Snorkpipe Posted August 31, 2022 Share Posted August 31, 2022 Looks like it'll only fit in the hub one way Quote Link to comment Share on other sites More sharing options...
SOHC Posted August 31, 2022 Share Posted August 31, 2022 2 hours ago, Snorkpipe said: Looks like it'll only fit in the hub one way They go on the stub and then press on to a tin cover witch is presed into the end of the hub Quote Link to comment Share on other sites More sharing options...
GregT Posted August 31, 2022 Share Posted August 31, 2022 If it's a single lip seal, the lip always faces the lubed side. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 1, 2022 Share Posted September 1, 2022 Looking at hose clamps for my radiator hoses. What is the OS hive minds opinion of T bolt clamps, versus standard style screw driver hose clamps? I guess anything is better than the wire hose clips used by the factory.  What does everyone reckon? Quote Link to comment Share on other sites More sharing options...
datlow Posted September 1, 2022 Share Posted September 1, 2022 We use them at work, theyre legit But its onto metal nipples I reckon you could over do it on plastic radiators? Prob why this style exists? Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 1, 2022 Share Posted September 1, 2022 2 hours ago, RUNAMUCK said: Looking at hose clamps for my radiator hoses. What is the OS hive minds opinion of T bolt clamps, versus standard style screw driver hose clamps? I guess anything is better than the wire hose clips used by the factory.  What does everyone reckon? Factory wouldn't use shit clips. 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 1, 2022 Share Posted September 1, 2022 Factpry stuff is built to a price. I was hoping that someo e whi tuens spanners for a living would chime in. Quote Link to comment Share on other sites More sharing options...
Bling Posted September 1, 2022 Share Posted September 1, 2022 I just have screw on ones on the project as it's what I had in the garage. If the pressure in the system is enough to blow those off I probably have bigger problems. That's my theory anyway. The other car still has all of these on it:Â 2 Quote Link to comment Share on other sites More sharing options...
Metalhead96 Posted September 1, 2022 Share Posted September 1, 2022 25 minutes ago, RUNAMUCK said: Factpry stuff is built to a price. I was hoping that someo e whi tuens spanners for a living would chime in. BMW/Merc spring clamps feel nice pinging across knuckles 1 Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted September 1, 2022 Share Posted September 1, 2022 6 hours ago, RUNAMUCK said: Looking at hose clamps for my radiator hoses. What is the OS hive minds opinion of T bolt clamps, versus standard style screw driver hose clamps? I guess anything is better than the wire hose clips used by the factory.  What does everyone reckon? personally would just run standard screw driver style clamps but the ones with no holes in them as it bites into the hose. can buy black ones too. i personally like zebra brand ones from wurth. And can't really overtighten the item as the clamp just strips too  have seen T bolt style clamps on standard rubber radiator hoses cut the hose on the edge of the clamp causing them to leak but that could be because they were overtighten or that brand were sharp on the edge. but personally think they can be quite bulky looking.  1 Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted September 1, 2022 Share Posted September 1, 2022 1 hour ago, Bling said: I just have screw on ones on the project as it's what I had in the garage. If the pressure in the system is enough to blow those off I probably have bigger problems. That's my theory anyway. The other car still has all of these on it: these clamps are a cheap and simple and quick clamp to use when in a production line. which is why they are used but are more of a single use clamp as once they have been opened and closed a few times can cannot provide enough clamp pressure to stop coolant seeping past. And they can be tricky to get off or move and are good for making you bleed or flying across the room.   1 Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted September 1, 2022 Share Posted September 1, 2022 On 31/08/2022 at 20:32, SOHC said: Witch way wound would one fit this hub seal? It dosnt have a spring and is totaly different to the old ones looks like that side would be the outside. and the other side would press into the hub. hub and spindle setup im guessing? as i cant see any other way the seal would be retained to the hub most style seals ive used like that have a steel other flange and bottom steel ring to press into a hub. but the photo you put up doesn't look like its a steel ring to press in  1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 1, 2022 Share Posted September 1, 2022 10 hours ago, datlow said: We use them at work, theyre legit But its onto metal nipples I reckon you could over do it on plastic radiators? Prob why this style exists? Radiator hose nipples are aluminum. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 1, 2022 Share Posted September 1, 2022 9 hours ago, piazzanoob said: looks like that side would be the outside. and the other side would press into the hub. hub and spindle setup im guessing? as i cant see any other way the seal would be retained to the hub most style seals ive used like that have a steel other flange and bottom steel ring to press into a hub. but the photo you put up doesn't look like its a steel ring to press in  Thats the way I ended up fitting it, it slides down the stub and that steel plate is just a shield, I tried fitting it the other way with the hub packed with grease and some oozed out. Quote Link to comment Share on other sites More sharing options...
kws Posted September 1, 2022 Share Posted September 1, 2022 10 hours ago, piazzanoob said: these clamps are a cheap and simple and quick clamp to use when in a production line. which is why they are used but are more of a single use clamp as once they have been opened and closed a few times can cannot provide enough clamp pressure to stop coolant seeping past. And they can be tricky to get off or move and are good for making you bleed or flying across the room.   I believe they also have the added benefit of keeping a nice constant tension over a wide range of temps and pressures, instead of cutting into the hose as it expands. Just because they're cheap, quick and factory, doesn't mean they're shit. 5 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted September 1, 2022 Share Posted September 1, 2022 The Toyota ones are especially good as they have little locking tabs that let you lock them open during servicing 1 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 2, 2022 Share Posted September 2, 2022 I use long nose vise grips for that.  This particular Vehicle will require a motor out job any time I blow a gearbox or clutch. So I'd like it to be easy to pull apart too. Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted September 2, 2022 Share Posted September 2, 2022 1 hour ago, RUNAMUCK said: I use long nose vise grips for that.  This particular Vehicle will require a motor out job any time I blow a gearbox or clutch. So I'd like it to be easy to pull apart too. better use these then....... or get better clutch/gearbag : 5 Quote Link to comment Share on other sites More sharing options...
kws Posted September 2, 2022 Share Posted September 2, 2022 1 hour ago, RUNAMUCK said: I use long nose vise grips for that. My life improved a lot once I got the proper hose clamp tool for these. Locks and cant slip off the tangs. So good. 3 Quote Link to comment Share on other sites More sharing options...
datlow Posted September 2, 2022 Share Posted September 2, 2022 Well if you want ease of motor/radiator removal https://pitstopusa.com/i-5066125-aeroquip-aluminum-male-quick-disconnect-radiator-cooling-refill-coupling.html Spill free disconnection..... And get a bulkhead fitting for the wiring too 1 1 Quote Link to comment Share on other sites More sharing options...
