate to 80% I think most of my previous problems with it, were from extrusion rate being too high. As I think this filament is a little wider diameter than 1.75mm, it's harder to push into the tube than PLA etc. Turned out pretty good, lots of stringing but its easier to tidy that up than fiddle endlessly with printer settings. So meh. I need to print some trumpets for @Stu so this will hopefully work out well for that too3 points
Winning, like a brand new box, no more anxiety on down changes, the crunches sounded pretty horrible3 points
Got a WOF today, super stoked about that! Also, for some reason the Dutch Top Gear website, and another Dutch site wrote some little articles about the Echo. This translation had me laughing out loud, ahaha "The combination, which you only dream about (mainly because it just doesn't make sense), apparently runs track-time sessions in New Zealand , and sounds surprisingly good too. We hope not to offend anyone here, but the Toyota Prius engine isn't the prime candidate for an ' engine-swap ' project. We will also not soon see a Toyota Echo among the registrations of a track day. Still, David van der Haas from Matamate, New Zealand thought it sounded good in his head to bring the two together." Thanks again to everyone that's helped me get the car going again with another motor. I'm now all set for OS drags in december, and getting the car back to the dyno in the meantime is now top priority.3 points
Sup yo. So a group of us are doing another shitbox challenge thing next week. This year, buying and modifying cars for less than 1500 bucks in the theme of the Golden era, aka, early 2000s. So we're off on a roadie in our creations next Tuesday, cutting another lap of the south island. Gonna be staying in Nelson 8th November, hokitika 9th, queenstown 10th and invers on the 11th. Thought it'd be worth a post up here if anyone local wants to come out for a brew and a yarn when we're in each town. Will probs do a really shit park up and cruise in each town for a laugh and to be general pests. 4/5 of the cars we're using. And there's an EK civic hatch as well. Come hang!2 points
Yup, dont have a massive turnout atm, maybe 4 or 5 cars Started out on NZ Datsun but not much interest atm, so all welcome2 points
Dyno day 19th Nov at Bombay, be cool to see how it goes compared to pushrod datsuns2 points
We may have gone a little overboard haha. I think we've all stayed within budget. Or near enough at least.1 point
Yeah man absolutely. We're currently in Nelson. Headed off to hokitika this morning. Will let you know a time and place!1 point
He's a nay as well as kass, he said he double booked.1 point
I love that this little car has captured the imagination of the worldwide media. In a world of chequebook car builds/supercars, this is what I'm here for.1 point
yeah gidday, we'prolly got accommodation in most ports (USB, Serial ?) due to Leyland PI Esc. cancellation. [Could be anyone mate.] I can't actually remember how many beds I booked in any town, but hit one of the red flaggots up after we have signed in and we can let you know how many spare floors / beds we have. This message wasn't intended for anyone in particular, but will look after whoever, where we can. HOO ROO SEE YOU FRIDAY FOR SOME THIGH SLAPPING ENJOYABLE TIMES LOVE TO THE FAMILY AND BERYL NUDGE NUDGE WINK WINK TOOMEKIE1 point
Because nothing is easy... The CDI arrived on Monday, and upon attempting to fit, I discovered it had all the wrong plugs and not enough wires... I managed to dig out a wiring diagram for an NSR 50, which aligned with most of what is on my bike, but didn't show the extra wire I had, and didn't include any of the gear indicator/speed limiter wiring. I'll put some info down here, incase someone else is scouring the internet for instructions like I was. I haven't got a photo, but my CDI had a roundy 4-pin plug, a roundy 2-pin plug and a squarey 6-pin plug. The 6-pin goes to the gear selector. The new CDI is a CF POSH 225064 and looks like this: None of the plugs fit together, so you need to cut them off and attach your own. Here are the instructions that came with the unit, translated to english: Wiring: CDI Side - Bike Side Orange - Coil + Blue - Blue/Yellow (Blue with yellow stripe) (This wire comes from the crank trigger) Black - Green (Ground) Red - Black/Red (Power feed) White - Black/White (Ignition switch) The spare wire on the bike side is Green/White, and needs to be connected to ground. To figure out the green/white took a while, lots of thinking, internetting, and a phonecall to @johnnyfive who is a GC and dismantled his bike to trace wires for me. There was a brief period where I didn't think I'd have it running again for east cape this week. But it seems I've got it sorted. As it happens, it would have been a plug and play solution for J5's bike... There must be some variation between models. Anyway, now its all ready to go.1 point
Good volumes of 2 stroke being burned this year. Nice1 point
Crikey. In a weeks time we'll all be slurping on a pink pussy. Better go put some stuff in a bag1 point
Some good throwback rigs there. Savage - Swing will be bumping hard. Licence plate rattling in the distance1 point
And, that's the boot more or less sorted. The existing boot liner is a bit tatty, but new ones are available so I'll order a fresh one sometime in the future and will then cut up the old one to make a neat little battery cover. That should complete the look nicely. I'm happy with the new spare wheel position as it has freed up some extra useful boot space. Thanks for looking.1 point
Battery relocation - Chapter 4 Next step was to pull out the original engine bay battery shelf to create the additional space needed for my bigger radiator. The whole thing is held in with 4 bolts and came out easy enough. What I really like about the Mustang tray is that it holds the battery down with a little foot clamp rather than the Mitsi tray which uses the old hooked threaded rods and a cross bar over the top of the battery. Checked the dimensions on the Muzzy tray and its just slightly smaller than the Mitsi tray, so I figured why don't I see if I can modify the Muzzy tray to bolt inside the Mitsi tray. That way I get a nice double thickness tray to help support the battery over the void and at the same time I get to keep the neater foot clamp style battery mount which looks way neat. Luckily the angle bracket on the Mustang tray is only held on with 3 tack welds, so those were easy enough to break. Cleaned the Muzzy tray up, poked a few more holes, slapped on some paint and the battery relocation is now done and dusted. Very happy with the result.1 point
Battery relocation - Chapter 3 With the foundation brackets mounted in place I returned to the shed for another scratch around and came out with an old battery tray left over from one of my donor Mitsi vans. Had a good bit of surface rust but was otherwise solid. Chucked it in my vinegar bath for a day and it came out absolutely mint. Poked a few extra holes in it, cobbled up a few spacers and gave it a test fit. Works perfectly. Slapped a bit of primer and satin black on that sucker and we were ready to rock.1 point
so I can keep track of what I've done: Things that did not work or made negligible differences 10" elec fansx2 Plastic flexalite fan 245 fan no shroud 245 fan with shroud 318 fan with shroud (probably most successful fan so far) Derale 6 blade stainless flex fan 180deg thermostat 160deg thermostat No thermostat Restrict flow through hoses Seal edges of fan shroud Make fan shroud 360deg Heat reflective stuff on rad tank, bottom of shroud Heat shield exhaust from bottom rad tank Bigger bottom pulley to speed up fan and pump Im getting tired of working on it tbh. Only options left are- auxilary radiator and fan mounted somewhere . Probably under left front guard. I think this will be the most practical /cost effective option to try Or Remove intercooler so it doesn't block rad and allows a fan on the front . I want to have/need some sort of intercooler though, so would need to redo piping and buy intercooler and heat exchanger for water to air ($$) or buy water meth system (also $$)1 point
