8 hours ago, Bling said:
What do you need to power? Haven't done it myself but from what i've seen, if the car is "on" you can run an inverter off the 12V battery and it's charged by the main battery. If I got a bunch of power cuts i'd likely be doing that myself for critical appliances.
Sounds good, but check the power limits - draw too much, you may find you discharge / damage the 12V, which will then be tricky to see once the HV to 12V tops off the (now weak for current) 12V battery
  • Replies 7.3k
Yeah that's why I question how much needs to be powered, you wouldn't want to draw much off it. Battery out of car with BMS will be the way to go. I wouldn't try and run my 16kW heatpump, but it would be able to run fridge / gas hot water / internet and maybe a TV. That keeps those indoors happy enough. Like I say, never tried it as power is reliable thankfully. But have seen it done a bit by those overseas with lackluster power supply.
Looking at doing solar to run the 3 freezers and hot water.
Being able to buy a leaf with 60-70% SOH well under 3k would make a perfect back up, and I could do rainy day town stuff in it too
I do have a 1/2 built prototype design for a round-robin load-sharer, exactly for running multiple freezers etc off a limited supply.
E.g, drop the freezer when you hit the microwave, then restart the same one while the compressor is charged, then after the first one reaches temeperature set-point, start the next one .
It's probably smartest for my hyperactive brain to buy a leaf preemptively for a project I'll get bored of in a month.
But at the price, that's a lot of battery capacity. You just have to dispose of the car. I could design a battery bank area off the side of the shed I haven't built too.
Edit a 67% SOH leaf I was thinking about and forgot just sold for 1650 in Hastings. A similar one went for 2100 in gisborne the other day
  • Haha 1
If you like to turn down your monitor brightness at night to help sleep, this system tray applet does that (if your monitors are connected with digital cables) https://github.com/emoacht/Monitorian
If Windows messes up your 1823.6 windows and you can't friggin' find anything after patch Tuesday reboots, this widget will automagically put them back https://github.com/kangyu-california/PersistentWindows
So steering tie rod end just fouls inside of 14in wheel, very tempting to bend the steering knuckle but I know its frowned upon, thinking about grinding a few mm off tie rod end... any ideas? Not super keen on wheel spacers as there's not much clearance tyre to gaurd either... must be a way. (rx2)
Had this issue with my Gmc. Drop spindles and stock 15" rims cause clearance issues with tie-rod and lower balljoint. They like to peel off wheel weights.
I found a smaller bodied tie-rod end which helped a little, but I also decided it was sensible/easier to have a few mm slip on spacer lasered to suit and be done with it.
Don't bend knuckles, not worth the risk.
1 hour ago, 440bbm said:
has it got big RCA's on it?
also. u got a 2 now?
Has RCA's but they make no difference as they are above the steering arm.
You might be thinking of someone else, had 2 for a long while (definitely could not afford to buy one now)
Fair.
Sorry, struggling to remember the setup on them now. its been a few drinks, ok ok yes few too many pies.
Memory definitely failing me today then soz!
  • Haha 1
If you want to get crazy, and you are certing it regardless, you could possibly replace the tie-rod end with a heim/rose joint. Either drill/ream the taper to be straight for a snug fitting bolt, or have a tapered adaptor machined to suit.
But yeh, would need to discuss with cert man first, and its a bit of work.
I like it, I knew you guys would come up with something.
Everything is a bit (lot) of work, was just looking at the white 2 in the rotary thread thinking maybe I should just put it all back to factory.
4 minutes ago, RXFORD said:
If you want to get crazy, and you are certing it regardless, you could possibly replace the tie-rod end with a heim/rose joint. Either drill/ream the taper to be straight for a snug fitting bolt @cletus - Keen?, or have a tapered adaptor machined to suit.
This kinda thing.
Would need a mis-alignment spacer to stop it from binding throughout suspension travel. Have to check that it would actually help your situation by the time a mis-alignment spacer is fitted though.
There is enough meat to cut the taper with wide end on the top instead of the bottom and have more than the 8mm min wall, so I could I guess move the rod end above the steering knuckle instead of the factory orientation with rod end below arm.
That will completely fist the geometry though
You would need to raise the inner joint pivot the same amount, or it would cause a large amount of bump steer
