shizzl Posted September 17, 2022 Share Posted September 17, 2022 2 minutes ago, cletus said: A big angle on a driveshaft u joint and a grease nipple binding up? I considered that but no, angles are nice and nothing has changed since the previous engine was in there and driving 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 18, 2022 Share Posted September 18, 2022 Waft some paint in the bellhousing and see if there's any marks In it? Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 18, 2022 Share Posted September 18, 2022 Looking at the box that was in it, there are no witness marks from anything Quote Link to comment Share on other sites More sharing options...
ajg193 Posted September 18, 2022 Share Posted September 18, 2022 Do you have a video of what is happening? Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted September 18, 2022 Share Posted September 18, 2022 22 hours ago, shizzl said: has to be something in the flywheel/clutch situation. But I don’t understand what it could be. the old box shifts through all gears nicely still . dumb is the clutch operating as it should ? had a spigot bearing fail once and jammed itself in the pressure plate. felt like clutch was releasing, but it wasn't Quote Link to comment Share on other sites More sharing options...
JustHarry Posted September 18, 2022 Share Posted September 18, 2022 @shizzl So the motor starts . And runs fine? And goes into gear in with your foot on the clutch? So the clutch is probbaly fine. And the car rolls round the workshop when the box in in neutral. But you put it in gear and try drive it it jams? What if the driveshaft is out and it's in gear. Does it spin fine? Maybe just take coil wire off and crank on starter so you dont spray gearbox oil everywhere out the back 1 Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 18, 2022 Share Posted September 18, 2022 Just jacked it up, chucked in first and spun it over in gear no ignition. normal. Same in reverse. so the issue is only when it’s running and letting the clutch out Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 18, 2022 Share Posted September 18, 2022 Will try it with the driveshaft out later after the whinging neighbour is gone so I can start it Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted September 19, 2022 Share Posted September 19, 2022 30 minutes ago, shizzl said: Just jacked it up, chucked in first and spun it over in gear no ignition. normal. Same in reverse. so the issue is only when it’s running and letting the clutch out whip the box out and check the clutch. sounds more and more like the spigot bearing issue i had Quote Link to comment Share on other sites More sharing options...
Mof Posted September 19, 2022 Share Posted September 19, 2022 Can you push roll the car on the floor in neutral? Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 19, 2022 Share Posted September 19, 2022 54 minutes ago, smokin'joe said: whip the box out and check the clutch. sounds more and more like the spigot bearing issue i had Nah the bearing is fine, I checked it when I swapped the box on Friday. Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 19, 2022 Share Posted September 19, 2022 48 minutes ago, Mof said: Can you push roll the car on the floor in neutral? Yes. only happens while it’s running Quote Link to comment Share on other sites More sharing options...
tortron Posted September 19, 2022 Share Posted September 19, 2022 Could the crank be wandering? Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 19, 2022 Share Posted September 19, 2022 I'm wondering 1 Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 19, 2022 Share Posted September 19, 2022 1 hour ago, Nominal said: I'm wondering I wondered home. Even Stirling clutch dont have a clue what it could be.. might need a physic medium or whatever those jokers are Quote Link to comment Share on other sites More sharing options...
mjrstar Posted September 19, 2022 Share Posted September 19, 2022 Could the clutch release fork or release bearing be catching on the pressure plate, ie its moved out of the way when the clutch is depressed and gets hung up when released... What sort of noise does it make when it doesn't go? Does it stall the engine when you let the clutch out? Quote Link to comment Share on other sites More sharing options...
shizzl Posted September 19, 2022 Share Posted September 19, 2022 18 minutes ago, mjrstar said: Could the clutch release fork or release bearing be catching on the pressure plate, ie its moved out of the way when the clutch is depressed and gets hung up when released... What sort of noise does it make when it doesn't go? Does it stall the engine when you let the clutch out? No noises, just stalls on release clutch fork and bearing has some movement at rest so feel normal. Quote Link to comment Share on other sites More sharing options...
mjrstar Posted September 19, 2022 Share Posted September 19, 2022 5 minutes ago, shizzl said: No noises, just stalls on release clutch fork and bearing has some movement at rest so feel normal. Can you bar the engine over at rest with the clutch disengaged? Quote Link to comment Share on other sites More sharing options...
Mof Posted September 19, 2022 Share Posted September 19, 2022 On 18/09/2022 at 13:58, ajg193 said: Do you have a video of what is happening? 3 hours ago, shizzl said: No noises, just stalls on release clutch fork and bearing has some movement at rest so feel normal. Yeah can we get a video of it happening? Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted September 19, 2022 Share Posted September 19, 2022 Have you tried running it in gear on axle stands? Quote Link to comment Share on other sites More sharing options...
