Showing content with the highest reputation on 10/18/17 in all areas
Got word from the machine shop that I can pick my engine up on Thursday! it came in at under half what I expected to pay so I’m fizzy! they did new bearings throughout, frost plugs, ground crank, acid tanked block, resized rods, measured up the rotating, removed + cleaned + tapped and bunged the crank. tore the engine out after work in preparation, jazzed on a long weekend refit and run in. also got some lock nuts and maybe some freebie chrome wheel nuts. good week7 points
6 points
G'day All, Figured I may as well make a little project log thingy for my newest project, a '62 Morris Mini Minor. I picked this thing up not too long ago and have been getting stuck in with ambitions to have it done early next year. I've been on the hunt for a MK1 for ages now so I'm super stoked to get into it. The car had been stripped down and semi-restored some 20 years ago by the previous owner, but never quite finished. This has led to the paint deteriorating, and heaps of parts disappearing over time. This prompted me to buy a '62 parts car from some guys lawn for its engine/interior bits/suspension parts. I've got almost all of the parts for it now! Its just a matter of painting it and getting it back together and on the road again As far as plans go I'm still not totally sure what color id like it to be. Wheels can be changed to suit, but I guess paint's a different story. Was thinking something along the lines of a light metallic blue with an old English white roof, wide steels/mags and a mesh sun visor for that retro mod kinda look. Something that could be taken back to original spec if need be. Was even thinking of doing it black or just standard white, but I'm not too sure. Cheers guys, looking forward to getting more involved on the forum. -Jack. -The 850cc engine in the front end of the less than fortunate parts car. 25 years of sitting on a lawn didn't stop it from running - it fired right up the day after it fell out of the van and onto the driveway. Wasn't seized, and has only done 40,000 miles. Just hoping that the 850 will be enough for me to keep up with traffic!3 points
https://www.trademe.co.nz/motors/motorbikes/motorbikes/dirt-bikes/auction-1437134367.htm closes soon3 points
Oh no the wof has run out on my car! Guess I'd better come along anyway.3 points
Time for some go-fast bits! After a bit of searching around I managed to pickup a pair of twin SU carbs on a genuine cooper S manifold, accompanied by the 12G202 head, which supposedly flows much better than the original 850 head. A few months ago I also scored a full cooper style exhaust system including LCB extractors that lead to a single muffler in the rear. Of course, I couldn't wait to test out my new bits so I threw them on a thrashed (had a really hard life) 850 and attempted to tune my twin carbs. Long story short this didn't really work out as my manifold is missing its locating rings (which should arrive tomorrow). This meant that I destroyed two inlet gaskets, which created a huge air leak, and ultimately prevented the motor from running properly. Instead, it started up, revved until the valves couldn't let it go any harder, before quickly calling it quits and turning off again. Doing this multiple times with different gaskets yielded the same result. However, it gave me a good indication of what the car will sound like! The situation with the cylinder head is quite tricky. The standard compression ratio for an 850 is 8:3:1, which I understand is fairly low. Throwing my 12G202 head on there, which is from an 1100, will drop my ratio to 7:9:1! I believe this is really low, and am debating whether or not to get it milled, or to leave it as it is and bolt it down. Some say to bolt it on, some say to bring my compression up to 9:1 by removing 4.1cc from my combustion chambers. Has anybody put a 12G202 head on an 850 engine before? I'd really love some advice as cylinder head machining and compression ratios are new to me. The neat part about the twin carbs would have to be the interesting air filters. They're called a "Pressmaster" and are New Zealand made. Not sure if they're a rare piece nowadays, but they look neat. I've never seen them before. I've also ordered a heap of new bits which should be arriving tomorrow and will allow me to make some more progress on the engine. Cheers, Jack3 points
Right! I've made a good start on the mechanical's by getting into the little 850, and the front sub-frames. The engine is rumored to have traveled a mere 40,077 miles since it's birth in early 1962. It even had its original cast iron water pump and fan belt! I've deconstructed it enough for my liking (Short Block, the crank doesn't need to come out), and as soon as the gaskets and assorted new bits arrive it will be going back together. No lip on the lifters, bore, or any other parts. The clutch has a ton of meat left on it, and I didn't even snap any of the bolts off in the strip down That's always a plus! The grand plan is to give the engine a big birthday, new gaskets, thermostat housing and thermostat, water pump, hoses, fan belt, paint up, plugs, points, leads, extractors and a better carburetor. If the engine is anything to go by, then I'm expecting the gearbox to be in great shape too! As far as subframes go, I'm happy to have a pre '64 Mk1, as 1964 was the year hydrospastic suspension was introduced to the mini. Since my two front rubber cones sat still for 23 odd years, they've been naturally compressed and are holding their, so I'm expecting the car to sit a little lower in the front. After we construct a rotisserie, the body will be properly rust proofed and under-sealed. Then paint will follow. Even though I can understand doing a period correct colour, there aren't many solid colors that I actually like. I'm liking the looks of the light metallic blue on the new BMW mini's. Was thinking I could do this with an old English white roof for a sort of modern take on a classic (old mini with a new mini colour scheme kinda thing). Anyways, I don't currently have enough money to splash out on paint at the moment so I have plenty of time to think! Cheers -Jack3 points
