HighLUX 32,891 Posted January 12, 2020 Report Share Posted January 12, 2020 Fixed the welder with a bit of wiring tracing and looking at stzz. Took out the circuit board behind the wire speed knob, cleaned years of garage dust/metal filling mix off the board which could of been bridging some circuits and doing something funny then there was a big grey box on the board that I guessed was a relay so gave that a tap with a screw driver and its back to working properly which is great because I didnt wanna have to buy a new welder 7 Quote Link to post Share on other sites
Nominal 56,781 Posted January 12, 2020 Report Share Posted January 12, 2020 Nice I got the Commondore engine running after pulling the injector rail out and spraying fuel all around the garage. Swapped a couple of dead ones with working ones from the old engine and it fires up OK now. Have to finish up the plumbing for the cooling system before test drives. 2 Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted January 14, 2020 Report Share Posted January 14, 2020 Because I'm too lazy to look up the glazing rule, How dark is the rear window of a ute allowed to be tinted? Quote Link to post Share on other sites
datlow 21,719 Posted January 14, 2020 Report Share Posted January 14, 2020 matt black /no longer a window maaayte 1 Quote Link to post Share on other sites
AllTorque 41,759 Posted January 14, 2020 Report Share Posted January 14, 2020 You can do what ever to the rear window of a Ute 2 1 Quote Link to post Share on other sites
Yowzer 33,977 Posted January 15, 2020 Report Share Posted January 15, 2020 How dumb is it that MA is restricted to 35% on the rear windows but everything else can be blacked out completely? What is the reasoning behind that? Quote Link to post Share on other sites
Bling 21,090 Posted January 15, 2020 Report Share Posted January 15, 2020 Business use type vehicle, well at least more often than MA standard car? Only reason I can think of. Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted January 15, 2020 Report Share Posted January 15, 2020 2 hours ago, AllTorque said: You can do what ever to the rear window of a Ute Can I ask what each class means? Quote Link to post Share on other sites
AllTorque 41,759 Posted January 15, 2020 Report Share Posted January 15, 2020 Go to tables and images https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/introduction/inspection-and-certification-process/identifying-the-vehicle-class you’ll be sorry you asked. 1 1 Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted January 15, 2020 Report Share Posted January 15, 2020 Would it need to be registered as a goods vehicle though? User type NA rather than MA? And perhaps have more expensive rego? (Its over 40 years old anyway, but it's nice to know so I dont get fisted by some.power tripping nazi copper at some.point) Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted January 15, 2020 Report Share Posted January 15, 2020 That said, it's not going to have metal mulisha/FOX etc stickers on the rear window either. 1 1 Quote Link to post Share on other sites
Popular Post SOHC 10,762 Posted January 15, 2020 Popular Post Report Share Posted January 15, 2020 I found if you cut open a Fram G12 in-line fuel filter you can jam it in your sedanent glass 11 Quote Link to post Share on other sites
SOHC 10,762 Posted January 15, 2020 Report Share Posted January 15, 2020 21 minutes ago, SOHC said: I found if you cut open a Fram G12 in-line fuel filter you can jam it in your sedanent glass Works in reverse tho, shit is going into the inside of the filter 1 1 Quote Link to post Share on other sites
kyteler 60,543 Posted January 15, 2020 Report Share Posted January 15, 2020 22 minutes ago, SOHC said: I found if you cut open a Fram G12 in-line fuel filter you can jam it in your sedanent glass This is relevant to my interests. Quote Link to post Share on other sites
AllTorque 41,759 Posted January 15, 2020 Report Share Posted January 15, 2020 2 hours ago, RUNAMUCK said: Would it need to be registered as a goods vehicle though? User type NA rather than MA? Having more load space than passenger it would always have been registered NA. 1 1 Quote Link to post Share on other sites
cletus 39,276 Posted January 15, 2020 Report Share Posted January 15, 2020 'Body transfer vehicle' Could apply to any car haha 4 Quote Link to post Share on other sites
TimShadboltfan27 4,780 Posted January 15, 2020 Report Share Posted January 15, 2020 my EF civic does this weird intermittent thing where it dies as soon as you disengage the key/starter. only does it sometimes, and you can keep the revs up and sometimes save it or hold the key on and keep the starter winding and it sorts itself out. this morning i had much trouble getting it to start and when it did it cut out a few times before i managed to save it with a bit of choke and mashing the throttle. I dont think its a usual culprit like a vaccuum leak or carb issue cos the car runs fine once it starts up (eventually). Am i right to suspect it may be the fuel pump? Google has suggested the ignition module as well but im leaning more towards fuel pump being a lemon anything else to check? anyone had similar issue? D15B motor. Quote Link to post Share on other sites
kyteler 60,543 Posted January 15, 2020 Report Share Posted January 15, 2020 Those Honda ign modules are notorious for fucking out but it would be unlikely if it runs fine afterwards. When the one on my City fucked out it wouldn't go at all, thats not to say that they don't have varying levels of out fuckery however. Is it mechanical or electric fuel pump? Are you sure it's not just that you're a noob with the choke? Quote Link to post Share on other sites
TimShadboltfan27 4,780 Posted January 15, 2020 Report Share Posted January 15, 2020 2 minutes ago, kyteler said: Those Honda ign modules are notorious for fucking out but it would be unlikely if it runs fine afterwards. When the one on my City fucked out it wouldn't go at all, thats not to say that they don't have varying levels of out fuckery however. Is it mechanical or electric fuel pump? Are you sure it's not just that you're a noob with the choke? lel i am proficient in choke operation m9 google says electric. looks like its an in-tank pump and i just filled it up. womp Quote Link to post Share on other sites
igor 12,791 Posted January 15, 2020 Report Share Posted January 15, 2020 My wife's Laser was hard to start for some months. Once started it ran fine. The problem was thought by many to be fuel related but eventually turned out to be a faulty ignition module. 2 Quote Link to post Share on other sites
