Showing content with the highest reputation on 08/22/17 in all areas
17 points
and at the top of those stairs i made a floor for filling up with shit. 2017-08-22_03-43-01 by sheepers, on Flickr13 points
Can you turn up to cert someones car on this please Clint. Then can you post an account of their reactions for my amusement?8 points
Took the bonnet out to @Archetype's place on Sunday to have a go at wrapping it. We'd used a bunch of vinyl samples to choose the colour "3m Dark Red" which seemed to match well. The 3m 1080 film is amazing stuff to work with. It seems almost impossible to get a bubble! After a bit of mucking around we had it finished with new vinyl eyelids and "grille" too. We used matte black for the eyelids and gloss for the grille to add depth. Got it home and chucked it on - looks nice: But... The colour is different to what we thought it would be. 3m obviously has a different colours for the 1080 wrap vs the standard 30 and 50 series vinyl. This is called "dark red" but it looks almost orange compared to the test sample. After a bit of research it seems like there probably isn't an option in this range that will match my paint... Dammit. For future reference - it's best to wrap your panels on or next to your car to make sure the colour matches as expected. Massive thanks to Brent / archetype / Doozi / MotoringEvents for making it happen. The job itself turned out mint.7 points
weather boards and the butinol done on the veranda. 2017-08-20_05-37-46 by sheepers, on Flickr 2017-08-20_05-37-37 by sheepers, on Flickr 2017-08-20_05-37-29 by sheepers, on Flickr wires and shit. 2017-08-20_05-37-20 by sheepers, on Flickr2017-08-20_05-37-29 by sheepers, on Flickr rondo for attaching the ceiling 2017-08-20_05-37-11 by sheepers, on Flickr steps for getting up to the roof storage 2017-08-20_05-37-01 by sheepers, on Flickr5 points
All the NOS M series headgaskets you can find?4 points
we got the trusses made with a reverse kingpin so the floor bit in the middle would have more space. I hope to fill it with car parts.4 points
Oops, missed a bit. Past couple of weeks I've cleaned up and put the interior back in. Cat helped - these had been out for about 10 seconds... Did I show you guys this? It's from Speedhut , they have a super cool gauge-face designer, can upload images and text and everything. Have a play, it's fun. Fitted in the hole pretty well (this was just a mock-up, fitted better after some more trimming inside and some sikaflex to fill the gap around the outside. It's tidier than it sounds, promise). Lights up all purdy-like too4 points
Cool stuff happened this week A local stainless steel fabricator has been busy restoring the exterior door trims for me, I got them back today and he has done a great job. As I mentioned in an earlier post the trims were full of holes where the trim had been pop riveted to the doors, all the holes have been repaired and they look great. Here is a comparison picture. I have also finished repairing the rear door cards. Very happy with how they turned out4 points
These ought to solve my offset issues. They have the same rear step as the WORKs, but are a little skinnier with a higher offset. Pair of 13x6.5 +10s, and a pair of 13x7 +15s. Outer edge of the fronts, with the 25mm spacers, sits only 5mm outboard of where the WORKs sat pre-spacer. Should give me the wriggle room I need. Rears might just get away without an arch roll as well, sit slightly in from the WORKs. Don't want these to be mint, but they HAVE been sitting in a dude's garage for 15 years, and were corroded to buggery around the bolts. Pulled the bolts, got some new ones coming. Pulled the shagged valves, got some new ones coming. Got some SSR shank nuts on the way too. Gave the lips a rub down with some graduated wet-n-dry, and a run over with some polishing compound. Prefer the bare ally finish to the chrome-like reflective finish they ought to be, so I'll probably just clearcoat them like this. Wire wheel and some brake cleaner on the centres and they are ready for paint. These were originally offered with an orange centre option, and I had some quite close orange paint in stock. The Starlet came with a green and and orange pinstripe down the side (of a green car, with a brown, beige, cream and red interior. Jesus, Toyota), so it should tie into that nicely.4 points
