Leon Posted June 12, 2019 Posted June 12, 2019 On 10/06/2019 at 14:04, Tender Raisin said: Can you tow a car with no WOF or registration behind a car? Or does this come into a trailer category and you need WOF & registration? Scenario. Work is having a track day at Ruapuna Raceway, 10min from my house. To Hire a trailer for the day is $250. Just looking for other options. https://www.nzta.govt.nz/assets/resources/factsheets/27/docs/27-exempt.pdf Using an unregistered vehicle on any other road Using an unregistered vehicle on any road other than a private road is illegal. However, if you’re fined, you may have a defence. It’s your responsibility to prove that you’re entitled to use an unregistered vehicle in that situation. You’ll have a defence if the vehicle is: edit snip • a motor vehicle normally propelled by mechanical power that is being temporarily towed (one time, not regularly) without the use of its own power 2 1 Quote
NickJ Posted June 12, 2019 Posted June 12, 2019 5 hours ago, Mof said: Apparently two spot lights or two light bars are ok on high beam as they are symmetrical... I put a piece of black tape down the middle of mine at wof time, old mate didn't see the joke 3 3 Quote
smokin'joe Posted June 12, 2019 Posted June 12, 2019 4 hours ago, Leon said: • a motor vehicle normally propelled by mechanical power that is being temporarily towed (one time, not regularly) without the use of its own power so nobody told anyone at Ashburton Car Club, did they ?? !!! Quote
SiRge Posted June 12, 2019 Posted June 12, 2019 Have a look at wof rules but not clear. Rear quarter windows, can you replace them with composite? I seem to recall aaaages ago a friend registered their car as a van or something then suddenly it opened up options for putting blackout vinyl on the rear side and rear window as they pleased. Figured if that were true, then maybe could make a fibreglass plug for them instead. 1 Quote
Ghostchips Posted June 12, 2019 Posted June 12, 2019 I recall someone saying they did that. Registered as a commercial vehicle and was allowed to black out the back. The penalty was something like $550 a year rego'. This is third hand info' and may be out dated. 1 Quote
Roman Posted June 16, 2019 Posted June 16, 2019 Hello, I'm making some engine mounts and I'm aware that for cert, I need some sort of restraint on the mount. So that if the rubber breaks, the engine cant move and jam the steering. I've bought the hobby car manual section on engine mounts but it didnt give me too much more advice on what I might do here. This is my current situation, Altezza Engine mount and Land Rover rubber mount: This is what I'm thinking, making it out of 100 CHS that comes up around the alloy part as well to stop it from being able to drop backwards. With a 4mm plate inside that it sits on. Would this be alright? Or would it be better made from sections of flat plate? I'd like to make it as light as possible. Printed a test copy which surprisingly holds the engine weight fine made from plastic haha. 2 Quote
Roman Posted June 17, 2019 Posted June 17, 2019 Ahh nevermind. Will just have a simple base part then make a cover that comes down from top to constrain it. Quote
allan Posted June 17, 2019 Posted June 17, 2019 Ive had some 4x100 rotors drilled to 5x100 by an engineer , the centre bore is snug the hub ring is this able to be certified? or do i need to fill the 4x100 holes? Quote
cletus Posted June 17, 2019 Posted June 17, 2019 It looks a bit rugged but I've had the go ahead from lvvta a couple of times for the same mod when I've asked One of the faqs on the website says it can't be done but that was from a long time ago Quote
cletus Posted June 17, 2019 Posted June 17, 2019 8 hours ago, Roman said: Hello, I'm making some engine mounts and I'm aware that for cert, I need some sort of restraint on the mount. So that if the rubber breaks, the engine cant move and jam the steering. I've bought the hobby car manual section on engine mounts but it didnt give me too much more advice on what I might do here. This is my current situation, Altezza Engine mount and Land Rover rubber mount: This is what I'm thinking, making it out of 100 CHS that comes up around the alloy part as well to stop it from being able to drop backwards. With a 4mm plate inside that it sits on. Would this be alright? Or would it be better made from sections of flat plate? I'd like to make it as light as possible. Printed a test copy which surprisingly holds the engine weight fine made from plastic haha. Could you use a rubber mount that already has a locking system? Another way could be to make a 'hook' that catches the engine mount bracket 1 Quote
cletus Posted June 17, 2019 Posted June 17, 2019 On 12/06/2019 at 23:03, SiRge said: Have a look at wof rules but not clear. Rear quarter windows, can you replace them with composite? I seem to recall aaaages ago a friend registered their car as a van or something then suddenly it opened up options for putting blackout vinyl on the rear side and rear window as they pleased. Figured if that were true, then maybe could make a fibreglass plug for them instead. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/introduction/inspection-and-certification-process/identifying-the-vehicle-class I guess if you could make it meet the requirements to be NA class then that would be possible Quote
