Snorkpipe
Everything posted by Snorkpipe
  1. Sorry, very slow reply. How many horsepower do you need? How much do you want to spend? 4cfm 1hp https://shop.snapon.com/product/Heavy-Duty-Die-Grinders/1-HP-Heavy-Duty-Die-Grinder-(Red)/PTGR400 3cfm 0.5hp https://shop.snapon.com/product/Die-Grinders/1-2-HP-Die-Grinder-(Black%2FRed)/PTGR200 1.7cfm 0.3hp https://shop.snapon.com/product/Die-Grinders/1-3-HP-Mini-Die-Grinder/PTGR100 cheap 4cfm 0.3hp https://shop.snapon.com/product/Die-Grinders-(Blue-Point)/Standard-Air-Die-Grinder-(Blue-Point)/AT105
  2. I daily a Microsoft Surface Pro 2 with a hard case and keyboard. It's mint, similar environmental conditions to you. If you're working with it, and have Microsoft on your main computer it keeps everything easier and more professional than swapping between Android and MS. Apple can get fucked
  3. How big an area do you need? Truck brake pot diaphragms might do the job
  4. Could be a possible. May be in mid-school E46 though
  5. I think after a week, people will stop trying to push the boundaries and take the piss. At least I hope so. Those who are working are volunteering to take on the risk of infection in order to keep people alive.
  6. My guess would be yes. I do believe that local garages are allowed to operate for similar reasons if needed. Most are using a telephone call out type service
  7. VTNZ, VINZ, and AA will be open for essential services vehicles only. No private vehicles. If your vehicle is used in the support of life, then join the queue at their lane, don't get out. They will come to you, they will judge your need, if they deem you are not essential service they will turn you away. Don't try to take the piss. If in doubt you're probably not essential
  8. May I recommend you buy brand new if going for a set of carbs. A new set of RS34 out of the states are cheaper than 2nd hand here, and not all worn out and broken. I bought some 2nd hand RS36 and then some brand new TMR40. Never again will I buy 2nd hand carbs
  9. Snorkpipe
    PAINT THREAD
    Have you tried your local Wurth guy?
  10. The sticker is still valid, but the car is not road legal due to being not up to WOF standard, no different to going for a fresh wof then throwing a set of slicks on
  11. Snorkpipe
    PAINT THREAD
    Is that an open offer? at some stage in the next few months, I'd like to get something like this done:
  12. It must be time to organise next month's one. being Spring and all. Also, daylight saving rolls out in 10 days.
  13. Ignitech motorcycle ignition control unit. Trying to rig up a quich shifter ignition cut-out
  14. Does anyone know how I could convert a piezo-electric signal into somethin a control unit would see as either high or low input? The pieze has around 1V AC, and the control unit wants either 12V DC, or ground as it's input? I have tried using a transistor to pull the control unit to ground, but that was unsuccessful
  15. Huge numbers of old japanese bikes had poor connections between the phases of the stator and the reg/rec. Probably worth checking too.
  16. Testing after the fuel filter should give an approximation of rail pressure. Depends if you have any restrictions in the hose between the two though.
  17. What age engine? Anything after M52 had a schraeder valve on the fuel rail
  18. I agree, that's why I had my fast friend ride it while I rode my R1.
  19. It's pretty cool when your 33 year old bike beats modern machines
  20. That's a peach. Oil cooled Bandit motor with GSXR cams and high compression would be a wicked sleeper
  21. USD ruins the look as well. Using the right springs and cartridge emulators will well andtruly update the forks. NZ has a few guys who specialise in MC suspension, but I just import my parts off fleabay usually. Where are you getting the shock from?