Headhunters, Greazy Dogs. Some mongrels I think. I plan on just using my bike as a weapon for any gang fights.2 points
Need to get a set of Bluetooth headphones off Jack Ma so i can crank easy rider on repeat2 points
This is such a sweet name for an event. Would be lols to throw nobblies on the MC21 and come along. One day...2 points
I can probably rustle up a propa bike jacket/pants/gloves for ya, though they may be a bit small for ya. ya.2 points
There’s no artistic ability here, just scribbles tbh can giz a hoon next week though and pm a scribble through to you If you want though j52 points
I'm quite looking forward to this. Have just been reminded also, does anyone with an artistic ability or creative streak want to throw together some crayon scribbles for stickers/t shirts/posters?2 points
Not a bad idea, maybe I could vape into it then sniff out the source of butterscotch and hipster2 points
Gave the hinges a bit of a polish and made some nylon washers, it all should work well I hope. Need to find some wood for the bed now. Decided I should go back and finish mounting the front sway bar. Started by making some new mounts since the ones that came with the rubbers weren't very nice. Bolted it all down in the right place and stole the sway bar links off the rear since they need to be changed anyway. Needed to cut out the side of that gusset sorta thing on the front end that I made ages ago since the sway bar hit it when the front raises up. Another thing that my parents picked up in America was an ashtray that goes in the middle dash panel, since neither of the RHD dashes came with one. Could of used the LHD one but wanted to keep that dash complete to hang on the wall or something haha. Had to get a second hand one since they don't sell them separate from the whole dash panel, and they were never made in stainless so it will need to be painted or chromed.2 points
Progress Progress... My plan of attack is to get the front & rear sub frames + the engine completed by the end of the year. On my college budget this will be a stretch but I think I'm capable of getting it done! I have new lower arm bushes, engine stabilizer bushes, cv boots and dust covers all ready to be installed. Yesterday engine paint was brought. It's not the original engine color (or even close really) but I think it's an improvement over the standard military looking green engines that minis came with. Certainly brighter than what the cap on the tin said! But I'm liking it. The car isn't being restored to complete factory spec, so I'm not too fussed. I picked up another complete 850, this one's a 1964. Whilst it runs, its been run hot, and hard. Plus its really sludgy on the inside, so it'd probably make a good rebuilder, but for now it's provided me with some really good parts, namely a generator that's dead silent when it spins (quite hard to find quiet ones!) and a tidy starter motor, both of which I have restored. So far, I've got most of the front sub frame parts painted and ready to go back into the frame. The rear sub-frame is virtually finished bar one brake hose! Wish me luck. Jack.2 points
Reckon the Sunday'd be the go. Have a squizz at the cars followed by a beer or two at the Mataura pub to round off the day?1 point
I was going to sign off with that but I didn't think of it until after I'd clicked submit /lingor.1 point
As far as gear goes, at the end of the day it's up the the individual, would rather not have gravel rash wounds etc to deal with though. I'd recommend helmet, gloves and sturdy footwear as a minimum. Riding jacket and pants are worth considering if you've got them. Or at least some durable long pants/sleeves etc. + Wet weather things for the inevitable.1 point
You got a place lined up for stickers/posters? I can prolly get a deal through Steve, or you thinking Christian?1 point
Do I need to bring anything CT110 related? I'm not even concerned if it has wof/reg though if it needs it im happy to pay.1 point
So I don't actually own anything riding related except for a helmet. Is something more than a singlet and jandels advisable?1 point
RIDE STICKER DESIGN HAS BEEN SENT AWAY TO THE PRINTERS! BRING SOME CASH MONEYS ON THE DAY TO GET THIS ONE TIME ONLY OFFER ECT NEXT SUNDAY!?1 point
See you there @Threeonthetree, I could bring that laser with me?1 point
Now for some actual progress, sort of anyway. New levers came today, still a touch long but at least usable, really do want some BWS/Zuma/Jog 100 controls and levers though I think. Fitted the bars to the scoot, then fitted the levers to the bars Drilled out the adjuster thread on the rear to take a scooter style cable. Haven't got a throttle grip that plays nice with the Jog style controls (think there actually from a Kymco looking at the markings) So I tried out the Kitaco throttle and AliExpress switch Still undecided on them though, if I do run this switch I 100% will be running the lights through a relay and NOT running any decent current through the switch! Brake bled up nicely, lever has a nice feel to it etc too. Need to figure out a plan for combining early stage Gyro, late stage Gyro and custom wiring into a tidy cohesive loom!1 point