AllTorque Posted June 17, 2019 Posted June 17, 2019 To be “NA” you need more cargo area than passenger. Like no rear seats in a wagon. Quote
BlownCorona Posted June 18, 2019 Posted June 18, 2019 Can anyone tell me if i can cut/enlarge existing large holes in my radiator panel to fit inter cooler hoses though? heard no end of conflicting info. not really sure how im meant to get pipework out in front of the radiator if i cant. will need to be cert able. Quote
cletus Posted June 18, 2019 Posted June 18, 2019 Usually no problem if it's just a single skin radiator support panel. Quote
BlownCorona Posted June 18, 2019 Posted June 18, 2019 perfect, should hopefully be able to dimple the cutouts too, so shouldnt be any lost strength. there are already large oval holes where i want holes anyway, no clue what for. perhaps air con was an option, but id doubt it on a 71 corona. 1 Quote
gavinnz Posted June 29, 2019 Posted June 29, 2019 I have a couple of bunny cert questions.... I have bought a copy of the Car Constructors Manual which I am currently reading and I am trying to get me head around some of the details as they relate to my build. The car I am building is a 1990 MX5, with body mods smoothing out the body and getting rid of lots of body lines, lowered a small amount on coil overs, fully open Speedster with a 3.0, 12 valve Alfa Romeo V6 driving the rear wheels through a MX5 . 1. Is there any leeway with the minimum height for rear reflectors on a car? I read in a couple of places that 250mm off the ground was a min, but I would like to go lower.... 2. With a fully open car (Speedster with not even a soft top) with a good central mirror do I still need a side mirror on the drivers side? 3. I have headlights (pop up) and one pair of front indicator lights. Can those indicator lights double as park/position lights? Normal indicators when the lights are off. Both on when position lights are needed then changing to one side off and one side flashing when indicating?? 1 Quote
Adoom Posted June 30, 2019 Posted June 30, 2019 12 hours ago, gavinnz said: I have a couple of bunny cert questions.... I have bought a copy of the Car Constructors Manual which I am currently reading and I am trying to get me head around some of the details as they relate to my build. The car I am building is a 1990 MX5, with body mods smoothing out the body and getting rid of lots of body lines, lowered a small amount on coil overs, fully open Speedster with a 3.0, 12 valve Alfa Romeo V6 driving the rear wheels through a MX5 . 1. Is there any leeway with the minimum height for rear reflectors on a car? I read in a couple of places that 250mm off the ground was a min, but I would like to go lower.... 2. With a fully open car (Speedster with not even a soft top) with a good central mirror do I still need a side mirror on the drivers side? 3. I have headlights (pop up) and one pair of front indicator lights. Can those indicator lights double as park/position lights? Normal indicators when the lights are off. Both on when position lights are needed then changing to one side off and one side flashing when indicating?? 1 and 3 are probably in here: https://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004/ 2. My Starlet hasn't had any side mirrors for years. Hasn't been mentioned in two certs and numerous WOFs. It's kind of annoying not having one when changing lanes. 2 Quote
AllTorque Posted June 30, 2019 Posted June 30, 2019 Wof rules for mirrors. pre 2000 you must have interior OR right mirror. post 2000 you must have both. If you have tints you need both side mirrors. https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/rear-view-mirrors https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vision/glazing see tables and images 2 1 Quote
gavinnz Posted June 30, 2019 Posted June 30, 2019 1 hour ago, Adoom said: 1 and 3 are probably in here: https://www.nzta.govt.nz/resources/rules/vehicle-lighting-2004/ 2. My Starlet hasn't had any side mirrors for years. Hasn't been mentioned in two certs and numerous WOFs. It's kind of annoying not having one when changing lanes. I just re read that page and it does not mention the minimum height for reflectors, I only read that in the CCM. As I read it it does not exclude suing the front indicator lamps at the front as position lamps as either can be amber... but I am still unsure Thanks for the side mirror info. Quote
Ghostchips Posted June 30, 2019 Posted June 30, 2019 I notice modern cars turn off a headlight & park light when the indicator comes on, pretty sure you can use the turn signal light as a park light if they are. My old white datsunpower car had that setup. Totally legal. Quote
