cletus Posted April 11, 2019 Posted April 11, 2019 On 01/04/2019 at 23:07, 00quattro00 said: Are there any limits on how much you can increase the track of a vehicle? I want to make longer arms for a ifs 4wd that would increase the track by about 150mm over all Cant find anything that specifically says a max increase, apart from maximum overall width, and max track width difference front to rear, how you do it would determine what requirements would apply Most likely would require design approval for that sort of modification Quote
cletus Posted April 11, 2019 Posted April 11, 2019 16 hours ago, CorollaGT said: A car that's got a LVV cert for aftermarket seats (reclinable) and rails. Also was 5 seater at time of cert. Does the cert become invalid if the car gets a MSNZ roll cage and is fitted with fixed back seats/harnesses with authority card etc? Cert plate would need updating to match the mods to the car. 1 Quote
cletus Posted April 11, 2019 Posted April 11, 2019 15 hours ago, flyingbrick said: Its normal to change feom 4 stud to 5 when increasing engine power but would instead increasing stud size also make the cert man happy? Yep that's one of the options in the engine and drive train standard Usually required for an engine swap that is heavier than original, ie a 302 into a capri- upgrade the wheel studs to 1/2 and that matches , for example, a fox body mustang- they were 4 stud, 1/2 studs and factory fitted with a 302 4 Quote
cletus Posted April 11, 2019 Posted April 11, 2019 Obviously that comes with a common sense clause, fitting a big block chev into a fronte would not be made ok by fitting larger studs into factory hubs with matchsticks for spindles 2 3 Quote
flyingbrick Posted April 11, 2019 Posted April 11, 2019 I ask because my beetle will soon be ready for a drive (using an old 1200cc aircooled motor) but I went and purchased a 96 legacy turbo as a donor for a one-day-dream-build of the beetle. About to buy wheels and would be cool if the wheels i buy (4 stud) wont have to be replaced later on. Have never heard of beetle spindles being replace with larger, but haven't heard of any legal turbo two liter beetles in nz either. Doesn't really matter because it will never happen anyway lolololololol Also. Are weld Draglites/prostars legal for road use in NZ. I have seen them on the road a few times but that doesn't necessarily make them OK Quote
CorollaGT Posted April 11, 2019 Posted April 11, 2019 2 hours ago, cletus said: Cert plate would need updating to match the mods to the car. Does that mean a full recert or just a minor paperwork update? If thats such a thing Quote
KKtrips Posted April 11, 2019 Posted April 11, 2019 4 hours ago, CorollaGT said: Does that mean a full recert or just a minor paperwork update? If thats such a thing All certs are full certs, except a wheel and tyres update and partial/full return to standard. The amount of time difference between doing a "minor paperwork update" and a full recert is not that much so you might save a little, but not a whole bunch. Keeping in mind the certifier has to check that all previously certified mods are still compliant and that there are no other obvious mods that have taken place since the last cert. FYI - plating fee is approx $200 which is what pays for the LVVTA system, the rest of the cost is the certifiers time and their costs. (a plate reprint for a partial return to standard or a wheels and tyres change is about half that) Quote
cletus Posted April 11, 2019 Posted April 11, 2019 6 hours ago, flyingbrick said: Have never heard of beetle spindles being replace with larger, but haven't heard of any legal turbo two liter beetles in nz either. Also. Are weld Draglites/prostars legal for road use in NZ. I have seen them on the road a few times but that doesn't necessarily make them OK the engine weight is more of an issue than hp, so a beetle probably wouldn't need the spindles upgraded for an engine swap, where the engine is in the back draglites/prostars are ok 1 Quote
M.H. Posted April 11, 2019 Posted April 11, 2019 7 hours ago, cletus said: Cant find anything that specifically says a max increase, apart from maximum overall width, and max track width difference front to rear, how you do it would determine what requirements would apply Most likely would require design approval for that sort of modification Is there an easy to comprehend document i can read as I'm not very good at words This is what I'm wanting to do https://www.chaosfab.com/96-02-4Runner-Long-Travel-Boxed-Lowers-Kit-96000BK-4.html Quote