Hey @azzurro! Look what I found in a barn this weekend......1 point
I actually bought this not just because its cool, but because it was a similar price to a decent trailer, but with the benefit of being self propelled! Looking forwards to smug facing at the dump as i reverse up the small gaps between all the jack-knifed trailer + modern ute combos1 point
Just a reminder that this Meet takes place on Wednesday this week. @cletus I have a gift or two for you.1 point
Been daily driving this lately. No big issues. Still waiting on some Aliexpress electrical stuff before I put the dash back together. The 24v > 12v DC converter I ordered from Banggood arrived, nice 40amp unit. Changed the engine and gearbox oils. All 15l of them. Not including the 18l of coolant. Went to an Oldschool meat. Had a ride on an AA tow truck. ... wait what? Just a fuel bleed nipple fitting that decided to go missing... The empty looking spot near the filter. Didn't notice for a little too long... Diesel everywhere. Nice and clean under the truck now though. Back window has a nice sheen to it now also. Put a new fitting and filter on and she is all good now.1 point
Front end is all tacked up and sitting on its wheels!Happy times.Been some time since it has been rolling and its a good feeling seeing it all together upfront again.Air out its sitting pretty much where we wanted it. If you enlarge the above pic you will see the trans cross member is bleeping low. have a couple of inch clearance at this point air out. Ride height is about 2.5 inch higher so say 100mm or 110mm or so.Engine is offset 20mm to get clearance for the PS pump. Not really noticeable even when you are told.If you have been twisted enough to follow along with the progress of the build then you know the rear ends shockwave airbags mounts are adjustable. At the moment is in the middle setting. May bring it up to the highest setting. I do love that rake but the extra inch at the back will help level the carbs a bit along with all the other obvious benefits. Time will tell.Cross support and trans mount are all made up. Folded top hat with a flat bottom similar to the original Hudson braces. Bolt in for ease of access if in the future we ever need to do work under there. Front brace helps for body flex etc.Pic above gives a better idea of how low the braces are. Just lower than the trans pan to help protect it a bit with luck. You can also see eight (4 per side) front access holes to the bolts that let you remove the whole front clip. The whole idea with all this is ease of maintenance for future work.Next is taking out the engine. Welding up everything. Brace up some bits with some gazeting. Notching the front rails for bit more clearance on the steering arms. Drilling the panels holes and ya ... golden. Oh and trim those long ass rails and add the rads front brace. Sigh list goes on.And talking about panels... Flockie held them in place as i took a gander. Instant grin when I steeped back to have a look.We did this not only just to see how it would look but to check the tire clearance as there was a bit of concern the inner guard my hit the tire air out. Nope it was fine with heaps of room. You can see how much longer the chassis rails are as well. Easier to make em shorter than longer was the idea.And talking of Flockie who is doing the welding, math and all the hard stuff at the moment for me.... BAMLooking pretty happy with him self and rightly so. He has done some great work.Go like him on Facebook: https://www.facebook.com/flockieschassis/Oh and for a laugh check out my Buick gravel track fun vid on youtube here.1 point
Well well October Already!! my Samsung s8 screen broke so I lost all photos and is an update even an update without a photo?? got all the brakes sorted and managed to enjoy it more or less hassle free for a few hundred KM which isn't short of a miracle! I made it to Septembers caffeine n classics where a lot of barrying went on! Good times were had!! last sat took it for a drive and heading up a hill it died n I struggled for the next few hours fighting to keep it going, it would die pulling up to lights I checked fuel filter, checked leads and coil resistance revs were up n down it was sluggish n all round crappy. found an electric ignition kit I ordered it so that'll turn up before weekend, also have another carb I'll try. The one on seems clean enough inside but just gotta work thru it mean eh1 point
took the front end off to tidy it up and remove the lights. One of my favourite jobs is cleaning the muck out from light lenses, seems to make such a big difference to the appearance for the sake of a bucket of soapy water. WHile i had that off it would be rude not to see if the 20 year older italian Fiat 125 chrome grill will fit in the usual spot. It will but it about 20mm wider than the plastic one and covers the edge of the inner light, so yeah, but nah. Car has been sitting around for a while not being driven. Tracing why this side repeater (this one is odd and from a Toyota of some sort) is non operational Deja vu is when they change something in the Matrix But is otherwise pretty straight1 point
When kids ask what's the point of Maths, from now on I'll be able to reference you/this diagram...1 point