have hopefully fixed the worn out gas sender problem.I have no idea how much gas I have, but the old gauge don't work anyway, I can just look down the filler neck and at least I can full'er up now.And then as Sunday drew to a end...dells seem to fit. oh man those manifolds are right bastards! hooked up the throttle wire.made brumbrum noises.just need to finish wiring and install electric fuel pump, K&Ns should be here at the end of the month.So questions,1; I have a Red and a Blue wire coming from my 009 distributor, is one positive and one negative on the coil?2; loom has two large red wires in the engine bay, one goes to the Alternator?, and one goes to the starter?, and then I think one goes from the alt to the starter? my loom had no instructions, and because I've gone with alt from genny, this has changed a few things??Also how the hell do you keep the fusebox in place? I bought that little clip but I'm buggered if I can make that work!trying to avoid using a washer and wood screw like it use to have.3 points
I missed my old white 944. I really, reeeeaaaally missed that car. The cash from that helped us into our first Auckland home. But I always said I'd get into another once we got comfortable with the mortgage and sorted a few things out, and I squirrelled together a few bucks on the side where I could, helped out by my photojournalism moonlighting. Even though the last car was an 8 valve NA base spec car, I'd always wanted an S2. For those playing at home, the basic differences are a 2.5l SOHC vs 3.0l DOHC, slider calipers vs 4pot Brembos, better suspension and bigger ARB's on the S2 and a bunch of cosmetic differences. I'd been eyeing this particular car up for a few weeks on Trademe. It was priced high and I always thought, "I'll wait until it comes down a bit." I waited. It came down slightly, but not really enough. And there the price stayed. And stayed. And remained. In the end I thought, "bugger it I'll have a crack," so called the number on the listing and named my budget, asking if I was in the ball park. The answer came back affirmative. So from then I enlisted the help of a Porsche-savvy mate, Tony, to scoot down and check the car over for me. At this stage, it's worth mentioning the Carjam report came back fairly positive. The current owner, (in his 70's) had owned the car for 11 years travelling around 250km per year in it over that period. Yeah, 250km. So the car's km sat at a pretty-low-for-a-944 127,000km. Great start. When Tony first queried an inspection, he was denied on the grounds that it was raining, and the car never goes out in the rain. A positive, sort of I guess. The sign of a fastidious owner. Anyway, after an excruciating week followed by a weekend of waiting to have this thing inspected, Tony flicks me a text with "call me now, seen the car" after lunch on a Monday. The assessment was brief but positive. I'd sent through this massive Barry-spec checklist of things that commonly turn to custard on 944's, after the rollercoaster ride I'd experienced trying to sort the wheat from the chaff while buying the white one. Most of it passed muster - a few minor problems, but the car checked out soundly - well, more than soundly - and the summary was, "it's a fuckin' sweet car, you'll be hard pressed to find another one this good." Decision made. So I called up, negotiated a price and a deposit to hold the car for a few weeks while I awaited a quiet weekend to pick up was sent through the ether. Now - the car had some pretty gaudy stripes on it. Orange, with a PORSCHE font in the negative space as a cut vinyl stripe down each flank. Furthermore, it had a bright orange window strip across the top of the screen. This was never going to do, but I was assured it didn't appear to be too old, and the vinyl wasn't of great quality so confidence was high that it'd peel off easily. In fact, I'd already decided that it would be resigned to the bin before I'd breached the Christchurch city limits. So the pick-up weekend rolled around, George (@Esprit) and I boarded a plane and set off bound for the shaky city. The flight itself was pleasant, smooth and some great sights of the setting sun over the Canterbury plains as we descended - but it wasn't without trepidation, as I was about to commit the most money I have ever laid down on a car by some margin. Spending big sums of money isn't something that sits well with me, but hey, this was one of the dream machines so I probably shouldn't let the opportunity slip by. But believe me, I agonised, tried to rationalise my decision beyond "I want it because I have wanted one for years" and even suffered cold feet over the whole deal. Tony picked us up in his Mini Cooper something hatchwagon thing with one rear door that opens backwards and a supercharged whatsit in the front. Either way, it was quite compact and made cool whizzy-doorty noises from the front bit and went hard for what it was. We ended up at the doorstep of John, the then-owner of the 944 and his son Simon, who I dealt with through the Trademe classified. John was one of those super nice older blokes, with the utmost passion for his car. I made some cursory checks in the dim light with the aid of an LED torch, just to make sure I was going to go ahead with the sale as John