KKtrips Posted April 11, 2019 Posted April 11, 2019 5 minutes ago, 00quattro00 said: Is there an easy to comprehend document i can read as I'm not very good at words This is the infosheet for design approval, effectively you are wanting custom IFS, so will need to be assessed via the Technical Advisory Committee (TAC) https://lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2016_LVV_Custom_Independent_Front_and_Rear_Suspension_Approval_Application_Guide.pdf Background:The NZ Hobby Car Technical Manual (HCTM) requires that any custom independent front or rear suspension (IFS/IRS) assembly obtains approval from the LVVTA’s Technical Advisory Committee. This includes any situation where an original equipment (OE) IFS has been transplanted into a different vehicle and where its OE suspension arm pivot-point locations have changed to non-OE locations, or where the relocation of any geometry-critical pivot points has taken place, thereby altering the suspension systems pre-set geometry. 1 Quote
scooters Posted April 11, 2019 Posted April 11, 2019 7 hours ago, flyingbrick said: I ask because my beetle will soon be ready for a drive (using an old 1200cc aircooled motor) but I went and purchased a 96 legacy turbo as a donor for a one-day-dream-build of the beetle. About to buy wheels and would be cool if the wheels i buy (4 stud) wont have to be replaced later on. Have never heard of beetle spindles being replace with larger, but haven't heard of any legal turbo two liter beetles in nz either. I searched this one for a long time with the quad cam engine. Very hard but it is doable to keep the engines under the deck lid in the quad cam. The physical size difference is huge. And... they get hard to lower because they have sumps. Hope you do it but. 1 Quote
Nominal Posted April 11, 2019 Posted April 11, 2019 14 minutes ago, scooters said: Hope you do it but. (too harsh?) 3 Quote
flyingbrick Posted April 11, 2019 Posted April 11, 2019 hehe, HZ will be back in full swing once i have the big shed built, cannot access it at the moment. Quote
M.H. Posted April 14, 2019 Posted April 14, 2019 On 11/04/2019 at 20:14, KKtrips said: This is the infosheet for design approval, effectively you are wanting custom IFS, so will need to be assessed via the Technical Advisory Committee (TAC) https://lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2016_LVV_Custom_Independent_Front_and_Rear_Suspension_Approval_Application_Guide.pdf Background:The NZ Hobby Car Technical Manual (HCTM) requires that any custom independent front or rear suspension (IFS/IRS) assembly obtains approval from the LVVTA’s Technical Advisory Committee. This includes any situation where an original equipment (OE) IFS has been transplanted into a different vehicle and where its OE suspension arm pivot-point locations have changed to non-OE locations, or where the relocation of any geometry-critical pivot points has taken place, thereby altering the suspension systems pre-set geometry. Would that also cover fabricating a new upright as well? Quote
Nominal Posted April 14, 2019 Posted April 14, 2019 8 minutes ago, 00quattro00 said: Would that also cover fabricating a new upright as well? Fo'sure. Quote
Rhyscar Posted April 16, 2019 Posted April 16, 2019 Just wanting to check what I can do to my seam above my wheel in cert world. I have enough clearance (just) for full compression without it touching but just wanting to be doubly sure I can’t damage the tyre on a big compression. This is being built to do jumps on targa.. A double seam like this provides quite a lot of strength to a sheet metal folding so I’m not sure if I can cut it back then stitch weld a doubler over the gap or something similar? In the past ive bashed seams like this flat but that doesn’t seem like the right thing to do either. Quote
tortron Posted April 20, 2019 Posted April 20, 2019 Looks like someone tried to re register my new Morrie in 2016 It failed. I imagine due to rust and possibly wrong engine. Will it now be flagged for rust and il need a repair cert? I'm going to get replacement chassis horns and seemlessly replace the whole lot 2 Quote
cletus Posted April 20, 2019 Posted April 20, 2019 On 17/04/2019 at 11:51, Rhyscar said: cut it back then stitch weld a doubler over the gap or something similar? I think that would be ok 1 Quote
cletus Posted April 20, 2019 Posted April 20, 2019 4 hours ago, tortron said: Looks like someone tried to re register my new Morrie in 2016 It failed. I imagine due to rust and possibly wrong engine. Will it now be flagged for rust and il need a repair cert? I'm going to get replacement chassis horns and seemlessly replace the whole lot if its got any rust or previous repairs it will need a repair cert at re reg time I would suggest getting a repair certifier involved from the start- its cheap compared to stripping it again later if you try to sneak it through without, and the certifier wants it done slightly differently or wants to see it before paint etc Quote
Nominal Posted April 20, 2019 Posted April 20, 2019 4 hours ago, tortron said: Looks like someone tried to re register my new Morrie in 2016 It failed. I imagine due to rust and possibly wrong engine. Will it now be flagged for rust and il need a repair cert? I'm going to get replacement chassis horns and seemlessly replace the whole lot I'm not sure if you can find that out. It would be recorded on the LANDATA system though. Quote
