  • Replies 10k
strangely, I have a question for this thread
if person 'a' puts rego on hold for the minimum of 3 months
then sells vehicle to person 'b' after 1 month
person 'b' then puts rego on the vehicle, rego then starts from the date of change of ownership, this is on the nzta website
does person 'a' get a bill for rego because it was on hold for less than the 3 month minimum?
the reason I ask, is I bought a bike with reg on hold, I put 3 months rego on it, but the date of expiry was 3 months from when the reg on hold ran out, not 3 months from the date I put it in my name. so I got nearly an extra month free.
  • Confused 3
Hey Cletus
just wondering, if a car has had a section of the floor replaced and this needs a repair cert.
how would one find the repair cert paperwork?
ive done a car jam report and it doesn’t say anything, nor is there any other paperwork to go with the car
do these get logged on a system of any sort?
thanks
ash
Hi Cletus,
- Can you tell me if it is possible to cert a half cage (or if its even part of a cert) with side intrusion bars? It would follow the design of being out of the way of the driver and passenger head.
- on that, what is the definition of 'head restraints' when it comes to a half cage?
The half cage would be welded in, unsure whether the side intrusion would be bolt in or weld in. I prefer weld in but it depends if its even possible.
The reason I ask is because I want to add safety and stiffness to a late 60's kei car design but I don't want to have to have an authority card and log book for a 2nd car (I am planning a full cage in another project).
Thanks again.
I put my bike rego on hold for 3 months over winter,  got the letter saying regos due (they come like a month early) put 3 months on hey presto you get 4months! So I imagine you were in that time frame otherwise it would of back dated to date of purchase?
On ‎29‎/‎05‎/‎2019 at 19:27, ESKIN8R said:
@cletusHey mate, any reason these would run into issues when certing a car for an engine conversion?
MP168.jpg.308e1cea51a86c82f36b1387e26eeeb6.jpgMP168-2.jpg.2c2d9749852137630cba3b941e77e723.jpg
cant see a problem with those, looks like a much better idea than the factory ones
@Nominal they are escort top strut hats, the factory ones don't have a bearing to let the shock turn freely
On ‎23‎/‎05‎/‎2019 at 13:34, ~Slideways~ said:
Hi Cletus,
Thanks again.
yep a half cage is certifiable
cage requirements from an interior impact point of view, is here
https://www.lvvta.org.nz/documents/standards/LVVTA_STD_Interior_Impact.pdf
head restraints
https://www.lvvta.org.nz/documents/standards/LVVTA_STD_Head_Restraints.pdf
On ‎23‎/‎05‎/‎2019 at 06:34, Ashkellybarr said:
Hey Cletus
thanks
ash
do you mean it needs a repair cert and you want to know how to repair it to that standard?
or it has had one done and you need a copy of the repair cert?
I don't know how you would get a copy of it, you might be able to get the repair certifier to make copies for you? its not usually something that the customer gets a copy of, the cert paperwork gets given to the vtnz/vtnz inspector
Thanks - I was trying to work out how they would relate to an engine conversion :)
Cheers for the reply
the repairs been done and I’m told it was signed off by a certifier.
however car doesn’t come with any paperwork to back it up, nor can VTNZ or carjam can confirm anything about.
Car has since been modified and will require cert for the mods so I’m asking as I don’t want it to be an issue should it go for cert
thanks again
ash
thanks again
ash
I understand that it would be recorded on LANDATA that the car has been flagged and un-flagged. According to the link below the paperwork has to be kept for two years.
https://vehicleinspection.nzta.govt.nz/virms/light-vehicle-repair/introduction/inspection-and-certification-process
I don't know how you can access the records though, maybe talk to NZTA?
thanks again
ash
Shouldn't matter for lvv cert - it's not usually a requirement for a lvv certifier to sight the repair cert
On rare occasions the certifier might want to see it- the only time I remember asking someone for a copy of a repair cert was an old car with a lot of repairs, where the owner had a repair cert done, then did mods and it turned into a scratch built vehicle,  when that happens it is considered a new vehicle and the lvv certifier takes responsibility for the whole vehicle including the body structure
So in that case it was me covering my ass as well as I could because I hadn't seen the body before paint
are there any requirements for aftermarket wheel hubs?
i can get these
marina-front-hub-new-minor-4-pcd-with-be
machined cast hubs which would mean i dont have to mess about with bearing adaptors and plugging and redrilling the PCD of some old ones
i can get these
Yeah that should be fine if they are made properly of a suitable material
I think I've asked this before,
but who whom.do I write to get a fuck up in the. Motor registry corrected?
The papers for one of  my datto states that the chassis number is j15xxxxxxxx
and the engine number is j15 [same as above]
the body tag obviously has the correct chassis number on it.  And sooner or later it will be prudent to get it rectifiedin the system.
I had an error between chassis number in the system and actual chassis number, something like a 1 and 7 mix up, man at the testing station was being a dick about it, but his boss took the papers, walked into the office and came back job done.
I have no idea what the actual process is other than it is possible.