proudly pointed out the hard-to-find bits that were still intact on the car, as well as detailing his maintenance schedule, and aversion to driving the car in the rain for the last 11 years of ownership. As I said, a guy with a legitimate infatuation for his pride and joy. As an added bonus, a wee zipped-up bag full of 944 specific books and memorabilia came as part of the deal, how cool is that?! Stepping inside to sign the paperwork the discussion turned to motorsport, and Porsches in general. I started to feel a little bad, as John's eyes were definitely tearing up at the prospect of his pride and joy being driven away, but then the excitement of finally being able to own what I deem the best of the 944 bunch finally had us saying our goodbyes, and soon enough we were crawling down the driveway in the dark. Then we had to turn back as I left my sunglasses behind. Because you know, it was dark and I'm a Corey Hart kinda guy. 15 minutes later, we drove into another internet-acquaintances shed (we will call him Terry the Italian car tragic) where a heat gun was supplied and the decals came off with minimal persuasion and zero damage to the underlying paint. Bonus. Dinner was served, yarns were had, beers were downed and before you know it, it was 6am the next morning and we'd crawled out of bed and poured ourselves into the 944's confines for the journey north. The trip was swift, but ultimately uneventful. Stops were limited to food and/or tea and coffee, aside from an overnight stay with @Bullitt in which George and I both managed to empty the fridge of any thirst quenching, fermented grain, hopped, fizzy beverages and I built a gigantor feed of nacho's for all present. More sharns followed and then we departed early in the morning, making a servo rendezvous with another couple of far north friends who were making the same journey back in a just-purchased EF8 Honda CR-X. How rad! Anyway, the rest of the trip was fairly unremarkable. You know. Standard North Island scenery. Farms. Mountain and tussock. More farms. Large body of fresh water. More farms. Even more farms. The odd passing lane. Some more farms and then traffic jams and rain. But hey, what a way to get to know a car, and also find out all of the little foibles that are going to make life an OCD hell for the next short while. For now, here's some shots of the car as we departed Christchurch in the early hours. I'll outlay some plans and discuss the experience, as well as all of the flaws this particular car has that I have already started to rectify. Thanks for reading my massive sharn! 1991 Porsche 944 S2-5 by Richard Opie, on Flickr 1991 Porsche 944 S2-7 by Richard Opie, on Flickr 1991 Porsche 944 S2-13 by Richard Opie, on Flickr TL;DR - bought a poor-man's Porsche and drove it from Christchurch to Auckland.2 points
lol like there's any of those left2 points
If anyone is keen the Nelson car club is holding a standing 400m sprint on Redwood Road Oct 1st. Car should be of wof standard or motorsport logbook. Helmet and cotton overalls. A great chance to find out how fast your car really is!2 points
If you bring your own overalls they MUST be 100% cotton or motorsport race overalls, NO polyester ones allowed. Not required for motorkhana but will be required plus helmet for autocross.2 points
sounds like you flash guys with your gears and chains and whatnot need to get on the variator and belt buzz keen as for some rolling thunder (lol) but do hope the weather holds.2 points
Can probably make this, easy as a local. BTW the Tararua Rodders show is on in Levin on 1 October also.2 points
Needed more ground clearance, so made a new front pipe, too rowdy with no muffler at all so made one. Whole exhaust is made from an old lawnmower handle and a bit of 2" pipe and some big washers. Good chance to practice with tig welder, I haven't done much for ages It's probably still a bit louder than I'd like2 points
lemon party golden shower squirt munro, geyser wilhelm, donald pump, gush gush, gone fistin', dirty hose, pump in the trunk2 points
This weekend, @Alistair bowled around and helped me with a lush polishing effort on the painted surfaces of the 944. Here's a few shots of the result, taken under some neat skies on Sunday evening. 1991 Porsche 944 S2-179-Edit by Richard Opie, on Flickr 1991 Porsche 944 S2-96-Edit by Richard Opie, on Flickr 1991 Porsche 944 S2-172-Edit by Richard Opie, on Flickr 1991 Porsche 944 S2-141-Edit by Richard Opie, on Flickr 1991 Porsche 944 S2-170-Edit by Richard Opie, on Flickr Some of the S2 differences: 1991 Porsche 944 S2-129 by Richard Opie, on Flickr Turbo nosecone, a big upgrade over the old 924-style front my 8v car had on it. 1991 Porsche 944 S2-92-Edit by Richard Opie, on Flickr "Bridge" spoiler in place of the squishy rubber ducktail thing, and the under spoiler/bum flap thing. 