Steelies Posted August 10, 2017 Share Posted August 10, 2017 yeah rad, will def anneal this time round. ground rods came back with about a 0.004mm bow in them without annealing, will post results when the next lot come back in a few months. Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted August 11, 2017 Share Posted August 11, 2017 Let's talk Bout cats my life is around half over. I'll be long dead before climate change is a problem. Is ditching catalytic converters worth the effort? I don't drive behind me, so I give zero Fucks what comes out the back. Quote Link to comment Share on other sites More sharing options...
Mof Posted August 11, 2017 Share Posted August 11, 2017 Yes Lose it Quote Link to comment Share on other sites More sharing options...
Yowzer Posted August 11, 2017 Share Posted August 11, 2017 6 minutes ago, RUNAMUCK said: I'll be long dead before climate change is a problem Aah, the baby boomer mentality. I hope you know you're one of them. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted August 11, 2017 Share Posted August 11, 2017 But yes, ditch the cat. Fuck it right off. 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted August 11, 2017 Share Posted August 11, 2017 I might have an incling. But zero Fucks are given. I shold swap them for resonators no? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted August 11, 2017 Share Posted August 11, 2017 1 minute ago, RUNAMUCK said: I might have an incling. But zero Fucks are given. I shold swap them for side exits no? 3 Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted August 11, 2017 Share Posted August 11, 2017 Plus aNY one of the men who worked from 1850 til 1950 shoveling coal into a steam engine did for more damage to the planet than I ever will. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted August 11, 2017 Share Posted August 11, 2017 Not really. Your resource usage trumps theirs a hunnid fold. 2 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted August 11, 2017 Share Posted August 11, 2017 If you are talking about ditching the cats in your new daily, I wouldn't. Modern stuff have oxygen sensors after the cats to check they are working and will bring on the CEL if removed. Quote Link to comment Share on other sites More sharing options...
M.H. Posted August 11, 2017 Share Posted August 11, 2017 8 minutes ago, AllTorque said: If you are talking about ditching the cats in your new daily, I wouldn't. Modern stuff have oxygen sensors after the cats to check they are working and will bring on the CEL if removed. Easily fixed be spacing them out Quote Link to comment Share on other sites More sharing options...
Yowzer Posted August 11, 2017 Share Posted August 11, 2017 Uh. You really don't know a lot do you? But yah if you have a post-cat sensor ya can't easily ditch it. On the other hand, if you don't have a post-cat oxygen sensor you're all good. If it has a temp probe on the cat, more than likely it ain't gonna give a fuck if it's unplugged. Test it first though. Quote Link to comment Share on other sites More sharing options...
Popular Post Steelies Posted August 11, 2017 Popular Post Share Posted August 11, 2017 so, jam jars filled with the correct gas and your sensors dangling inside them, a bunch of cheap slimy electrical tape, SHAZAM?!?! i know, brilliant. 14 Quote Link to comment Share on other sites More sharing options...
kws Posted August 14, 2017 Share Posted August 14, 2017 On 8/11/2017 at 22:37, 00quattro00 said: Easily fixed be spacing them out Doesn't always work, especially if it's German. Car too serious to fall for that. 3 Quote Link to comment Share on other sites More sharing options...
TimShadboltfan27 Posted August 18, 2017 Share Posted August 18, 2017 Have you guys got any ideas for improving cold starts ? My SR250 is taking a good 10-15 minutes of 1/4 throttle before sustaining idle. Cant leave it to idle on its own even with full choke as it dies. Have put a fresh plug in it and gave the carb a cursory once over with injector cleaner, hasnt made any decent improvements. I was assuming its just been the cold weather, but even with daily use its not getting any better. TIA Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 18, 2017 Share Posted August 18, 2017 intake air temp sensor reading wrong so wrong warmup enrichment? Quote Link to comment Share on other sites More sharing options...
TimShadboltfan27 Posted August 18, 2017 Share Posted August 18, 2017 shes just a wee 250cc single, aint no sensors for miles cob Quote Link to comment Share on other sites More sharing options...
cletus Posted August 18, 2017 Share Posted August 18, 2017 On 8/11/2017 at 22:07, RUNAMUCK said: Let's talk Bout cats my life is around half over. I'll be long dead before climate change is a problem. Is ditching catalytic converters worth the effort? I don't drive behind me, so I give zero Fucks what comes out the back. If it's registered after 2010, it's a wof failure to remove cats. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 18, 2017 Share Posted August 18, 2017 2 hours ago, Nick Ritchie said: shes just a wee 250cc single, aint no sensors for miles cob ah, I thought it was injected because you were talking about injector cleaner just adjust where the throttle plate sits at idle then? if you have a manual it should tell you where the adjustment should be. alternatively, adjust it until it runs Quote Link to comment Share on other sites More sharing options...
TimShadboltfan27 Posted August 18, 2017 Share Posted August 18, 2017 Oh yeah carb cleaner /injector cleaner same aussie export junk. I tried turning the idle up a bit but once warmed up she idles way higher than normal, which isn't ideal. Tryna figure out why its taking so long to warm up really Quote Link to comment Share on other sites More sharing options...
