  • Replies 135
Growing up we had a 720 king cab as our only family vehicle. I was 6ft tall when it was finally replaced. I've always lusted after one of these or a Hilux xtracab.
  • Haha 1
Shit yeah this is mean
my dad used to have a horrific z24 d21 that’s had a knockey z18 put in as the noisiest gearbox I’ve ever heard. I did some much towing and roadies in that thing and it never let me down.
The best part is that 6 stud wheels have an  "anti tax" on them. You can get really sweet reyums for 1/3 or 1/4 the price of the same wheels in four of 5 stud.
Its fucking brilliant!
Cool rig Beave.
Haha yeh they are definitly cheaper. Probably because everyone else is just putting d windows on their Utes lol.
If anyone has some sweet 6 stud rims stashed away I'm all ears
Yeah lush whip. Just a thought, if some dweeb has whipped out the thermostat then you would guess it got hot at some point (unless just total durp) if you say the water was gross then high chance the rad has some shit in it, would look into getting it cleaned at minimum. So many old radiators you assume are sweet can cock you over once you load it up.
Yeh I broke my own cardinal rule which is don't even bother fucking around with temperature related problems until you know for 100% that the radiator is good.
You're right though, I should just get it done properly.
Fwiw my td27 d21 had wrong temp thermostat in it and temp sender for glow plugs disconnected. Fixed that and replaced water pump with a unit with actual fins on the impeller and it’s mint.
sweet ute!
have found that white vinegar is good for cooling system flushes. put couple litres in with water and let it run through a few heat cycles and drain it.
it surprised me how much crap came out.
18 hours ago, Beaver said:
Still hunting for some choice wheels.
When are you coming to pick up the set of 16x8 Crags