1991 Porsche 944 S2-47 by Richard Opie, on Flickr 1991 Porsche 944 S2-106 by Richard Opie, on Flickr 16x7 and 8" "Design 90" wheels and Brembo 4-pot clappers on 300mm rotors at either end. 1991 Porsche 944 S2-116 by Richard Opie, on Flickr 1991 Porsche 944 S2-119 by Richard Opie, on Flickr 3-litre 16 valve 4-banger engine. A shade under 220hp, lol redline of 6500rpm but sooooo torquey. Actually a very smooth thing to drive, with twin balance shafts and all that jazz. 1991 Porsche 944 S2-189-Edit by Richard Opie, on Flickr Delicious pop-up headlights, I can watch these go up and down all day. 1991 Porsche 944 S2-108 by Richard Opie, on Flickr 1991 Porsche 944 S2-68 by Richard Opie, on Flickr 1991 Porsche 944 S2-80 by Richard Opie, on Flickr 1991 Porsche 944 S2-82 by Richard Opie, on Flickr 1991 Porsche 944 S2-112-Edit by Richard Opie, on Flickr Interior things and stuff. Headunit will be switched out shortly for something not silver, and Bluetooth capable.2 points
I watched the videos, I was impressed that you managed not to spin! I reckon @ThePog could have done with more handbrake. PS Is he bringing guitar to Hanmer/should @scooters bring something too? I don't think the 400m would be ideal Beagle material. I'm currently saving all my pennies for suspension. Ground clearance vs handling is a conversation I'll no doubt be boring a few of you guys with in a few nights time...1 point
No, open are ok. Ideally not too old ( meant to be less than 10 yrs old)1 point
I think your order is on the same slow boat from Germany as mine @Shakotom, dunno WTF is going on, normally it's sub 10 days! Have got a stack of jets en-route to @MopedNZ now, so hopefully he can at least get a healthier amount of fuel flowing for the ride. The middy's leave was denied so I'm out, anyone want to do a park up at/ride from caffeine and classics next month?1 point
I also have a bike with a variator and a belt that needs a new belt/weights which are currently AWOL from Germany. also I'm out of the country between now and Saturday night. No worries though1 point
Got some more parts Roobars and a long range tank to turn this into a true Aussie battler. Bars are off an 83 4wd, and Ive just noticed they are not going to fit because I have the bumper with only 1 set of holes in it, and I'm not going to cut holes in it, so will need to cut it up and make something work.* Scratch that I looked again and they appear to mount to the towing eyes. Which is weird I thought. It also has a mount for an A frame on it that I won't need because a holden 6 will run forever)it's an auto. So that can go. Side bars should fit fine. Also from the 4wd I got the fuel tank which is 18 usgallon vs the 2wd 15. So should get about 100km more from it. Speaking of. I changed the thermostat and now it's actually getting to temp. Sits at half to the next mark depending on driving conditions (2 marks from red, 3 from cold) which seems high compared to what every Holden owner says they sit at (fans on at 1/4 to halfway) but maybe it's a NZ market thing. It won't go past that mark if I hoon up the Bombay's or leave it at idle with the fan on. Will see how it goes as the weather warms up. I'm using 1L less per 100km so that's a good thing. Also got a nos heavy vinyl floor covering without any shifter hole in it, so probably aftermarket. Should be ideal1 point
Nope I have not organised a cruise before, I assume there would be enough fucking around to make a few delays here and there, would you recommend a more afternoon sorted time like 2 -3 in Otaki ? Would be better ?1 point
Top coat on, terrible phone pics but you can get the idea... Sat the engine in And all the bits have come back from the platers. Thanks to Phill at Electroless Coating Systems Next up is getting the front wheel sorted, Seat covered and the cream insert painted onto the tank. Then the fun part, bolting it all back together!!1 point
Just in case anyone has been thinking.... I wonder what happened to this. I have hit a major curve. The holes in the heads that the pushrods pass through are making contact with the pushrods at about 3/4 lift... File it out I hear you say, but alas, these need to seal against the pushrod tube seal, and they have already been moved so they are hard against the valve cover rail. And welding and machining opens a whole new can of worms. So to "fix" the interference issue, I will be reassembling, trying the set up with the old smaller cam and maybe go to a different ratio rocker if the adjusting screw centreline is closer to the pivot point, and hopefully I can find enough clearance to make it work. I can probably sort it and have crappy rocker arm geometry, Ill go there if I have too. Pushrods are 1/2" diameter and tapered at the ends. Because this engine is not exactly off the shelf, Pauter (the manufacturers) were contacted, they no longer have castings made and all their current heads are billet at the amazing price of $8k usd a pair (holy fuck is the correct expletive here). Unfortunately if plan A fails this is where I am at, which is why I have mothballed it for a while. This week, next weekend Ill get it together and start trying shit.1 point
