  • Replies 7.4k
sounds like the best plan.  unless its a rev monster and its well over 350 hp wont need more than 20-25gph anyway
i had in my mind the larger body ones are higher psi mostly. not just volume
3 hours ago, NickJ said:
Does 5/8 fit in 3/4? sounds like a custom fitting rather than bush?
3 hours ago, HumberSS said:
I'd be busting out the tig
It may be custom lots of options for 3/4" bsp  to 1/2" bsp
Might have to drill a 3/4" to 1/2" adapter out and retap need a 21mm hole to tap 5/8" bsp (22.99mm) 1/2" is 20.99mm so only 2mm smaller
3/4" bsp is 26.44mm
Need to see if I have a tap that will work.
I've got some quick release fittings that are 3/4" male to 5/8" male that I'd like to be male to female. To buy the same complete fitting in the female option its 17.5 each and I need 6 of them.
3/4 to 1/2" bushings are about $2 each and worse case a taps $40 so I'm still ahead
Don't want to use a 3/4" female to female as can't add length
Edit Actually that won't work
What I have on the left and what I need on the right
Guess I'll bite the bullet and buy new fittings
I want to activate a relay, but I only want it to close the circuit when another circuit is broken.
ie I only want the second circuit to run when a limit switch has disconnected the first.
But I dont necessarily want the second coil to be energised all the time.
Is there a devious way to achieve this passively?
22 minutes ago, NickJ said:
Can you substitute a different switch in?
Not really, it has a limit switch that breaks the circuit once in position. I need to use the break as the ok go signal for the next thing.
Sounds like Nick might be on to it with DPDT? Use one NC to common terminal to open at limit, then the other common to the other NO terminal, which closes to enable your 'next, Go!' signal? Or 2x SPDY limit sw if they don't do DPDT?
Of course, if you supply full cad drawings and all your Arduino code, I pinky promise I won't steal them and get zillions made in China
Oof. I did a reading fail. How much coil current becomes a problem? Is 10mA for an SS relay too much?
Also, I think there are set/reset relays that only consume energy at change?
Ah, run your relay off the NC terminals of the limit sw for the first stage parallel to the motor, so it switches off with the motor at the limit, then you have the NC terminals on the relay will relax closed, to drive the next thing. You'll have those NAND/NOR/1 bit sadder gates going in no time!
This is so obvious I am smacking my forehead.
Doing the rear wheel bearing on the Marina, do I need to drain the diff first? It's a borgwarner diff, similar to what's in escorts, capris, Datsuns of the time.
