UTERUS
Everything posted by UTERUS
  1. UTERUS
    diesel spam
    J5 wrote what I was thinking. Sounds a lot like an exhaust valve not closing. I bought a cheap USB endoscope for peeking into impossible to see places, probably slim chance having one of those on the island though. https://a.aliexpress.com/_mLRaVpk
  2. Fuck that's cooked
  3. I've got a few ideas, depending on what you're trying to do and how much torque you need and power available to drive the motor. But yea, keen to know. Or PM if you want to keep it secret
  4. UTERUS
    Aubs gokart
    Hell yea, I need one of these.
  5. Those drivers are only expensive because they're 0-10V dimming control. You could use non dimming constant current driver instead. I might have a look later to see what will work
  6. Hello Joe, what you have there is a fucked armature. Kind regards, Simon.
  7. 50psi minimum
  8. I used a 2 speed electric one from a Volvo 850 I think, on my 13B. It was awesome. I might even have a spare one
  9. Fletch is bang on with charging advice, redarc stuff is really nice and safe but criminally expensive, keep an eye out for second hand stuff if you're not in a hurry. Run those panels in parallel, you'll want all the power you can get. I'd run a 24v winch from the main batteries and run a lithium house, have you got winch already? Unless you find a cheap PTO, that would be super sweet.
  10. Soap is cheap.
  11. @Nominal it's impossible to say without seeing it, I avoided doing drum bearings and seals because it takes forever and was never worth it.
  12. I've had some success with a desulphator and charger on a battery for a few weeks. https://a.aliexpress.com/_mNukyZN
  13. Like kpr says, they all do it. I've repaired lots of Digi dash stuff off that era too.
  14. They'll have the cable and lugs, but won't crimp them for you. Whatever you do, don't be tempted to solder them. You could try bribe an auto sparky to crimp them?
  15. 25mm double insulated flex is most commonly used. https://www.trademe.co.nz/3132796229
  16. I dunno why you're complicating this, just goto the tyre shop and tell the guy what you want. Buying second hand tyres can get fucked for a daily tbh, you gotta check the date code to see how long you got till they fall apart. I've used motor treads in the past and he's been great for doing exactly what I asked of him.
  17. This thread sucks, do you ever finish anything?
  18. It's only 6A, I'd just run it through a switch. Unless you really had your heart set on putting a relay in.
  19. How many watts is the light? I prob wouldn't even bother with a relay depending on what switch you have or going to get.
  20. Hell yea, I have fond memories of hectic nights on Thompsons. Kati side next?
  21. @kpr have you got any thoughts of cold (fridge temp) vs hot (50 ish?) petrol?