I've been collecting timber from a sawmill 'up north'. Is my ute OS? I reckon it are. It's also bloody awesome. It has self canceling indicators and power steering, but everything else you need to do yourself. The objects in the mirror are precisely their own size and I need to get out of the cab to engage the free-wheeling hubs. I love that ute. Sadly the generator died last weekend (as did a number of other things). It's a real challenge trying to keep tools dry enough to use up there, but after forking out a significant portion of the cabin budget on a replacement generator I managed to finish another frame today. I've gotten a bit better at calculating tangents... but of course there are mistakes aplenty. Sorry about blurry photo. It was almost dark1 point
Getting so close to wof-attempt time now, got windscreen squirters & fuel gauge going, chin spoiler on (+10 bhp) seats, door cards etc. Hopefully just re-attach the earth to the horn and a pair of tie-rod bushes (which I should really order) to go. Brakes work well with new fluid and various levels of abuse to free them up1 point
we had a roof shout and it was fucking great. approx 11 thousand people turned up and had great times. this is the last people standing. 2017-08-20_12-29-17 by sheepers, on Flickr1 point
That blue is nice! any pics with the decals on it? I'm trying to picture what they'd look like1 point
FUCK YEAH, Sweet looking machine you found there. such cool little cars!1 point
scooter started smoking like a 350,000km mitsubishi. when i put the head on, it felt like the exhaust valve retainer was hitting the top of the valve stem seal at full lift, i thought "meh, ill see what happens" and now i know. took 13 minutes to have engine out again and stripped. put the old head back on and no more smoking. still waiting on new rollers, i pulled the variator apart cause i had some new guide bushes for it, and removed 3 weights just to see what happens and it makes it rev better. the variator has some wear in it so probably need a new one of those next. and ordered a 52mm piston and barrel because moar powarr1 point
This cabin is taking forever to finish. I try to work on it every weekend, but it's taking a while. In good news there's two lots of paving down, two sets of stairs finished, about 600 baby trees moved into bags, and I've started on the cabin frame. It might be weathertight in December? Dunno. It's fun though!!!1 point
Hah turns out it was already a 70cc and the new piston makes it 84cc, not 100 cc as advertised I see why people mess around with scooters, had it stripped in 30 min. Found some grey paint that matched ok so painted the bits of frame that were modified The variator rollers were worn with big flat spots so hopefully the new ones make that work better .1 point
Have since taken a break from the car and regained enough motivation to get back into it. With the Kaikoura hop coming up its the perfect time too. Both the Viva and the KE20 will be driven up there in the hope they both make it! Since the last update not a whole lot has been done. The fix for it running badly was very simple and purely the car over fueling to heck because of the carb supplied by the previous owner. I have since put the original carb on it and it runs a treat. Next i will be getting it re-ready for a warrant hopefully this week.1 point
Okay, long overdue an update. Rust patches were sorted by the inimitable @Goat several months ago, sweet! Gearbox mount came together a couple of weeks ago, pretty pleased with it: Exhaust got some love last weekend. Please excuse horribad welds, I'm still new. Got a sweet new shirt: Also got a full set of nolathane bushes. Here's me downstairs bush collection: Rad mountings are also sorted, hurrah! Waiting on a brake kit from MRP, excite. Getting there now!1 point
Other end of the engine size scale, I picked up this non running scooter from Scrubb, what a top bloke. I got it home and managed to lose the key somewhere, I disassembled the ignition switch to get that working and it had some water in it, and the air filter foam had fallen to bits so maybe it had sucked some of that into the carb. Anyway after that it started, I fixed the indicators, made a new air filter out of a car wash sponge, cleaned it, and got rego on it. At first I thought there was something wrong with the clutch but it turns out it has a automatic 2 speed. I have had some funny looks when riding it.1 point
