Yowzer Posted June 30, 2019 Posted June 30, 2019 Legal if it's factory, not necessarily legal as a retrofit Quote
KKtrips Posted June 30, 2019 Posted June 30, 2019 Standard for Lighting - if you have a vehicle being certified - otherwise WoF standards apply. https://lvvta.org.nz/documents/standards/LVVTA_STD_Lighting_Equipment.pdf Quote
gavinnz Posted June 30, 2019 Posted June 30, 2019 So they allow it for the rear... I think I have a good case for the front being less of a safetly issue.... ? "A direction-indicator fitted to the rear of a low volume vehicle may be either: (a) an individual item of lighting equipment; or (b) incorporated within the rearward-facing position-lamp and stop-lamp circuits, so that when in operation, the directionindicator illuminates or cancels, as necessary, the rearwardfacing position-lamp and stop-lamp. NOTE: A direction-indicator incorporated within the rearward-facing position-lamp is the standard system that has been used in the American automobile industry for over 50 years." Quote
gavinnz Posted July 11, 2019 Posted July 11, 2019 I think I am starting to get my head around the cert process a little. I have bought and read and re read the CCM and read a bunch of the regulations online. One question that is not specifically answered in the book.... I have a convertible MX5 from 1990. I have turned it into a Speedster, fully open car with body mods and an Alfa Romeo 3.0 V6. I am looking at cutting the screen off the car at the bottom of the A pillars. Then cutting a screen frame from an identical donor car including a lot of the body with it so I have overlap of parts where the screen bottom of the donor parts meets the body. Then refitting the full screen and screen frame at more of an angle.... by cutting away material until it all fits and welding it back together with extra bracing to the welded area. Same screen. Other than doing the work in a workman like fashion and documenting the work and maybe even getting the cert chap to pop to the shed to take a look when needed to see how it's going to go back together.... what else do I need to consider?? The seat will be lowered so head to screen distance will be safe.... Thanks. Gavin Quote
Jeffs_Emporium Posted July 19, 2019 Posted July 19, 2019 Can anyone reccomended an Auckland company that offer NDT with relevant certification for welded stub axles that arent SGS (they apparently no longer do cash sales and I'm not opening an account for something I use once every 6 years) Quote
cletus Posted July 19, 2019 Posted July 19, 2019 X ray laboratories. Much better price than sgs too Quote
Nominal Posted July 27, 2019 Posted July 27, 2019 7 hours ago, Mof said: Are wider offset rims covered by cert? Thanks Only if they exceed the threshold Quote
h4nd Posted August 1, 2019 Posted August 1, 2019 Where's the standards / requirements for ewof for caravan please? I can see many docs saying 'you must have one' but none syring what the the technical requirements are (other than it's 'proscribed work''). Thanks. Basically I wanna see what's the minimum needed to get power into a van for a PC, lamp and a heater. Cheers edit: @kempy? Update, it's a joint AU/NZ standard, $123 to download here in NZ: or at https://vicparks.com.au/app/uploads/2016/02//as3001_2001-electrical-installations-relocatable-premises.pdf Quote
Nominal Posted August 1, 2019 Posted August 1, 2019 26 minutes ago, h4nd said: Where's the standards / requirements for ewof for caravan please? I can see many docs saying 'you must have one' but none syring what the the technical requirements are (other than it's 'proscribed work''). Thanks. You could try reading on https://www.electricalforum.co.nz Prepare for lots of this sort of thing: Quote
ajg193 Posted August 2, 2019 Posted August 2, 2019 7 hours ago, h4nd said: Where's the standards / requirements for ewof for caravan please? I can see many docs saying 'you must have one' but none syring what the the technical requirements are (other than it's 'proscribed work''). Thanks. Basically I wanna see what's the minimum needed to get power into a van for a PC, lamp and a heater. Cheers edit: @kempy? Update, it's a joint AU/NZ standard, $123 to download here in NZ: or at https://vicparks.com.au/app/uploads/2016/02//as3001_2001-electrical-installations-relocatable-premises.pdf Head down to the EPS Library at UC, they'll probably have a copy on the shelf that anyone can access free. /edit clicking that link of yours gives the file anyway... Double edit, your copy is superseded. I have the latest copy. I'll see if I can PM it to you. Quote
Mof Posted August 2, 2019 Posted August 2, 2019 @ajg193 me also please if you don't mind please and thank you Quote
kempy Posted August 2, 2019 Posted August 2, 2019 I'm avoiding that by going entirely 12v and using an inverter in case of needing something to run off 230v, so not much help I'm afraid. Quote
ul9601 Posted August 6, 2019 Posted August 6, 2019 If I have a cracked lens of say, parking light (or any other lights except head light), is it acceptable to glue or sealant repair it? Virm states the following for rejection: A lens is missing, or has a hole, crack or other damage that allows moisture or dirt to enter. The light is not diffuse and/or is altered, eg due to damage or modification I take the intent of the rule is to prevent non-diffused light output and nil foreign object ingress (which would degrade the light output). Therefore, if the repair of the crack with glue (or similar) does not significantly affect the light diffusion or foreign object ingress, it should be ok, IMO. What are the opinions of the learned inspectors (or anyone else) amongst us? Cheers. Quote
AllTorque Posted August 6, 2019 Posted August 6, 2019 IMHO repair is ok as long as water can’t get in and the wrong colour light can’t come out (like white out a tail light. Quote
Casper Posted August 6, 2019 Posted August 6, 2019 Just take the lens off the car and use a soldering iron from the inside to fix the crack. Quote
ul9601 Posted August 6, 2019 Posted August 6, 2019 3 hours ago, AllTorque said: IMHO repair is ok as long as water can’t get in and the wrong colour light can’t come out (like white out a tail light. Thanks guys. Quote
Guest Posted August 8, 2019 Posted August 8, 2019 Soooo i did ask somwhere here a long time back regarding line locks, turned out they are legal but came down to how its wired and a light. I tried a search but cant find it now. Could you please update me clint? In a few weeks ill finally be able to shift the sack down to me to finish and start enjoying it. Thank Quote
Guest Posted August 8, 2019 Posted August 8, 2019 On 23/05/2015 at 17:24, cletus said: line lock has to have a main on- off switch, with a light to tell you its is on, and a momentary switch to operate the line lock. Sorry just managed to find this. Is this still correct and passes WOF standards? Quote
cletus Posted August 8, 2019 Posted August 8, 2019 Yep, that's the cert requirements, a line lock needs cert though so even if you have it done as per that, it shouldn't pass wof without cert. Quote
