Jeffs_Emporium Posted April 25, 2019 Posted April 25, 2019 Negative. Trying to organize it to put it through but the standard rear subframe are not camber adjustable so I have about 5 degrees negative camber at desired height Quote
crustywhip Posted April 25, 2019 Posted April 25, 2019 I didn't with my x71 doing the same mod to the subframe and certed fine. Quote
tortron Posted May 4, 2019 Posted May 4, 2019 If I was to buy some old banded steel wheels to go on a car getting certified, what if any paperwork would I need. Assuming they are within the limit for width increase, the band is the correct thickness, it runs true, and the welds are (visually inspected at least) good. Is seeing them bare metal sufficient or do they need a runout/crack testing piece of paper? Quote
CaMpylobacter Posted May 5, 2019 Posted May 5, 2019 What happens if you buy a vehicle that’s on an old declaration type cert, has rego on hold, but they don’t have the old declaration letter thing anymore? recert? Or are there records kept somewhere? Quote
KKtrips Posted May 5, 2019 Posted May 5, 2019 28 minutes ago, Dolan said: What happens if you buy a vehicle that’s on an old declaration type cert, has rego on hold, but they don’t have the old declaration letter thing anymore? recert? Or are there records kept somewhere? We carry a fair few of them on file, but not all of them. (it relied on the person filling out the declaration to send it into the MoT back in the day) Does it still have live rego? If it does then send me the rego number tomorrow and I'll look to see if we have a copy on file. Quote
CaMpylobacter Posted May 5, 2019 Posted May 5, 2019 Thanks you beautiful person. ill slam you a on. the window of the old fella that owned the rig reckons she has ‘ownership papers’ but not sure what else allegedly on hold I haven’t checked Quote
cletus Posted May 5, 2019 Posted May 5, 2019 On 23/04/2019 at 07:22, Ashkellybarr said: Regarding fuel system wiring changing carb tank to EFI with in tank pumps, using a large inspection plate for pump fixings would a compression glad for cable through the plate be ok? Can’t really find much aside from this blurb, 2.3(16) An electrical system within a low volume vehicle must be designed to have electrical equipment such as pump motors and solenoids isolated from the fuel tank and system. and any other suggestions or things to watch out for with doing these mods to a tank? cheers ash Anything you use in a fuel related application has to be designed for that purpose. The rule book doesn't really mention much about internally mounted pumps and wiring apart from this Quote
cletus Posted May 5, 2019 Posted May 5, 2019 On 23/04/2019 at 20:40, doullama said: Looking at u.s conversion vans: I see as part of entry cert they must now (from '16) be lvv certified due to the removal of bracing when installing side windows, fibreglass roof, dodgy seats & seatbelt mounts etc. Does this also apply to the many vans that are already on the road? These two are my current candidates, dodge is already lvv certed (and has 318) and ford is a heavy vehicle therefore exempt (and has 460 + uncle Rico vibe) both 14k with no bites for a while/ripe 4 beatdownz. Was just wondering as if so there must be hundreds of vans due for some wicked spendy work Yeah those are a bit of a cock up There was lots that got complied that should have been certified first for the mods Quote
cletus Posted May 5, 2019 Posted May 5, 2019 On 24/04/2019 at 13:31, dspec_tt131 said: Do I need to go through any design approval processes or crack testing to make my Toyota mark ii gx61 IRS rear subframe camber adjustable - similar to this method- they are toe adjustable on the inner trailing arm mount but not camber adjustable on the outer so it's just replicating what's already there but making it stronger Nah doesn't need design approval. Have certed a couple of that style suspension with similar mods Quote
cletus Posted May 5, 2019 Posted May 5, 2019 On 05/05/2019 at 10:34, tortron said: If I was to buy some old banded steel wheels to go on a car getting certified, what if any paperwork would I need. Assuming they are within the limit for width increase, the band is the correct thickness, it runs true, and the welds are (visually inspected at least) good. Is seeing them bare metal sufficient or do they need a runout/crack testing piece of paper? Visual inspection by the certifier with tyes off is the requirement, any doubt and they have to be NDT'd Quote
cletus Posted May 5, 2019 Posted May 5, 2019 On 23/04/2019 at 20:59, MaxPower said: whats the go if i had a 1980 L300 van, and had a de-reg L300 cab I wanted to put on the chassis instead? (van to cab) would that need cert as its pretty much the same? thinking it would be an easier way to make a L300 well side later on, than cutting down a van if that makes sense. cheers Yes it would require cert. Quote
Kimjon Posted May 7, 2019 Posted May 7, 2019 It's not like I intend to drive it in the rain, but just checking if pre 92 vehicles need a windscreen washer/squirter bottle? I found this, and that how I read it: I'm having a bit of a dumb night where I'm struggling with written English. Quote
Nominal Posted May 7, 2019 Posted May 7, 2019 In my experience, if they are fitted they have to work. If they are not fitted (i.e. completely removed) it's OK. Quote
Corbie Posted May 7, 2019 Posted May 7, 2019 iirc pre 1992 if the nozzles are there, they have to work, if there are no nozzles then no problems. Quote
scooters Posted May 7, 2019 Posted May 7, 2019 if not nozzles and wipers..... rain-x my good man. if it's good enough for aircraft then it's overkill for me. Quote
Kimjon Posted May 7, 2019 Posted May 7, 2019 It's got some shit attempt at crudely fitting some squirters, a real home job. And a jappa tank from a wrecking yard hooked to that. Better off without it I think. Quote
JoKer Posted May 7, 2019 Posted May 7, 2019 56 minutes ago, Kimjon said: squirters Mate deleted his on a wrx bonnet & replaced nicely with Irrigation Squirters from Mitre10 Gardening dept worked rather well ( Quote
kws Posted May 7, 2019 Posted May 7, 2019 Just dont buy $2 washer jets from Aliexpress..... argh. Even at their lowest setting they wash the windscreen of the car behind me. Quote
Bling Posted May 7, 2019 Posted May 7, 2019 Put a T in the line and put half the fluid back into the tank? Quote
